Question about Car Audio & Video
A new lanzar sd32mu car stereo
Opend box and on wiring harness is pluged into back of stereo there is
a plug and at other end there also is a plug is some thing missing or do i need a harness to hook it up also it is going in my 63 vw bug and inst.says you need to hook 1 wire to e brake but my bug doesnt have
a ebrake
  • 45 Answers
You need a factory wire harness for your car you can pick these up at bestbuy. The cord for the ebrake twist that to the ground wire its basically a safty thing so you can only work it while not driving. Hope this helps Good ratings help me out.. Have a good day.
Posted on Jan 13, 2009
Need to know how to connect the two wires socket in the back of my 2006 subaru impreza with manual transmission now i have a blinking check engine light
usually unplug wiring fromradio and plug one end of new harness into radio and the other into the original radio connector
Mar 27, 2014 | 2006 Subaru Impreza 2.5i
Tip
How to install Radio in Honda Accord
Things You'll Need:
* Stereo
* Wiring harness
* Dash kit
* Phillips screwdriver
* Heat shrink
* Lighter
* Wire strippers
* Wire caps
In order to install A Radio first follow steps of Removing the Factory Radio
#1
Open the center console, and you'll see two phillips screws at the bottom. Unscrew both of them.
#2
Remove the drink tray, and unscrew three more phillips screws. The center console is now loose enough to move.
#3
Pull the center console back a few inches to expose two more screws under the plastic part of the gear shift. Remove these screws.
#4
Pull the ashtray out of the dash, and you'll see one more phillips screw. Remove this screw and pull off the plastic panel around the factory stereo.
#5
Locate the metal tray under the factory pocket (below the stereo), and pull it out of the dash. There will be two phillips screws holding it in place; remove those, and then pull the stereo out of the dash. You'll need to unplug the wiring harness that is plugged into the back of the radio.
Now Install The New Stereo
#1
Assemble the dash kit, as shown in the instructions. Put it into the dash where you just took the stereo out. There will be a rectangular opening, and a pocket underneath. The opening is where the radio will go.
#2
Secure the dash kit by screwing in the one screw in the ash tray, and the two in the opening of the panel.
#3
Insert the metal cage that came with the stereo into the opening above the pocket. Ensure that the fit is flush with the pocket. Using a screwdriver, bend the metal tabs upward, which holds the metal cage in place.
#4
Start wiring the stereo harness to the wiring harness. Match wires color by color until all of the wires are paired. For example, if you find a purple wire coming out of the aftermarket wiring harness, plug it into a purple wire from the factory harness. You aren't touching any of the wires in your dash on this step, you are simply wiring the new stereo to the wiring harness.
To connect these wires you'll want to place a piece of heat shrink over one of the wires, strip the ends, twist both ends together, and then pull the heat shrink over the exposed metal parts of the two wires. Heat the heat shrink with a lighter until it shrinks and forms a tight bond between the two wires. When done correctly, you won't be able to pull the wires apart.
#5
Plug the aftermarket harness into the factory plug, and insert the radio back into the dash. If you find wires that don't have a match, be sure to cap them so that the ends aren't exposed. Exposed wires are what cause shorts and electrical problems.
#6
Work in reverse order to put the dash back together. The radio won't be secure in the dash until the dash is put back together.
Hope this helps
Thanks
on Oct 07, 2010 | Honda Accord Cars & Trucks
I want to know where and which cables to connection on my van
Thats pretty vague, but here is the basics:
Battery wire (red) should go from the battery of your van to the amp (+)
Ground wire (black) should go to the frame (metal) of your van and to the (-) of your amp
The blue wire should go from your amp to either the back of your stereo unit (remote accessory) or to the fuse box (accessory/ignition)
Left/Right audio should go to the subs.
If you are looking to install a new stereo into your van, they make a wiring harness that will fit the year and make of your van to get you going in no time.
All you do is buy that little wiring harness, and connect the wires on the back of your new stereo to the same colored wires on the harness, and plug the harness directly into your dash!
Super easy!
Hope this helps you out!
Feb 23, 2011 | Car Audio & Video
Im trying to install one of radios into my 1996 honda accord but how?
#1
#2
#3
#4
#5
#1
#2
#3
#4
#5
#6
Hope this helps
Thanks
Oct 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
How to install An SD54MU Lanzar stereo
Hi if you go to a autoparts store such as auto zone they sell a universal plug for your vehicle you plug it in to the radio harness on dash and then match up the colors coming off the radio harness it comes with a diagram to help you.
Feb 01, 2010 | Car Audio & Video
Intaller Manual Lanzar SD32MU
output socket
hello, where can I get a output socket for my lanzar SD33MU, that is the socket that goes into the radio/dvd player, It is 18 pins.
With great regards Lody Alblas
Nov 30, 2009 | Lanzar SD32MU Car DVD Player
Lanzar SD32MU: how do you disable the video screen
ok here is the big secret. There should be a wire that goes to the parking break. In most after market radios, it is a brown wire. The way to get around this is to put that wire directly to ground. It will work at all times.
Nov 06, 2009 | Lanzar SD32MU Car DVD Player
I dont know how to wire it to my car stereo wires
Do yourself a favor and run to audio store or even autoparts store & get an adapter plug/harness, cost is a few bucks but well worth it. It plugs into factory harness & you wire your new stereo to it according to diagram with new system.
May 02, 2009 | 2001 Dodge Stratus
I have a lanzar sd32mu stereo its new when i took it out of box the wiring harness has a connector at the end where there should be just wiring usialy there is just wires this has a connector
Looks as if you did not get a new unit.
The wires should look like this (top right side of picture) when new...
http://app.infopia.com/img/image/fp/VPID/1331418/img2/img.jpg
You have an aftermarket plug installed, which means it was in a vehicle already.
Need more help, just ask!
Jan 11, 2009 | Car Audio & Video
I need to install a kenwood cd player into my 2001 ford explorer step by step
goto the auto parts store and purchase a pair of stereo keys, fascia adaptor and wiring harness (you may need to get fascia and harness from a car audio store or circuit city.)
Then use the stereo keys to remove the factory stereo. Push them into the small holes on the front of the stereo push them slightly outwards and pull to release the stereo. Unplug all the connectors from back keeping track of where they fall.
Insert wiring harness into the stock wiring
attach fascia in regards to its packaged instructions.
Place cage from new stereo into the hole in the dash using the tabs on cage to secure it,
Attach stereo to other end of new harness along with aerial (may need adaptor for this also depending on the new head unit.)
Insert stereo into new cage and voila nice new stereo.
Nov 27, 2008 | Kenwood Car Audio & Video
Car Audio & Video Logo
123 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
