Question about RTO Suburban Rv Water Heater Dsi Gas Valve Part 161109
Suburban hot water heater sw6p shooting out flames
My suburban sw6p hotwater heater in my travel trailer has issues. i replaced the pilot burner assembly because the pilot wouldnt light and after replacing it , i lit it and it lit great and stayed lit. seconds after switching it to on, the burner ignited and second after it did, it started shooting flames out and up the side of my rv. what is going on?
Just bought and replaces pilot light assembly and installed on our Suburban Hot waster heater at camp we can get pilot ,but when you go to put the gas on it goes right out? How to fix??
Posted on Aug 26, 2013
  • 3 Answers
Quit screwing around and shut gas off at tank valve and call a professional ASAP!!!!!!!!! This is a serious and quite dangerous situation. Fixya is full of people who think they know. This is a situation needing a hands on experienced professional,not a bunch of whining incompetent egocentric morons.
Posted on Feb 03, 2013
  • 61 Answers
SOURCE: the pilot on My atwood water heater will not stay
Did you make sure the connection between the thermocouple and the control is tight and that the tip of the thermocouple is in the flame?
Posted on Jun 28, 2010
gary1121
  • 332 Answers
SOURCE: I replace my thermal coupling. burner doesn't ignite
is the burner assembly sitting pronperly on it;s cradle,, this will put it at just the right distance for it to ignite,,
Posted on Jun 21, 2009
Gort007
  • 1187 Answers
SOURCE: Atwood water heater - pilot light and flame malfunction
Michael,
The thermocouple sensor may not be in the best position to sense that the pilot is lit.
Adjust the thermocouple mount or simply bend the thermocouple "wire" so that the pilot flame is touching the tip.
Posted on Oct 13, 2009
  • 21 Answers
SOURCE: Water heater doesn't keep running
Sounds like youo have a problematic gas valve. But I would get a gasfitter to replace it. Not for the amatuer.
Posted on Nov 27, 2009
c7121
  • 160 Answers
SOURCE: The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Posted on Jan 09, 2010
Richmond gas hot water heater. After I light pilot and main burner why does it flame out in 15 seconds?
If you had to light the main burner manually, something is wrong. Once you light the pilot and it stays lit, the flame heats the thermocouple to open the gas valve and fire the main burner. Either or both of the components you replaced could be defective.
Sep 10, 2015 | Water Water Heaters
Sw6p suburban won't stay lit. My 6 gallon hot water heat on my 2007 camper won't stay lit, I go and light the pilot light and it lights but I turn the gas up and it blows out please help
the thermal couple is likely bad .
when you release does pilot stay lit or only as long as you hold the button .
if it stays lit then the thermal couple is good
if it only blows out as you turn on the heat then its draft issue.
May 09, 2015 | Water Water Heaters
SW4P Pilot Water Heater 3 Gallon Trailer Camper RV
These systems use "flame rectification" to sense or prove a flame or pilot flame exists thus it is safe to continue or transition to main burners if a system with a pilot light.
The AC spark is rectified to a DC signal by the flame as the AC current passes through the flame, the flame being a poor conductor only a small amount of DC signal is sent, in the milliamps, so it is not too difficult to interrupt the signal and disrupt the operation, it is doing this for safety.
What you can do is clean the surfaces where the pilot assembly meets the casing and burnish this path clean back to the ignition modules ground or burner ground terminal, there may be a flame sensor too, in this case clean it with 0000 steel wool it is just a ground rod and does not wear out but will build a film that can disrupt the weak DC signal.
Nov 04, 2013 | Suburban SW4P Pilot Water Heater 3 Gallon...
Hot water tank doesn't stay on
Suspect the thermocouple that senses that the pilot is lit. This device prevents the gas burner from coming on when if the pilot goes out, but if it's defective could cause the burner to shut down even when there is a pilot flame. Also check the position of the thermocouple in relation to the pilot flame. The tip of the thermocouple should be right in the middle pilot flame.
Oct 11, 2013 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
SW6D Suburban water heater shuts off prematurely.
Mar 03, 2013 | Suburban 6 Gallon Water Heater SW6D S/D -
I have a new Atwood G6A-7 water heater. The pilot lights fine but gas flow, when it turns on, is so strong it will blow the pilot out. Certain times, it sounds and looks like a mini fire ball going
Clean burner tube with proper brush, such as long spring type for bar-b-Q burner tube that are available at most hardware stores, and make sure you have new burner tube aligned properly (straight on) with brass orifice on gas control. Then be sure to adjust air shutter for nice blue flame, with little orange at tip. Do not give so much air that flame roars or jumps off the end of the burner tube. Too many people think more air, less fuel, but actually, when flame roaring and jumping off end of tube, the heat passes through faster and it takes longer to heat the water inside the tank. Like I said, only enough air to have quiet, steady blue flame. If your not giving it enough air, you'll see dark soot on trailer above water heater, which indicates burning too rich, need more air, or perhaps pilot is partially plugged. Pilot flame should also be blue, not yellow/orange. Small air intake hole on side of fitting just before pilot tube can get spider web, or debris in it as well. Use air to blow that out or a piece of wire like a paper-clip to clean inside that hole.
Dec 12, 2012 | Atwood G6A-7 G6A7 Manual Pilot 6 Gallon RV...
G4-7 atwood water heater lights great, heats water but when it cycles the pilot goes out no hot water
Sounds like the burner flame may be too strong (jumping out from burner tube) . Some people think the louder the better, but that is not correct. When burner shuts down like that, it has a tendency to snuff out pilot as well. Adjust your air shutter at burner so that the flame is a nice blue, or with just a hint of orange/yellow at the tip. Whatever setting that keeps the flame solid from burner tube, and not a big gap between tube and flame. Signs of soot (black) up the cover, or side of trailer means it's running too rich, and you've gone too far thus needs more air. Keeping the flame blue but still right out of the burner, actually heats better, is quieter, and should eliminate that pilot getting snuffed out. Pilot should also be a nice blue flame as well. There may be a problem with positioning of the burner tube as well, but doubtful if it has been running well in that position before. Let me know what happens.
May 10, 2010 | RTO Atwood Water Heater - 6 Gal LP
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Pilot light going out on whirlpool hotwater heater-Fgif403t Flam
Paint fumes can foul a thermocouple. If you have painted anywhere in the home this could be the issue otherwise its the gas valve.
Phil
Dec 08, 2008 | Water Heaters
RTO Suburban Rv Water Heater Dsi Gas Valve Part 161109 Logo
454 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
