Question about Brother Office Equipment & Supplies
Brother model MFC-9970CDW won't print
Everything seems to be online and connected but it just won't print. for some reason it started automatically checking the "use printer offline" box but i fix that now and so I know that's not the problem.
SOURCE: Brother mfc is offline -
For my MFC, my PC says its ready and working properly. It really only works when I'm not connected to my cable modem. All PCs use it then. It's offline otherwise.
Posted on Oct 30, 2008
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Posted on Apr 16, 2009
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
the kowalski
  • 86 Answers
SOURCE: I can not print
You could try to use static ip to remove possible problems with dns retrieving:
  • Set the machine to static ip (Menu -> Network -> WLAN -> Boot Method -> Static).
  • Check the ip number on the machine (Menu -> Network -> WLAN -> IP address)
  • On your PC, go to Control Panel -> Printers
  • Right-click printer, choose Properties
  • Choose Ports and click "Add Port"
  • Double-click on Standard TCP/IP, follow the guide and type in your IP number earlier retrieved.
  • Save settings, press OK and the problem could be solved (if it was due to dns problems).
Also, if it works, you can change the network settings for scanner driver to go to ip address too instead of dns, even if it isn't a problem right now, it could later be.
Posted on Jun 02, 2009
trikha_karan
  • 66 Answers
SOURCE: My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Posted on Nov 10, 2009
My Brother printer mfc-9970cdw is off line how do i fix it
Depending on what type of connection you have. please specify
Oct 09, 2014 | Brother MFC-9970CDW
PRINT UNABLE EC
Your machine ventilation fan is not working, usually due to a foreign material being stuck at the fan or the fan is faulty or the PCB is faulty.
Mar 28, 2014 | Brother International - MFC-9970CDW -...
Brother fax machine MFC 495 CW won't print a received fax
Hello sir; would you try on another phone jack if still have same problem then replace phone wire.
Nov 01, 2012 | Brother MFC-495cw Color Inkjet All-in-One...
My brother mfc-7420 will print but won't let me scan and i can not find my disk
Go to the Brother web site and put in your MFC info and you may download it for free. If you find it to be difficult you may call Brother for support and they will walk you through it. Do not have to be under warranty. Hope this help you out.
Aug 28, 2012 | Brother MFC 7420 All-In-One Laser Printer
Brother 9970cdw toner
The Brother printers have a counter which will shut the printer down when the preset number of copies has been reached. You can reset the counter and it should print again. I did this 4 months ago. It bought me a little time, but my printer has begun to print a solid line down the left side of each page. I have cleaned everything that I can access to rule out smudged glass, etc. Perhaps it is just best to replace the drum or buy a new printer(much to Brother's delight and design).
Jul 10, 2012 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-J430W won't print
I don't have an answer but the one posted on February 18th by the Wales flag guy/Clive/Pineworks worked for me. Just don't forget to hit 99 after you've done everything or you'll be stuck in maintenance mode.
Jul 01, 2012 | Brother Office Equipment & Supplies
My MFC290C printer will not print in black. I changed the ink and it still won't print black. I changed the color of the type and it will print in colors, just not black. I ran the cleaning cylce...
You need to call Brother at 1-877-brother and tell them your mfc is "missing black". They will tell you where to take it to get the print head replaced under Brothers' warranty. This is a VERY common problem and Brother will cover the cost to repair it.
Aug 10, 2011 | Brother MFC-290C Printer
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Brother MFC-235C print head removal
there are no instructions that you would understand and once the print head is clogged up, you can noy mannually clean it , it has to be replaced! sounds like you are using generic ink!
Nov 05, 2008 | Brother MFC 240C All-In-One InkJet Printer
311 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
