Question about Boating
Have just bought a 1993 90hp v4 johnson and would like to know what type of oil to use in the oil resevior
    Problem Solver:
  • 5 Answers
Any tcw3 two stroke oil . I am a marine mechanic and I would recommend disconnecting the vro which is the oil injection. Just disconnect the oil line and then mix the oil in the gas 50 to 1. The vro is known for going out and taking your motor with it
Posted on Dec 03, 2012
Johnson V4 outboard #C0020325 I'd like to know the year and hp of this engine
call your local outboard dealer . they will help you figure it out
Sep 12, 2016 | Boating
How much oil to mix in 1976 115 v4 johnson ?
500millilitres to 25 litres or 1pint to 5gallons
Sep 01, 2014 | Boating
Johnson 115 V4 no push at low revs and no oil alarm at hi revs
Good Morning George,
First Thing To Do Is Use Pre Mixed Fuel Until This Problem Is Solved Or Engine Damage Could Be The Result.
Pre Mix Fuel -Oil Ratio Is 50:1
Have You Tried Priming The Oil With The Primer On The Oil Tank Supply Line?
Is The Oil Tank In The Boat Low On Oil?
Let Me Know If You Have Any Luck!
Cheers
Gordon
Apr 08, 2014 | Boating
Changing impeller on 90hp v4 johnson 2000
Remove Linkage Under Carburetor
Remove Bolts Securing Gear Box Remove Gear Box
Do Not Turn Shift Linkage
Remove Water Pump Housing
Fit New Impeller
Re Fit Gearbox Follow Procedure In Reverse
Mar 16, 2013 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
What type and weight of oil for johnson 28 horse outboard boat moter
Hi, mix the gas and oil at 50 to 1 and use two cycle outboard oil. Regards Phil.
Jun 29, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
93" 115 H V4 Johnson outboard motor will start and idle fine
your carburetors might be dirty blocking flow to the high speed jets causing it to bog down
Jun 29, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
Type of motor oil for a v4 2002 nissan altima
Should be in your owners manual... but generally 10W30 will do
Jan 18, 2009 | 2002 Nissan Altima
Boating Logo
181 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
