Question about Samsung Computers & Internet
Samsung pico fuse - Samsung Computers & Internet
  • Samsung Master
  • 1,684 Answers
What size pico fuse do you need? Or what board does it go on? We nned more information that just Samsung please.
Posted on Dec 04, 2012
  • odra_noel_86
    odra_noel_86 Dec 05, 2012
    it's from an inverter for the monitor samsung 940n, the model is IP-35135B and I removed the pico fuse. It is a 3A LF pico fuse.I tried it with a multimeter and unfortunately I have seen that the current does not pass. But rather how these pico fuse? normally switch the current or only at a certain current?
  • Buddy Mcsparrin Dec 06, 2012
    That fuse is available here:http://www.ccl-la.com/catalog/product_in...
Wher is fuse fd102s located
check fuse FD802A on the power supply board it is also feeding the -30 volt line. FD102S is on the convergence board 3.5 amp pico fuse cb6844a9-6247-49fc-a85b-fbc69d68a3ea.jpg
Jun 25, 2014 | Samsung HCM5525W 55" Rear Projection...
I have a Samsung Rear Projection TV with an HDTV 1080i Monitor. I know the convergence is messed up because the blue would not move when I tried to adjust it on the menu. So, then I tried to make it
You will need to replace both convergence Ics and the pico fuses that blow when the Ics fail. You can get the replacement Ics and pico fuses from www.tvreairworld.com they also provide free tech support to help you install them
Oct 27, 2012 | Samsung HC-P4752W 47" Rear Projection...
Please tell me where the fuse box is and the mother board
one fuse is located directly where the power board goes--set has as many as 6 other fuses inside in different areas--they are pico fuses which means not glass or fuse like in appearance.
Set dead with or without power light?
Apr 09, 2012 | Samsung HCN4226W 42" Rear Projection...
Bought a convergence repair kit for my Samsung HCP-4752W DLP...ICs are replaced and I'm ready to refit the board back in the unit...the kit came with two 3 amp pico fuses...I can not see any similar...
Pico Fuses are either Green or Yellow ,they are in many different circuits near STKs,and Startup Power Supply boards.
Encompass Parts Distribution sells Parts and Boards for this Model.
Most of the time their is 2 resistors that need to be replaced 3.9ohms located in front of ICs.
First just replace the ICs ,you might not need to do anything else.
Jan 22, 2011 | Samsung HC-P4752W 47" Rear Projection...
Samsung pcl5414r power resistors and pico fuses??
Hi again and welcome back to FixYa,
Appreciate the direct "Ask Me'.
Based on your original post, only the STK ICs were replaced. Presumably 392-040, the surrounding resistors and pico fuses could very well have been affected as well. Depending on the board revision (pls confirm location numbering on the actual board), the resistors could be:
RZ104 -RZ106 - 270 Ohm 1/2watt
RZ133-RZ135 - 27K Ohm 1/16 watt
RZ136 & RZ138 - 3.3K Ohm 1/8 watt
RZ146 and RZ147 - 3.9 Ohm 2 watt
RZ148 and RZ149 - 150 Ohm 2 watt
while the pico fuses would look like the image below.
Good luck and Thank you for using FixYa.
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Samsung hdtv projection has red double vision
your convergence isn't working this is done with the stk chips 3 look for a blown pico fuse or regular fuse a blown fuse will lead you to the faulty chip, replace all faulty components in the circuit,
cheers
Dec 26, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung pcl5415rb convergence problems
If you bought a kit from sites such as TvRepairKits.com go back and ask for help. If you bought the parts over the internet without instructions you have two common problems...1) Bad/Fake chips... or 2) You did the repair wrong - because you lack proper instrucitons.
Pico fuses - yes - they can be one of many secondary reasons convergence is not fixed on Samsung models.
Nov 13, 2008 | Samsung PCL5415RB 54" Rear Projection...
Pico fuse
It's on the T-con board itself at location Cp1 which you will find printed on the board itself.. The fuse is a tiny s/m (surface mount fuse but you can use a pico fuse of same value. According to schematics it's a 1.5a fuse. Simply solder one across the s/m fuse and if it opens then change the board. Samsung p/n# Bn81-01286a
To test the fuse use a VU meter set to continuity.
Pico fuses are readily available at almost any electronics supply outlet. I get mine from ACME Sales in Florida (least expensive) but even your local Radio Shack might sell them...
Bill
Sep 04, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung HCN4226 Convergence IC Problem.
The problem is likely to be the digital convergence board that generates the convergence signal that is amplified by the output ICs.
Jun 22, 2008 | Samsung HC-R4755W 47" HDTV
Pico/ Resistors what are these??
Pico means small and these look like little small resistors, but don't have stripes like resistors, just part numbers. They should measure as a dead short and be in the immediate vicinity of the STK's
Jan 03, 2008 | Samsung HCN5527W 55" Rear Projection...
Computers & Internet Logo
305 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
