Question about Philips Norelco 8240XL Electric Shaver
How to replace a razor head release button on a Philips norelco 8240xl
The head won't stay closed. I need to replace the head release button, but I need a diagram or specific instructions.
  • 3 Answers
SOURCE: head of philips norelco speed xl fell apart.
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
Hope this helps!
Posted on May 13, 2009
brector3
  • 1610 Answers
SOURCE: The head holder of my Norelco Philips HQ6707 shaver is cracked
You will find a replaceent for model HQ6707 at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-6700-series-cool-skin-head-holder-p-310.html
Posted on Jul 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: Norelco Smart Touch locked
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
brector3
  • 1610 Answers
SOURCE: I have a Philips Norelco
It sounds like maybe one of the blades is damaged and it is jamming the whole thing. Try taking apart the head assembly and then insert each head one by one turning the shaver on in between each one. This should identify if one is damaged and causing the problem
If you require new heads, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Posted on Sep 19, 2010
  • 9 Answers
SOURCE: Norelco/Philips jet clean shaver cleaning bath no longer works
I have had three 1050CC shavers all with the same problem. Apparently other models have the same issue. After about a year of use, the unit reverses after dipping the shaver into the cleaning solution for a second. Two were replaced by Philips within the 2 year warranty period. I still use the 3rd one. There are several things you can try. If the cleaning solution is low this will cause the shaver to reverse and not clean. Add more cleaning solution. I have noticed that sometimes I have to add more fluid to the unit after a week of use. Sometimes it is necessary to fill the solution a little above the max fill line. Be careful though. Filling it too much above the max fill line can cause cleaning fluid to run out of the bottom after a cleaning cycle. If the above two fixes don't work, then press the clean button and after the unit reverses back up, wait about 5 or 10 minutes and press it again and it should stay down as long as there is enough cleaning solution in the unit. If you wait too long or too little to press the button, it won't work. I have noticed if I press the button immediately after it reverses the same problem occurs. Also if I wait 30 minutes before pressing the button the same problem occurs. There must be some sort of timing cycle. You may have to repeat this process a few times to get it to stay down and clean. This is the only way I can get mine to clean now. Obviously something is getting dirty or wearing out over time in the cleaning system. Since I have had 3 shavers with the same problem, I know many others have had it too. Philips must be aware of the problem. It is frustrating that they don't offer help on their own website and consumers have to band together to solve problems that they should be solving. The two year guarantee is very generous, but there is a design flaw with this product.
Posted on Jan 23, 2011
HQ8 or HQ6? What is the correct head replacement?
These Philips Norelco Replacement Shaving Heads HQ8/52 are compatible with the following series: 7100 series, 7200 series, 7300 series, 7700 series, 7800 series, 8800 series, PT/AT700 series and PT/AT800 series. They are sturdy and durable and provide for a smooth finish. The Norelco razor heads keep your shaves close and comfortable and are easy to replace.
Norelco HQ6The Norelco HQ6 is men's replacement heads. The Norelco HQ6 is made up of stainless steel and contains 3 cutters. The Norelco HQ6 works with all Quadra Action razors. HQ6 Features:Replacement Heads Stainless Steel 3 Cutters / Combs
Norelco HQ6
Oct 14, 2015 | Head Health & Beauty
Philips norelco sensotouch replace the shaving unit. replace damaged razor heads
You will find RQ11 shaving heads at shaveroutlet.com at the link below
http://shaveroutlet.com/philips-norelco-rq11-sensotouch-replacement-heads.html
Mar 01, 2015 | Norelco Health & Beauty
I have a Norelco arcitec 1050 electric razor and I have lost my instructions. What does it mean when the red light starts flashing (picture of razor heads)?
Means that the the replacement heads indicator flashing, it's time to replace new heads. That Norelco RQ10 heads for Norelco arcitec 1050 electric razorreplacement parts.
Aug 15, 2011 | Health & Beauty
I can't get the shaver heads into the holder to stay fixed so they don't move
You will find a video showing proper installation at shaveroutlet.com. See link below and scroll down for video
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq56-super-lift-and-cut-replacement-heads-p-249.html
If you find that one of the parts are damaged or broken, you will find replacement parts for model 6613X at the link below
http://shaveroutlet.com/catalogsearch/result/?q=6613x
Aug 06, 2011 | Philips Norelco Reflex Plus 6613x Electric...
Will the HQ55 razor replacements work on the 5601x razor?
HQ55 heads will fit in your model 5601X but they will not work as well as the correct heads. You will find the correct heads for your model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq5-reflex-action-replacement-heads-p-246.html
Oct 24, 2010 | Norelco 5601 X Electric Shaver
I have a Norelco 6891 xl and a 7886 xl. No cord for either one. Also need new heads. Which razor is better?
Norelco 6891xl and 7886xl are Norelco Quadra Action men razor, that Norelco Quadra Action replacement heads is Philips Norelco HQ6 shaving heads.
Jun 20, 2010 | Norelco 7886XL Electric Shaver
Philips Norelco 8240XL Electric Shaver Logo
106 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
