Question about Husqvarna Snowblower 414cc 18.0 TP OHV ES 30 961930073 1830HV
Doesn't engage into reverse, in forward it will go a few feet slow than pick up speed
Putting into reverse it seem like it wants to go but just no power to do it, motor runs fine something just not engaging
SOURCE: pto willl not engage
Hi mate, Although my trade is repairing turfcare machinery, I have no experience with this model, so I will try my best. Firstly, the clicking you hear will probably be the electric clutch engaging/dissengaging. Firstly, see if you can get the clicking with engine off, keyswitch in first position/on/lights on dash. You may have to place something heavy on the seat and have traction pedal in neutral. MAKE SURE YOU DO NOT ENGAGE THE STARTER MOTOR/START THE ENGINE THROUGHT THIS!
Now have a look under the footwell on top of the deck and try to determine where the clicking is coming from, there will be a clutch there somewhere joining the engine drive pulley to a deck pulley, Also at this point check that both belts are on and with the ENGINE OFF! spin the blade/blades with your hand and ensure that the deck belts are not slipping on the deck pulleys. If they are you will need to establish where the tensioning system is. (Sorry i know pretty vague)
Back to the Clutch, once you establish where it is, engage the blades ENGINE OFF! and you should feel a greater resistance turning the blades as you are now turning the engine as well, beware though, it is theoretically possible to start the engine by doing this, but you will almost certainly not be able to spin the blades that quickly by hand.
If it is clicking to engage but not turning the engine pulley when spinning the blades by hand, then try tapping the clutch lightly as it may not be fully dissengaging.
I would put money on it being either one of the belts coming off/snapping, the blades jamming or the clutch not engaging fully.
If you find that the clicking is not the clutch engaging and its actually getting no power to the clutch then you need to go back to the pto switch and go through all safety switches! (good luck, it usually ends up with me bypassing them or running a new cable to the switch,then, smoke, shouting, swearing etc etc!) Either not advisable.
In doing all this you should have been able to have determined the problem be it one that I have mentioned or another.
Hope this helps,
Chris.
Posted on May 30, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 420 Answers
SOURCE: Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
Posted on May 27, 2010
Biggdex35
  • 333 Answers
SOURCE: husquvarna hydrostatic mower won't move
Sounds like the belt going to the hydrostate broke. Or a key on one of the pulleys broke. The belt runs inside of the frame and is hard to see.
Posted on Jul 12, 2010
Testimonial: "THANKS SO MUCH. VERY HELPFUL."
SOURCE: I have stored my lawn mower since September - it
Rally tractor mower won`t start. Battery fully charged but nothing when turn key
Posted on Mar 16, 2011
My old Jacobsen Imperial 26 only goes a few feet and the drive stops. I put it in reverse to break the locked wheels free. It will then go forward for a few feet, then I have to repeat this procedure
Sounds like you may have too much slack in the drive Chain. Pull the bottom cover off and look. Usually there is a way to move the shafts to tighten the chain.
Feb 06, 2015 | Garden
2010 polaris sportsman 300 awd is not in awd in reverse is this normal or do I have a problem
Push the yellow button on the hand area. On some models, it engages 4 wheel drive
Jan 06, 2014 | Polaris ATV
Craftsman GT6000 54" stalls while mowing
Sounds like you have dulled the blades with your aggressive hill cutting
Aug 12, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
96 ROVER DISC. Has strong reverse - won't engage any forward gears. Fluid seems full even when warm.
Make sure the 4wd shifter is in correct position and hasn't slipped out of correct spot to get you moving forward.
Mar 27, 2013 | 1995 Land Rover Discovery
Mower starts but drives very slow or not at all, but fine in reverse.
If this is a hydro unit and it drives fine in reverse then there is no reason why it will not do the same in forward, there is a variable swash plate in the unit to change from reverse to forward, i would be looking at the linkages, if there is not enough movement it will greatly affect speed, check also that the pulley on top of the hydro is tigh and has not stripped the splines.
Apr 14, 2012 | Garden
When i start the truck its fine when i put it in forward gears it doesnt want to move for a couple seconds the it catchs and starts to move same in reverse just slugish could it be the torque conveter ot...
Try putting it in neutral before putting it in drive. the pump doesn't engage in park and sometimes the fluid leaks back out of the torque converter. I have the same problem in my 2004 Ram 3500 and 70 Challenger.
Jun 05, 2011 | 1996 Dodge Ram 1500 Club Cab
Shoprider deluxe te-889af loses power when reversing
I think that this is usual to have a slower reverse speed for safety.But on your shoprider you should have 4mph and 8mph ,usually if you are at 8mph it won`t reverse at that speed, you have to go to 4mph ,look infront of you there is a dial this controls the speed that you go forward and reverse.If reverse speed needs to be increased turn the dial up,but don`t forget this also increases forwards.
Jan 14, 2009 | Shoprider Sprinter 889B-4 Scooter by
No power when drive is engaged
Hi
Check your drive belt and the tensioner pulley that holds tension on the drive belt. Its possible for the tensioner pulley to be sticking and not putting enough pressure on the drive belt causing it to slip.
Grab hold of that tensioner pully and make sure it moves in and out freely against the drive belt.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna Snowblower 414cc 18.0 TP OHV ES 30 961930073 1830HV Logo
51 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
