Cannot connect smartphone to my computer via wi-fy
Have a d-link dir-815 router. works fine for wireless connection of laptop to home computer. would like to connect smartphone to home wi-fy. get "authentication problem" message although several secured networks are displayed, including mine. connected to wi-fy at local shopping centre with no problem. must be wrong setting somwhere in my wireless router configuration. computer is a dell xps 8300 with windows 7. phone is a sony ericson xperia mini st15a with android 4.0.4.
  • 4 more comments
  • Ernie Lohrenz Dec 03, 2012
    I still get "authentication proble"
  • Justin
    Justin Dec 03, 2012
    If it can't authenticate, you are most likely entering the wrong password.
    No, I checked and double checked the password. I know it's correct because I was able to connect my laptop to my computer wi-fi using the same password and it connectged fine.
  • Justin
    Justin Dec 03, 2012
    Do you use mac filtering?
  • Justin
    Justin Dec 03, 2012
    Ahh I see the problem. Your router is 802.11n. Android 4.0.x ICS has known bugs with N routers. Sony will need to patch it to fix. Make sure your phone is up-to-date there maybe a patch already for it. Also see if you can set a static IP on your phone. I always had problems on a old tablet I had with ICS. Had to wait for a patch to fix it.
  • Ernie Lohrenz Dec 05, 2012
    I solved the problem by changing my router security from WAP/WAP2 to WEP
  • 2,072 Answers
The smart phone should work fine on any wireless router. Try going to wireless settings on the phone and if it has your network remember click and hold on your network and select forget network. This should clear out any thing cached about your network. Once that is done try re-connecting to your network and enter any password you may have.
Posted on Dec 03, 2012
Limited connectivity
Limited connectivity (this phrase occurs first inside the WIN 8 OS) means, that you have connection with your router already, but NOT to the internet. Pls. check, if you have access to internet from other computers or smartphone connected via the same router.
If so, sometimes a driver-update for your D-Link could be useful.
Check also, if other wireless adapters are working with the same frequency, this may disturb. Try to change the channel or change from 2,4 GHz to the 5 GHz Channels, if the router & your D-Link Adapter will support this.
I had the same problem with my WIN 8 - PC and I had to change the (wireless) radio-channel.
Aug 15, 2013 | D-Link D Link Dir 825 Xtreme Dual Band...
We have a couple of computers that will not connect properly if at all through my dir 815 router... up until a few days ago they worked relatively fine, and we have a few other computers and an xbox that...
Hi! have you check your wireless encryption methods does every machine support ex.wpa2? how about signal status is it fine? you can allso try to give ip addresses manually to make sure they are correct
Mar 10, 2011 | D-Link DIR-815 Xtreme N Wireless 802.11N...
I cannot connect my Wii to the internet via new D-Link Wireless N Dual Band Router DIR-815. How do I see if the wireless connection is enabled for connection?
Are you able to connect using a regular laptop? If so, your connection is fine.
I suggest you try Nintendo's Wireless Router Troubleshooting procedure here : http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterTroubleshooting.jsp
Hope this helped.
Please rate :)
Mar 02, 2011 | D-Link DIR-815 Xtreme N Wireless 802.11N...
I can not make my D Link DIR-615 work with Hughes HN9000 modem. The D Link is located at the PC and Hughes modem location so I can wire 1 PC but need the laptop to connect wireless. I tried both an...
If you connect Modem to your laptop, can you go online?
If you are able to go online like that then log onto www.hnetworking.com and we can take the remote access of your computer and try help you out.
Feb 28, 2011 | D-Link DIR-615 Wireless Router
Unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Jun 17, 2010 | D-Link DIR-825 Wireless QuadBand Router
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
Connect wireless g devices to D-Link 615 (wireless n) router
Try to able the WI-FI Protected Setup that you have in your router.
Make sure that the MAC filtering is OFF in your Network Filter under the Advanced tab.
Jan 23, 2009 | D-Link DIR-625 (790069292637) Wireless...
Router seems to drop connection frequently
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
Apr 11, 2008 | D-Link DIR-625 (790069292637) Wireless...
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
