Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Whirlpool gold door falls open during cycle
Pretty sure my 4 year old nephew was jumping on the door while it was open. Door now only stays shut with duct tape and still mostly falls open during the cycle (especially heavy loads.) What do I need to fix in order to keep that door closed and dry my laundry?
  • cmh_p Jan 14, 2009
    I ended up buying a heavy duty magnet (rated for 100 + pounds) and that is working perfectly.
    New Friend:
  • 88 Answers
You can probably get away with getting just hinges for the door if it is not bent also check the latch if it doesn't look broken the just go for the hinges.
Posted on Jan 11, 2009
I have a quiet partner ii the soap dispenser door will not stay shut, how cab I fix it?
I have the same dishwasher, and have a problem with it shutting when soap cakes up on it. Have you tried scraping the latch door area? Once I cleaned out all the scale it shut better and when I close it, I push gently on the door and help the latch shut. It still opens fine during the cycle and the soap is gone.
Oct 11, 2015 | Whirlpool Dishwashers
My whirlpool duet washer stops towards the end of the cycle and flashes 6 then F. The door stays locked and the washer beeps. It has happened before, the machine is about 6 years old, how can I fix
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Feb 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer was out of balance and almost fell over during the spin cycle. The washer was shaking and the front door came open during the spin cycle. Now the front door will not latch and stay...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cold storage door will not stay shut
all of the refrigerator has a spring if there has no spring it will not open and close!
Apr 14, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
Dishwasher is leaking
Gasket probably became dislodged, replace door gaskets, at 4 years old I would replace the gaskets, they are not expensive.
Feb 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Have Whirlpool dishwasher Gold Series, Model GU9805CGB1 which stops part way through wash cycle with the led indicator blinks on the normal cycle.....if we ope nthe door and shut continues until part...
sounds like the door is losing contact with the door switch, first thing i would check is the door strike.Metal strike plate located on the tub itself that the door latch catches as it closes. its a spring metal striker, i would try bending it down a little bit to ensure better contact with the switches inside the door itself . next id open the control panel and check to make sure your door switches are secured well, wires are tight.
Mar 22, 2008 | Dishwashers
Whirlpool Gold Mod GU2500XTPQ1
sound like a low water level and or pressure issue. Start machine on normal cycle after filling open door and ck water level. should be up toJUST below heater assy.. assumiong htats good set hte wash arms to a set positon so you can watch for rotation. close the door adn after a few secs open rapidly and look for middle arm to be spinning, even the top 3rd row arm if present, should be spinning spinning . if not its possible that the motor/sumo assy is blocked w/ foriegn debris. remove the lower spray arm (hold the nut and spin arm)then remove 4 or 5 torx 15 screws. probly pretty glogged under there. if not id look into replacing motor sump assy/seals worn and not throwing water where it should go
Mar 03, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
94 people viewed this question
Dan Webster
Dan Webster
Sal De
