Tried unplugging. Tried holding >> Open/close buttons. Tried holding power, open/close, and >> button.
SOURCE: I cant eject cd/dvd changer.
Try first unplugging unit from main, and holding the cancel button.
If that does not work try the following:
Hold at the same time the stop button on the main unit and key >10 on the remote control at the same time for about 5 seconds, until you get the word "initialised" on display. This will reset the unit to factory settings.
SOURCE: how do you unlock the tray for the panasonic
Cannot eject disc. ≥The unit may have a problem. While the unit is off, press and hold (>> / >>I) and (< OPEN/CLOSE) on the main unit at the same time for about 5 seconds. Remove the disc . After disc removal or if this does not work you may need to reset to factory defaults. for the player alone.
To return all settings other than some settings to the factory preset.
≥Select “Yes” in “Restore Default Settings” in the Setup menu.
This returns all values in the Setup menu and the on-screen menu, except for “Remote Control Code”, “On-screen Language”, “IP Address/DNS Settings”, “Proxy Server Settings”, “Network Service”, “DVD-Video Ratings” and
“BD-Video Ratings” to the default settings.
If this does not work then you may need to reset everything to the factory settings.
To return to the factory preset. Everything Reset.
(No setting)
≥Reset the unit as follows:
1 Press [POWER] on the unit to turn off the unit.
2 Press and hold (>> / >>I) and press [POWER] and [< OPEN/CLOSE] on the unit at the same time for more than 5 seconds until “PLEASE WAIT” is displayed on the unit.
3 The power is turned on and then turned off automatically.
Cheers!
SOURCE: LOCKED displays when attempting to eject disk from SA-HT670
i have a panasonic SA-HT720 and it displayed locked anytime i wanted to eject discs so i found out that dad27's solution was the best and holding down the stop and power buttons also locks the system as well as unlocking it. God richly bless u dad27 u really helped me out
SOURCE: I got a panasonic sapt
I am having the exact same problem with mine and mine is about 15 months old and I hardly use it either. All of a sudden it's just started with this error.
SOURCE: When I turn on my
You have a mechanical problem inside the drive. It needs to be taken apart to fix. There is a mis-alignment of the tray.
