Question about Garden
What is the points gap on a briggs & stratton engine model 326Y32
I need to know what the points should be gapped at? Bob O
4 Suggested Answers
  • 15 Answers
SOURCE: briggs and stratton lawnmower 4horse power engine needegap specs on coil and points
That's easy man! You will always hear, "You sir, need to gap this or that at EXACTLY .00071542 inches per square meter".
The actual "poor boy fix"-
Put your magneto back on there, and stick a business card from your wallet in between it and the rotor. Let the magneto pull itself to it, you center it, and give it just a hair of breathing room (to slide the card back out). Tighten 'er down, and you got it.
1.- If you can't pull the card out, it is too tight.
2.- If you pull the card out easily, too loose.
3.- JUST enough to pull it out, and have it drag just a bit on the way out is JUST ENOUGH!
Remember, on 4-strokes, they ARE forgiving, and can do miracles even if you try your best to destroy them.
Posted on May 30, 2009
rycgl
  • 1545 Answers
SOURCE: spark plug gap fpr a
Typical old Briggs flathead "L-Head" engines require about a .030" plug gap.
Posted on Jun 13, 2010
rycgl
  • 1545 Answers
SOURCE: What is the magneto gap for a 6HP Briggs &
Briggs lists it as .006 - .010 on this 6 HP L-head engine. The .010 width can easily be attained by using a standard sized business card as a feeler gauge (and it doesn't stick to the magnets in the flywheel). I double up the card, loosen the coil and let the magnets in the flywheel draw the pickup legs in until they press on the card, tighten up the retaining screws (threadlocker is optional) and your air gap is set.
http://www.smallenginesuppliers.com/html/engine-specs/briggs/common_specs_single_cyl_lhead_engines.pdf
Posted on Jun 10, 2011
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
What is spark plug gap on unidentified pressure washer?
Briggs & StrattonLearn how & where to find the right spark plug and a gap chart to guide you through ...are commonly used for walk behind lawn mowers and pressure washers.
Spark Plug Gap - Troy-Bilt
Nov 24, 2015 | Garden
BRIGGS AND STRATTON 550 SERIES
Identifying the Correct Spark Plug and Gap
What is the correct spark plug and gap for my engine?
Due to the variety of engine and equipment configurations, your best source for spark plug information is your engine or equipment Operator's Manual. However, the following general guidelines will get you pointed in the right direction.
This guide provides the common spark plug part numbers used in our L-Head and Overhead Valve engines. For information regarding the service/replacement of spark plugs, please visit our Servicing the spark plug FAQ. Please be aware that the size/shape of the spark plug varies depending on engine design.
Briggs & Stratton L-Head Engines
(also referred to as Flat Head or Side Valve Engines)
Sep 29, 2014 | Briggs & Stratton Garden
What is the gap between he condenser and the piont
The point gap on all Briggs and Stratton engines is .020 inch
Mar 16, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Need point gap setting for 8 hp Briggs and Stratton gas engine
If it is an older BS it will be .015 That was standard. In fact an old match box cover would work to set them if you could not find a guage
Oct 07, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Mar 21, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
