Question about BenQ MP511 Projector
Benq mp511 projector does not recognize cable tv when run through pioneer receiver
Run from cable box directly to projector works fine but run through a pioneer receiver( to be able to switch between tv, DVD, game) projector cuts in and out showing picture or sound but not both
    Champion:
  • BenQ Expert
  • 225 Answers
HDMI?
Posted on Dec 06, 2012
jfpogie
  • 104 Answers
SOURCE: projector shutdown
your air filter of your projector is dirty, try cleaning it. tnx
Posted on Jan 30, 2008
Marrie
  • 563 Answers
SOURCE: BenQ PE8700 DVI problem
Hi guys
All that needs to be done is a firmware upgrade.
This can however only be done by a BenQ Approved Service Provider because if the person doing this makes a balls-up the Projector will be dead as a doornail.
Posted on Apr 01, 2008
vortash
  • 431 Answers
SOURCE: My Benq pb6100 projector needs a ''shake'' on switching on to run
Hi I am Vortash possibly a loose plug or the bulb housing is not secure and the cut off switch is not contacting .. loose fuse .. dry joints o loose component .. one thing is for sure keep shaking it
and your going to kill your bulb ?. During the arc on the lamp it builds up carbon deposits if they break loose they get hot in the bulb under working conditions against the glass and sometimes fracture it ?. don't shake your your unit unless you can afford to replace this at between $400 and $800 i bet that repair would be a more economic solution hope this helps Regards Vortash
Posted on May 17, 2009
  • 35 Answers
SOURCE: Hi, the Benq PB8263 projector is working fine we
Please check the input selection some times it goes to y,pb,r mode.
Mahesh
M.R.Corporation
Mumbai -India
Posted on Aug 05, 2010
heathgr
  • 442 Answers
SOURCE: my projector won't project anything.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Posted on Aug 20, 2011
Dust particles being projected onto screen with BENQ MP 525 projector
White spots on the screen are generally caused by a bad DMD chip.Multiple elements of the chip remain continuously on causing these spots.Solution is replacement of DMD chip.
Samr
Jan 14, 2013 | BenQ MP511 Projector
Hi .. need to connect my tv audio through my pioneer 5.1 home theater.I was using normal video audio cable ...shall i use component cable???pls advice
"Component" cable refers to the 3-wire hi-def video connection. It's irrelevant to audio.
Assuming you get all your TV programming through a cable box...
The TV wouldn't actually be a source of audio.
I would advise you to route the Cable Box's BEST DIGITAL audio directly to the Pioneer model number ????? (which would be helpful to know for this conversation).
Run the cable box's normal analog audio to the TV so you can watch it without the Pioneer turned on.
And route the best Cable Video (HDMI, Component?) directly to the TV. Unnecessary paths through the receiver can degrade the signal.
Feb 16, 2011 | Pioneer 1000 Watt 5.1 Surround Sound...
On my projector BENQ mp511+ the green lamp keeps blinking continuously. tried shutting off the projector for a while. but no result. Please help?
I expect the lamp life is about to expire. Check your instruction book to clarify the situation.
If you haven't got one, go to the BenQ web site to down load one.
Hope this helps.
Oct 30, 2010 | BenQ MP511 Projector
The projector has several white dots on the screen. how can i fix it, it started with a few white dots then every time i used it, it doubles and doubles until it became many dots.
I have the same problem. I think we need a class action!
http://s1231.photobucket.com/upload/albums/m3231/?location=projector+spots
Oct 06, 2010 | BenQ MP511 Projector
Pioneer works with cable box but not with new blue
HDMI version is 1.3 in your receiver.The current version is 1.3b. I would suggest calling Pioneer cust assistance and see if there is a firmware update. Your unit has a 2 year parts & labor warranty. Their # is 1-800-421-1404 It sounds like a CODEC issue. Hope this helps
Dec 25, 2009 | Pioneer VSX-92TXH Receiver
Getting picture lines across tv that keep scrolling down like old tv's used to do. HDMI connected to cable box. Cable box to tv works fine and dvd to receiver hdmi to tv works fine no picture problems. can...
You will need to run HDMI directly from TV to Cable Box. Then run an optical or digital coaxial from your cable box to your receiver. The version of HDMI in your receiver is 1.1 or 1.2 and will not pass signal correctly. The recording industry has placed many roadblocks in front of HDMI to keep us from recording.... Go figure... That's the fix though. Hope this helps
Dec 19, 2009 | Harman Multimedia AVR-254
I have an Onkyo TX-SR605 AV receiver that just stopped outputing video to my Panasonic projector. I have connected other devices directly to the projector and video is fine, so the problem is not the...
Goof information. Have you eliminated or proven the Onkyo as a cause by going direct to the projector? Try another Input and/or Output. It's best to know which component is broken and if it's limited to a specific subset of its function.
Settings are also indicated. Run through the video setup again. If it just stopped, what preceded it?
Nov 27, 2009 | Onkyo TX-SR605 Receiver
Problems with Sharp Blu Ray Player "copy protected signal"
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
Apr 19, 2009 | Pioneer VSX-D514 Receiver
No Video
have you gone through the menu to assign which signals the receiver recognizes?  I had to change the source when i switched to the Dish Network HD receiver.
Aug 24, 2007 | Pioneer VSX-1016 Receiver
BenQ MP511 Projector Logo
177 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
