Question about Altec Lansing PT8051 Rear Speaker
Altec Lansing PT8051 Rear Speaker is not giving any sound
80910EAWW0002506 REAR WIRELESS SPEAKER: Power source seems to be working, however there is no sound generating from the speaker. This is brand new. Please advise on possible solutions. Kind Regards
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
SOURCE: Dented front speaker grills.
Take a good size paper clip, make it into an L shape and stick it in one of the holes at the dent, be careful not to hit the speaker. Turn the lower end of the L so it is flat, up against the grill and put gently to straighten out the grill. the other solution is to take the whole speaker apart and push from the inside.
Nogenius54.
Posted on Mar 17, 2008
SOURCE: No Power (LED off) in the Altec Lansing VS4121
There is a fuse on the power supply board which is held in place with 4 screws. Yiu will have to unplug the sub-woofer connector to remove it.
Posted on Apr 15, 2008
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
SOURCE: Altec Lansing ada745
I work for a charity that had one of these donated today and as I was looking for a new sub for my cinema system I purchased it. I have no other speakers with it and no way of switching or varying the volume. I opened up the back of the sub and slid the board partly out exposing the PCB.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3734.jpg[/IMG]
You'll see 3 solder connections behind the scre in an "L" configuration. One of them is common, one volume and one power on. As I don't need volume, I'm happy with it being on full as my cinema system will vary the input, I joined all 3 together giving power on and full volume. It is working great now.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3737.jpg[/IMG]
For you guys with volume controls, I would suggest shorting out the two rightmost pins in the "L" and I recon this will power it up and try varying your volume control. I recon it'll work just great.
Good luck
Posted on Jan 22, 2009
I have an Altec Lansing 340 speaker system that is not working.
There could be a defect in the connector. Check both sides for continuity.
Jan 03, 2015 | Altec Lansing Audio Players & Recorders
Altec lansing multimedia speaker model ATP3 woffer is giving tearing sound at high base and it seems the woofer is not working at all
Your woofer is bad, probraly blew the megnatic coils, and if mention that it's giving you a tearing sound, then the woofer cone is tear somewhere and is not get the reflex to produce the sound.
Jan 28, 2011 | Altec Lansing Multimedia Computer Speakers
Altec Lansing VS3251 rear left channel not working
Sounds like you "blew" the left channel. Make sure your connections are good, and all positives and negatives hooked up the way they are meant to be. If it still does not work, take it to be repaired. Call around first, with the AND serial number. Get repair estimates, ask about the "bench charge"
Apr 11, 2010 | Altec Lansing VS3251 Speaker
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
Altec Lansing ADA995 Speaker system partial speaker play
Drivers and support softwares for Dell Dimension 9100 are still very much available to Dell's website (here). Download the audio driver for your StaCruz Audio card.
Hope this helps. Please don't forget to rate.
Nov 07, 2009 | Altec Lansing ADA995 Speaker
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Not good sound comes frm my Altec Lansing 251i speaker
1. you first check with other media player software and use another mediaplyer software checkit this problem, if u experience the same
2. check the the dvd disc is supported the 6 channel, use another 5.1 dvd disc
Jan 04, 2008 | Audio Players & Recorders
Output board for Altec Lansing ADA995
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Dec 24, 2007 | Audio Players & Recorders
Altec Lansing PT8051 Rear Speaker Logo
50 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
