Question about Brother Sewing Machines
Brother sewing machine vx 807
How do I add thread to an empty bobbin
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: brother vx-950 sewing machine
Place thread spool on the spool pin at back right top of machine. From there, thread through 1) rear thread guide (little hook), 2) front thread guide (front hook), 3) down and up through the thread tension dial from right to left so that thread picks up the thread spring check (the little spring on the left of the tension dial). 4) Through the thread take-up-lever, from right to left (the little lever that goes up and down). 5) Through the thread guard and guides (one on the front, one on the needle arm). 6) Through the needle, front to back. Good luck johntrev800 (at) yahoo.com
Posted on Jan 19, 2009
  • 3 Answers
SOURCE: I use Brother VX 1120 Sewing Machine. It can not
go to the brother website, you can download and/or look at the manual for free
Posted on Mar 04, 2009
make sure that when you insert the thread *top hole bottom to top* that you turn the bobbin itself until you hear a click *that is the spring sliding into the ****.
Posted on May 02, 2009
I have a brother vx1100 sewing machine and I forgot how to combine the bobin thread with the upper thread to start sewing please help
ono secret
just pull the bobbin thread down the slot in the bobbin holder and under the spring plate
leave about 6 " thread loose and put the bobbin and holder back in the machine
use you hand and turn the machine over a few times and the needle thread will pull the bobbin thread up
or use a bit of scrap material and start a short sew
Jan 15, 2017 | Brother Sewing Machines
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
How would to insert the bobbin in the sewing machine brother VX 1400?
There is not much of a secret to inserting a bobbin in a sewing machine. A couple of things to check, the thread from the bobbin should be pulled through the slot of the carrier, and make sure the thread comes through the sewing hole by manually lowering the threaded needle and then lifting it out of the hole again after it has picked up the thread from the bobbin. The video link posted below is useful if you have a Brother sewing machine.
If the stitching is still not right then check that the needle is fully inserted in its housing. (Push the needle up as far as it will go then tighten the screw.)
How to wind and install the bobbin and thread the sewing machine PART 2...
Aug 24, 2014 | Sewing Machines
How to thread the bobbin on a brother vx 1500
Did you ever find out the answer? i just got one of these models with no instructions and im so lost!
Aug 16, 2012 | Brother Sewing Machines
Brother vx-1435, needle cuts thread when sewing
change the needle it could have a burr or be damaged
also check the needle plate & bobbin area for burrs
Apr 09, 2012 | Brother VX1435 Mechanical Sewing Machine
Top & bobbin thread will not sew
Most likely the needle is in backwards. Weird I know, I have no idea why but if the needle is in wrong, it either hits the bobbin and breaks or won't grab the thread at all. Good luck.
Jan 06, 2009 | Brother LS-1520 Mechanical Sewing Machine
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Bobbin thread will not pick up nor will dog feed rise
my Brother sewing machine model VX 1120 will not pick up the Bobbin Thread. Machine is fairly new with only several hours use. I have changed needles , tried different bobbins, cleaned the machine. Any suggestions?
Jul 06, 2008 | Sewing Machines
Sewing Machines Logo
54 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
