Question about HP DeskJet 960c InkJet Printer
I need to set the printer to print 51/2 x 8" paper
    Problem Solver:
  • 10 Answers
Visit this link : http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd08618&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN. And you will find your solution there....sodeep
Posted on Mar 21, 2009
How to clear error 51
Check type of printer it may need cartridge or special paper
roll to print.
Nov 14, 2013 | Brother MFC-640CW All-In-One InkJet...
What is "unable to print 51"
Error code 51 means that there is due to wate ink pads which are full. You'll need to clean these pads to remove the error message. Also check for any small bits of paper stuck under the printhead (check under the carriage). Try removing the cartridges and check for any bits of paper. Before doing any of the above said things please turn off the printer and unplug it from power source.
If this doesn't work then its an issue with the purge unit. The purge unit is responsible for carriage movement on the chrome bar.
Please tell me if you need further assistance,
Nov 25, 2010 | Brother MultiFunction Center MFC-440CN...
Unable to print or copy, see troubleshooting 51
The error means you have a paper jam or one of the sensors is incorrectly reading a paper jam. Unplug the unit and check all areas for a jam. Remove the back Jam Clear Cover and check inside there. Remove the Paper Tray and check that area and check if the PE actuator is in place behind the paper tray. Lift the scanner flatbed unit and check inside the print carriage area. Look for scraps of paper at the sides of the platen. These scraps that may be soaked with ink and difficult to see. You may need to move the print head to see both sides.
If the PE actuator is missing, contact Brother for a replacement. Put in the replacement if needed.
Close the scanner unit, replace the clear jam cover (put it on correctly) and replace the paper tray. Plug in and turn on the printer and see if the message clears. If it doesn't clear, access the Ink or Ink Management menu (either directly by a single key or through the menus). Do a test print for Print Quality (Color). If the quality is good, press 1, the up arrow or + key to select Yes. Then press the Stop/Exit button. If the print quality is poor, clean the print head.
If the jam message occurs again, check for more scraps of paper inside the unit as above. Make sure your paper meets the specifications for the printer and isn't getting excessively humid. (Paper will pick up moisture from the atmosphere so keep only the needed amount in open reams or the paper tray.) Fan the paper in the tray and then return it to the paper tray. Make sure the paper is flat in the tray and that the guides are just touching the edge of the paper.
If it still doesn't clear, the unit needs service.
I hope this helps.
Sep 14, 2010 | Brother MFC 240C All-In-One InkJet Printer
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
Printer error UNABLE TO PRINT 51
51 says the cleaning assembly on the right is not movig properly, the first check is for a paper wad caught on the right where the printhead parks. If you can pull the printhead out of the corner, look inside for paper scraps. If the printhead is stuck on the right, don't force it, but unplug the printer when the head is out of the corner to check.
Feb 01, 2010 | Brother MFC-465CN InkJet Printer
Paper size settings
Thanks for your reply,
Here are the things you might want to try:
1. Go to Printers and Faxes in your Control Panel
2. Right click on the white area and select SERVER PROPERTIES
3. From the FORMS tab, check the box that says CREATE A NEW FORM
4. Enter a Form Name
5. Manually input the specific paper size you want.
6. Press OK
7. To verify if you are successful in creating a new form, right click on the icon of your LX and select Printing Preferences
8. Click on the ADVANCE Button
9. Check under PAPER SIZE
That's supposed to be all, however take note that if the newly created paper size is not showing up, its possible that the paper size is not supported.
Hope this will help
Mar 16, 2009 | Epson LX-300+ II Matrix Printer
Brother 440cn error 51
Uninstall the printer.
Reboot.
Install printer and try to print a test page.
Nov 22, 2008 | Brother MFC-440CN InkJet Printer
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Clean unable 51
Ok Please follow this link and it has your answer.
Please rate me when it was a FIXYA
May 03, 2008 | Brother Multi-Function Center MFC-240C...
Postcards causing printer jam
I think the card is too heavy or too thick for the machine as when it prints it has to turn the paper. If the card is too rigid it is unable to bend causing a paper jam. Suggestion is to try a less grade of card.
Thanks J
Dec 15, 2007 | HP DeskJet 5650 InkJet Printer
HP DeskJet 960c InkJet Printer Logo
54 people viewed this question
Ben Johnson
