Question about Pool & Spa
Gas fireplace constant poofing sound? - Pool & Spa
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
Gas fireplace won't light
Your fireplace does have a pilot. It is either millivolt, where you manually light the pilot and use a remote or wall switch to light the logs
or is IPI where it still has a pilot light but the reote or wall switch lights the pilot first then the logs. The second version has a non-standing pilot. In either case, it sounds like a pilot assembly issue. When you "throw the switch", do you hear clicking inside the fireplace? If so and it does not light, you may have a pilot assembly issue. If there is no sound at all, then you may have a bigger issue with the control module. The only sure way to know which is the culprit is to have a certified technician come oput and examine your fireplace.
Feb 02, 2014 | White Mountain Hearth Empire Tahoe 36...
My Rinnai Flame fire classique ib30 will light, but as soon as i lift my finger it goes out, what is my solution??
From what you have describe, it sounds as if the Thermocouple on the Pilot Assembly has failed and needs to be replaced. Or if this is a Vent-free (vent-less or ductless) gas fireplace, the Oxygen Depletion Sensor (ODS) is clogged with dust, lint and/or pet hair. The ODS constantly monitors the room's oxygen level to make sure that there is enough O2 for safe combustion. The ODS is part of the pilot. The reason I mention this, is that your model does not appear in any of the Rinnai USA products. So, I don't know if it's a Direct Vent Gas Fireplace or a Vent-free Model. In any event, the Thermocouple can be an issue with both.
Hope this helps you troubleshoot the problem.
Apr 15, 2011 | Heating & Cooling
Fireplace starts right up but as soon as the flame is complete, you hear a poof and the flame goes out.
Sound like it could be flame sensor. This sensor is a rod hooked to a wire where the flame would hit it. Sometimes the sensor gets a coat of film on it. If it is this can clean with dollar bill. Other possibilities is if this is direct vent fireplace (sealed door) could be not getting enough combustion air, but if this just started doing this I wouldn't think it would be lack of combustion enless pipe got plugged somehow.
Jan 18, 2011 | Stoves Heating & Cooling
Help troubleshooting an FMI GL-850E Gas Fireplace
It sounds like the Ignition Control Module went out, as I've heard the vibrating noise you speak of just before the module "dies." You most likely have the gray Robertshaw control module box located under the fireplace connecting the power to the gas valve. You will need to have a Certified Gas Fireplace Specialist look into this issue and replace, if necessary.
Dec 07, 2009 | Heating & Cooling
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Propane furnace "POOFS" several times when starting heat cycle
Sounds as the regulator is not operating correctly (possibly the control board)
Mar 12, 2009 | Dometic Rooftop RV Air Conditioner
Oven makes poofing sound when in use
hi. thanks for the question .Yes the igniter is at fault here. replace it. thanks the appliance doc
Oct 02, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven makes a poof noise when turning it on.
HI thanks for your question. the poof you hear is the gas sorta igniting because of a failing bake igniter. i would replace it thanks if you need help don't hesitate. thanks.
Aug 08, 2008 | GE Profile JGSP48 Gas Kitchen Range
Sideburner for Thermos Stainless Steel Gas Grill (Mod # 461262006)
It sounds like the orifice is bad. An orifice is a small metal part that has a small hole in it. This regulates the gas coming out to the burner. It is at the tip of the pipe that brings gas to the burners, before the flame. I don't know what the hell the garggley noise is. Unless the bottle is upside down, and you are getting liquid, I don't know.
Mar 02, 2008 | Thermos Stainless Steel Gas Grill
Pool & Spa Logo
24 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
