Question about Dometic Rooftop RV Air Conditioner
No fan or heat on gas furnace
Appears to be in controller 3106481 electric kit relays sometimes click as if on and off.
  • doug_k7evi
    doug_k7evi Dec 04, 2012
    i have trried exchanging funace boards, with no change. I have checked the voltages at the furnace and get strange results, it almost seems like both the control board in the AC unit and the furnace board are each locking the other out. These furnaces are not wired the same as the one in my Class C MH. I can not find schematics to assist my troubleshooting. I am a 35 year HVAC journeyman, but withoutprints I am at a standstill..
  • Mike Butler
    Mike Butler Feb 02, 2013
    4 wires from furnace normally, I -12v-, 1-12+, and 2 blue that go up to and back from thermostat. Simply joining those 2 blue together right at furnace connection after removing wires that run to thermostat from the blue wires, will confirm if furnace has the problem, or thermostat, provided wiring is good from furnace to thermostat.
  • Dometic Master
  • 6,674 Answers
Once you have confirmed 12vdc to connector at furnace, just remove wires to 2 blue from furnace and join the 2 blue together to see if furnace runs. That just by-passes thermostat. What is furnace in? 12 volt-dc, or maybe 120AC, with 24V transformer if park model or similar.
Posted on Jan 27, 2013
  • doug_k7evi
    doug_k7evi Jan 29, 2013
    I am on the road in the other motor home. I will check this out again when I get back. As wired, there are at lest 3 circuts wire with blue wires. I will have to figure which blue wires are the ones you are refering to. Are those two in the ceiling units (at the control box)?
  • Mike Butler
    Mike Butler Jan 31, 2013
    Normally you can check right at thermostat, or go directly to furnace. At the thermostat, usually you will find 2 wires in a separate wire harness, like telephone line , which come from furnace, then another bunch of wires from control box at ceiling. If you have the separate wires at thermostat, ( usually red & white, or black & white ) and simply remove from wires at thermostat and join the 2 together, which completes the circuit for furnace only. But, if at all in doubt or wires all clumped together and you get confused, go to furnace and look where wires connect to furnace. There you will usually see 2 blue wires. Take the 2 blue coming out of furnace and join those 2 together and give furnace a few seconds to start up. The 2 wires connected to those blue wires, should be the same as the 2 at thermostat. By joining the 2 blue after you remove the 2 that are connected to them, you are by-passing thermostat. If it runs, then stops when you pull those 2 blue apart, then all is well there.
I disconnected all the wires to the thermostat and the fan still keeps running.
The problem is with the contacts in the fan relay, not with the thermostat. If it is an older furnace, the relay should be an individual component and is replaceable. If it is a newer furnace, the fan relay will be incorporated into the control board and cannot be replaced. Both of those answers above pertain if the furnace is a natural gas or LP furnace.
If it is an electric furnace, the first stage sequencer could be stuck closed because typically the first stage heat brings on the fan.
Dec 01, 2015 | Heating & Cooling
We have a Coleman Electric Furnace Serial # AOL6042086, Model # AHP36C3XH21A and the fan runs constantly, will not shut off. We have replaced the thermostat and just replaced the control board. We h
I wish I was a furnace expert but I will give a push in the right direction. When a gas/electric fan runs it has two speeds. When you turn on the FAN ON switch it should run at the slower speed. If it doesn't turn on or turn off again when you turn it back you have a wiring problem or a thermostat problem. Make sure the thermostat is compatible with your unit and wired properly (on both ends). The other time the fan runs is "in session" when heat or cooling is applied to the system. It should run until the system finishes the cycle then a bit more (30 seconds or 1 minute) to blow the treated air completely through the ducts. If it doesn't stop then you may have a bad fan time delay or relay. Check parts for your model and various appliance repair site online.
Nov 25, 2014 | Coleman Mobile Modular Home Electric...
Honeywell thermostat will not work when put on automatic
Depends on what type of heat you have...if it is electric, it could be your thermostat (some electric heaters use contactors & rely on the thermostat to switch the fan on). Heat pumps also use the thermostat to switch the fan on in heat & cool mode. Most electric furnaces use a sequencer to switch the low speed of the fan whenever there is a call for heat. Gas furnaces use either a fan/limit controller (if the unit is older) OR a circuit board based on time (after the thermostat calls for heat). SO depending on the type of system you have, it could be a bad sequencer, controller, relay, thermostat, or control board. Hope that helps.
Dec 17, 2013 | Heating & Cooling
My honeywell thermostat will not let the fan blow if it's on automatic
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
The pole buiding 24 in hanging Dayton sometimes the blower comes on like after 5 minutes after everything else kicks in and sometimes like when its supposed to and sometimes not at all?? All the electric...
I'm not sure whether this is a gas unit or not. With many gas heaters, the blower comes on when the heat exchanger gets hot enough and goes off once the heat exchanger cools. Other things are happening before the blower goes on. The blower is normally controlled by a "fan control thermostat". This stat actuates the blower when the furnace is hot enough so that cold air is not being blown around and allows the blower to run until the furnace cools enough to get out the remaining heat after the flame shuts off but not so long to again allow cool air to blow around. If this fan control is malfunctioning, you will get erratic runs from the blower or the blower may not run at all or run long or continuously. The fan control is the first thing to check.
Gary
Jan 31, 2011 | Dayton Gas Furnace Heater
Electric furnace. Just replaced the controller board but no heat. The blower does come on when the thermostat gives the heat command and I was wondering if that means the relays to the furnace coils is...
On a Trane furnace the fan realy must energize before the electric strips will come on. On the thermastat. See if there is setting for electric heat. This will bring the fan on and the strips should come on. First just turn on your heat and and turn fan to on postion if it works you need to set tstat to electric heat mode. Most of the time there is sswitch in the back of the stat that says gas elec. Turn to electric. Rus
Oct 29, 2009 | Heating & Cooling
The fan does not turn on but the furnace does appear to heat uo
Try turning the fan on manually at the Thermostat by clicking "Fan On"...if thiis turns the fan on...leave it running and you will have heat till a Service Tech can come out....if if doesn't work you will req a Technician to have a look . Likely if the furnace is fairly new either the Relay , Circuit board relay or the motor itself is Defective.
Bill
Oct 15, 2009 | Pelonis Disc Furnace Heater
Dometic Rooftop RV Air Conditioner Logo
100 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
