Question about Mitsubishi WD-65738 DLP TV
Mitsubihi WD-65738 no power, no lights. Is there a fuse I can check? Maybe by the plug?
TV was working yesterday afternoon. TV is bricked now. There is no power reaching the TV. No blinking lights, red, green or otherwise. There's gotta be a broken or blown fuse somewhere? Any clues before I try to disassemble? Thanks so much. ~Eric
  • 3 more comments
  • eric Dec 03, 2012
    Thanks for the reply. Will it look like a regular blown fuse? I'll go and try to disassemble tonight after work.
  • eric Dec 03, 2012
    Oops wrong link...
  • eric Dec 03, 2012
    This is what the local repair shop replied back when I emailed them the symptons... "The fuses are not visible, unplug the TV from the power strip and maybe try a different outlet. We have not seen a problem with capacitors on this model but anything is possible in the game of electronic repair. Thanks, Sara"
  • eric Dec 04, 2012
    tonight, i opened the back panel like SD Tech suggested and sure enough there is a blown fuse. it's a 125v 10amp fuse. problem is, Radio Shack doesn't carry any. Not sure where else to go to find the right fuse. might have to order online... ugh. hope this might help others.
  • eric Dec 05, 2012
    contacted a local tv repair shop and he said to come on by for the fuse as he should have one. he looked at the blown fuse and provided me with a 250v 10am fuse. i questioned him as the blown fuse was 125v. his reply was that 250v will not have an issue, something vaugly technical, and then that it will work. got home, replaced the fuse, screwed things back into place, and the tv started up. bad news though, found out that my ps3 hdmi port is shot. composite works though. thanks.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Follow the power cord inside to the power board--line fuse will be there--have fun and patience as a lot of screws to remove to get there---as seen from rear power board should be to far left side.
Posted on Dec 03, 2012
Testimonial: "Solution provided direction. Thanks for that. "
  • 1694 Answers
SOURCE: Mitsubishi WS65513 with blinking green light
Download Chris@ChrisAndNat.com .........T.
Posted on Nov 09, 2007
  • 179 Answers
SOURCE: Timer light blinking green/tv won't turn on
the wd 62327 doesn't have a DM module as it doesn't have the atsc tuner. are you sure you have a wd62327?
in a normal set
power:
Green Blink = μPC Initializing (after AC off/on) (1~2 sec)
get the error code by doing this: (and let me know)
Error Code Operational Check
Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The ” Power LED” flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is “34”, the LED will flash 3 times, pause, and then flash 4 times.
Posted on Nov 17, 2008
  • 67 Answers
SOURCE: TV start up green light comes on but blinks and then turns off.
You have a bad ballust
Posted on May 18, 2009
rylee_smith
  • 8619 Answers
SOURCE: MIT WD-62525 DLP TV blinking green light on front won't stop
Hi!
It means your TV needs to reset. Although you have reset it previously, now again reset the TV as per procedure given below:
Please press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green LED will flash quickly for about one minute. After the green LED stops flashing, turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button, may be lost; the changes you made previously, however, are not lost. Only those changes since the last power on may be lost when the system reset button is pressed. All other settings are retained.
TV Reset Menu
Read on-screen warnings before proceeding, as some user data or settings may be erased.
1. Press TV MENU and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV.
2. Select Reset System Defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
  • 927 Answers
SOURCE: green light continues to blink. TV does not power
Howdy,
Try these ;
1. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001.
2. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V).
The board is on the left hand side of TV from the back. It is standing up, in a silver box.
Good Luck, BIG IRISH.
Posted on Jan 04, 2010
I have wd 65738 Mitsubishi tv that has a problem can you help ME?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 17, 2016 | Mitsubishi WD-65738 DLP TV
I have replaced my bulb several times on my mitzu wd65738 dlp but this time is different....will not boot green light flashing constantly 2010 model
its bad capacitors in the power supply. Pretty common. The power board is available on eBay from what I have seen
Aug 29, 2015 | Mitsubishi WD-65738 DLP TV
I have a wd-65738 TV . Heard pop no picture with
That pop was probably a capacitor blowing up in the power supply. Could be another power component too. Get an estimate from a TV repair shop first to see if it's worth fixing or flat screen TV time.
Sep 07, 2014 | Televison & Video
No lights or power to the tv
Check and replace the main power supply regulator board to your Mitsubishi TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 13, 2014 | Mitsubishi Wd-65738 65-inch 3d Dlp Hdtv
65738 colors flickering after bulb replacement
check the colour wheel in the light engine most likely bearings are worn needs replacement and the colors will stabilize need to open the light engine and replace with a new one
Mar 08, 2013 | Mitsubishi WD-65738 DLP TV
Sound but no picture
did you do the self check for errors this set has? you can click the make a comment button and reply if you need help.
Dec 21, 2012 | Mitsubishi WD-65738 DLP TV
My Kenmore Tumble Action Front Loaders power will not turn on. It worked fine yesterday but now there is no power what could it be?
Hi from retired Englishman in SW France @ 167:37 Sat afternoon!
You need to check the socket it is plugged into first. Try another device- maybe a kettle- to see if there is power. If not then a trip/fuse has gone on your main supply panel.
If there is power at the socket the fuse in the plug (if there is a fuse) needs checking and ,if necessary, replacing.
Come back to me on email john.cross@aliceadsl.fr if neither of the above solutions identify the fault.
John C
Jan 29, 2011 | Kenmore 44102 Front Load Washer
I plug the Mitsubishi WD-52525 TV in and nothing happens. No indicator lights no humm. Power is not getting to it. I checked the lamp, it is ok and in place. Is there something I can do?
Check the fuse, there will be internal fuses (be aware of high voltages maybe present even when unplugged) check for signs of internal damage. If the TV is still under warranty do not remove the back of the TV, get in touch with the supplier. When in doubt take it to an expert for advice!
Dec 11, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubihi tv wd-52525will not Power On after plug power cord
These Units have had a lot of problems with bad capacitors all over the Main Chassis. Most of the repairs are fixed correctly by sending the Main Chassis to Mitsubishi for them to refurbish it. In order to do this a Qualified Mitsubishi Repair Facility would need to come out to your home and remove the Chassis and send it Mitsubishi. The repair cost normally runs around $800.00 to $900.00. I would all Mitsubishi and see if they would be willing to help with the repair cost. Their Customer Service # is 1800-332-2119.
They should also be able to get you in touch with a local Service who can help out.
I hope this helps,
Sky Assoc
Oct 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-65738 DLP TV Logo
352 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
