Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Can not get I pod touch to work to connect on the WiFi with actiontec gt701wg
  • 3,606 Answers
Hello download the user manual here:
http://www.actiontec.com/support/product_details.php?pid=40&typ=doc
And follow the setup instructions.
Good luck
Posted on Dec 03, 2012
3 Suggested Answers
  • 5 Answers
SOURCE: actiontec GT701WG ROUTER
If you cannot connect to the router through 192.168.0.1, do a harware reset - I think there is a button in bach and use the factory default user/password. Then just disable the wireless in setup, advanced, wirless settigs - click Wireless Off radio button. And change the password.
Posted on Apr 17, 2008
  • 258 Answers
SOURCE: changing mtu settings
From a wired or wirelessly connected device do the following:-
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the Default Gateway value is the IP Address of your modem/router
usually 192.168.0.1, 192.168.1.1 or 192.168.1.254
6. Note this value down
7. Click OK
8. Click OK or Close
9. Now open Internet Explorer
10. Enter http:// followed by your gateway address noted in 6. above
e.g. http://192.168.0.1
11. You will now have to enter a username and password
If the box has the username and password completed, then click OK
If there is no value for username try "admin" and for the password try one of the following "password", "admin",
Also try nothing for the username and "admin" for the password
Sometimes the value for these are written on the underneath of the router
On the left look for the WAN or WAN Setup in there should be a vlaue for the MTU
overtype in your new value and click "Save" or "Apply"
Posted on Feb 09, 2009
Tip
I went to the actiontec router utility website. There is no item Beacon setting...
To boost up the performance of the wireless connection try the following.
  • Open the setup page of the Router / Modem.
  • Click Wireless and under wireless click Advanced Wireless Settings.
  • In there, change the Beacon Interval to 50.
  • Change the Fragmentation Threshold to 2304.
  • And change the RTS Threshold to 2304.
  • Save the settings. Turn OFF the router. Turn it back ON after 20 seconds.
  • It'll work.
More information on Wireless Security, click here.
For updated information on firmwares, click here.
Courtesy : http://linksysfirmwares.googlepages.com
on Feb 16, 2009 | Linksys Wireless-G WRT54G Router
Hello. I bought this modem with wi fi ,dsl router. How to set it to use this modem as a router.I want to connect my pc with lan cord & use wifi connection with my laptop and phones.
Turn DSL-router off.
Turn Actiontec off.
Turn computer off.
Connect:
* telephone-port in wall <--- 4-pin telephone wire --> DSL router
* Ethernet port on DSL-router <-- Ethernet cable --> WAN port on router
* One of the LAN ports on router <-- Ethernet cable --> network-port on your computer.
Turn DSL-router on, and wait for it to fully load, i.e., pattern of lamps becomes repeatable.
Turn Actiontec on, and wait for it to fully load, i.e., pattern of lamps becomes repeatable.
Turn computer on, and boot it.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway....192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you saw)
Login to your router
Configure the wireless adapter inside the router
(enter an SSID, choose 'WPA' encryption, enter a password)
Disconnect the Ethernet cable from your computer
Click "View Available Wireless Networks",
and select the SSID that you provided.
Enter the password that you provided.
Oct 21, 2010 | Actiontec GT701WG Router (actiongt701wg)
Trying to change from actiontec gt701 to actiontec gt701-wg. after new modem is hooked up, internet light stays red. switched by to old modem and all is fine. anyone know why internet light stayed red?
The reason why your internet light is red for the actiontec gt701-wg is because it is not yet configure. You need to access the gui of this router. enter the username and password for your internet connection. You can contact your ISP provider so they can walk you through for the steps on how to configure your new router.
The old router has green light because it was already configured by your ISP provider.
Apr 08, 2010 | Actiontec GT701WG Router (actiongt701wg)
Connecting printer to Actiontec GT704WG
Well the printer will have to have a eathernet plug on it to make it a networked printer and when you install it you will tell it through the network. I hope this would help you out. Do not for get to rate this solusion.
Jan 04, 2009 | Actiontec (GT701WG) Wireless Router
Connecting printer to Actiontec WG704WG
Yes it cn as long as the printer has an eathernet port on it. You would then need to install it through the network when seting it up on both computers. I hope this helps you. Also do not for get to vote for this solusion.
Actiontec GT701WG ROUTER
Jan 30, 2008 | Actiontec GT701WG Router (actiongt701wg)
Wireless light is green but i don't receive any signal on my laptop?
Check to see if the SSID is being broadcast. That could probably you be your problem.
Thanks,
Jan 02, 2008 | Actiontec GT701WG Router (actiongt701wg)
Actiontec gt701-wg Installation
You can use USB instead of Ethernet port but its not a common practise. Leave it empty then.
Dec 03, 2007 | Actiontec GT701WG Router (actiongt701wg)
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
