Question about Sew Pro QuickStitch SP-402 Mechanical Sewing Machine
Looking for the AC adaptor and foot pedal for Quick Stitch model sp402
Bought it used from Goodwill and these two were missing can you help me find them and at what price
Need a thread tenson dial for a dress maker 101
If your upper Thread Tension Dial/Assembly is out of whack, broken or missing, then you need to Re-Adjust/Re-Calibrate, Repair or Replace it with a used or new part upper "Thread Tension Assembly". New Exact Replacement Parts are usually not available on vintage machines, so you will need to (a) Buy a used part (Exact or Similar enough to be compatible and work), or
Used parts can usually be found on-line, from used parts dealers or people selling stuff on places like eBay, etsy or Craig's List.
(b) a new generic part that may need to be mounted, but may loose the ability to automatically release thread tension when the presser-foot is lifted. New generic parts are not likely for this part, so unless you can figure out how to rebuild and fix the one you have, your last option may be to bolt-on an independent industrial, "Thread Tension Assembly", that can be bought on-line from Cleaner's Supply catalog < cleanersupply.com > for the price of a cheap dinner. Hope this helps.
Sincerely, --Amender (2018 FEB 19)
Feb 18, 2018 | Sewing Machines
When were the Singer merritt 3013 manufactured?
I have a Singer Merritt, I got it at Goodwill a few years ago, I looked up the manual on the internet and have printed it out in case you need it. BTW, the reason I bought it is because it's superior to what's manufactured today, all parts are metal, not plastic. This machine is no longer made as you've suspected so it was probably made in the 50's. See if you can find any info on the internet as I've done. At my age, it's on it's way out to anyone interested.
Jan 20, 2018 | Singer Sewing Machines
Help please. How to adjust presser foot. Where to chg stitch length
Please provide the make and model of your machine. There is generally no adjustment to the presser foot for selecting a straight stitch. You just need to use the specific presser foot that the owner's manual recommends for a straight stitch. The adjustment is made to the stitch length and stitch width selectors. But, since we don't know which machine you have, we can't help.
Search for:
Make Model manual
Aug 26, 2017 | Sewing Machines
I bought a white model 609 at the local goodwill. Cannot get the stitch selector dial to turn
It's probably an older mechanical machine which has set idle for many years without oiling or cleaning. Most likely the dial has seized due to the old oil. If nothing is broken, you can probably resurrect this old machine and make it useful again with some good quality oil, heat, a fair amount of elbow grease, and a lot of patience. Good luck!
Wheel on right side that controls the needle up and down is very tight...
Jul 12, 2017 | Sewing Machines
Need threading guide please.
search Google perhaps you will find what you need there .
Jan 24, 2016 | Sewing Machines
Can I purchase a foot pedal, adaptor,(if required) and an instruction manual for synergy 8 stitch sewing machine please.
This type of machine is usually referred to as a mini sewing machine and as such it is manufactured by the million with minor styling variations and various makers' badges. They all use the same foot control and power adaptor.
The simplest solution is to search for "mini sewing machine foot pedal" or similar on eBay, but don't pay very much because the machines are simply not worth it. They can be bought new for around £50 including accessories and manual etc. I think about a£10 is what you might have to pay but honestly you'd be better off with a second hand full sized machine.
You haven't said which country you are in so I'm going with the UK. Here's a start: ELECTRIC MINI SEWING MACHINE FOOT PEDAL AND POWER LEAD
Mar 03, 2015 | Sewing Machines
Does anyneed a model 5932 singer sewing machine
I don't know if you have found someone by now, but you might try listing it in Craig's List, either for a nominal price, or you can list it as a free giveaway. You can also donate it to Goodwill or the Salvation Army.
Jul 13, 2014 | Singer Sewing Machines
Is the motor in my kenmore sewing machine bad?
will the motor run if you turn it by hand when the power is on
Apr 02, 2014 | Sewing Machines
Sew Pro QuickStitch SP-402 Mechanical Sewing Machine Logo
Top Sew Pro Sewing Machines Experts
Steve
Jamie Sewell
Level 1 Expert
ray gallant
Are you a Sew Pro Sewing Machine Expert? Answer questions, earn points and help others
