Question about Toshiba 50HP66 50 in. Plasma Television
I nave a toshiba 55.in plasma tv model 50hp no picture just sound
I was thinking it may be the video board, please advice thankyou.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Problem with a Plasma is it can be:
Power supply issue in set.
Almost any board pulling voltages down.
Main signal board that controls everything bad.
worst case is display panel (entire front screen unit) bad.
Best advice is get it to a shop and get an estimate.
Posted on Dec 03, 2012
  • 148 Answers
SOURCE: I have a 3 years old 42
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ...If this helped (or not )please rate,thank you!2c66514.jpg
Posted on Feb 03, 2010
  • 3 Answers
SOURCE: No picture
You have a bad Y sustain or bad Z sustain! End of story! Please feel free to give me a call if you would like more info!
I'll help u fix your TV!
Ask for Dave @ 1-503-432-9904 or message me @ pleasefixitdave@yahoo.com
Posted on Sep 11, 2009
  • 6 Answers
SOURCE: 42" Toshiba Plasma TV no picture or sound
My experience with 42" plasma tv's with no picture or sound was a missing power supply voltage. On the power supply board check voltages on the plug. The voltages should be marked on the board,
Posted on Mar 02, 2008
  • 50 Answers
SOURCE: Toshiba 42" plasma tv 42HP66. All of a sudden, no picture.
Hello, You may have a bad power supply! Its hard to say! I need more info! please feel free to call or message me if you would like more help with your TV!
Thank you!
Dave
1-503-432-9904
Posted on Aug 26, 2009
SOURCE: My 32HL57 model tv has sound but no picture?
en francais
le modul est fixé sur l'ecran
sur ce modul verifier si vous avez 3.3 volt (trois regulatuer avec un test point) si vous n'avez pas 3.3 verifier les deux fusibles F1 et F2
F1 devrais etre ouvert ....
bonne tv ;)
module is fixed on the screen
this modul check if you have 3.3 volts (three regulatuer with a test point) if you do not have 3.3 Check both fuses F1 and F2
F1 should be open ....
good tv;)
Posted on Oct 05, 2009
Tv no picture but sound
hi, mate,
when you reparing you have to do meassurement not just swap. you waste your too much money like this! how much va, vs, vsc..especially vsc?
Feb 01, 2014 | Televison & Video
I have a toshiba 50hp plasma t.v. and it made a popping sound and the picture went dark and somewhAT FUZZY. CAN STILL SEE PICTURE BUT BAD COLOR AND ITS DARK. IS THIS ANN EASY FIX OR IS IT NOW TRASH?
I am ready to bet my lunch that you have a bad ZSUS board.
There is less than 1% chance I would go hungry and that's with around of thousand of such repairs on my back.
This is the link for what you need:
http://www.coppelltvrepair.com/p/263/75003043-zsus-board-for-toshiba-50hp66-repair-service
Aug 03, 2013 | Toshiba 50HP66 50 in. Plasma Television
Hitachi 55" plasma: No picture, no sound
Perhaps the seller forgot to mention the basic power supply problems and who knows what else
Jun 12, 2013 | Hitachi 55HDS69 55 in. Plasma Television
Have no picture just sound
Your video board is defective.The sound indicates your power supply is working.Often the inputs are to blame and no signal is getting through.If a picture appears on TV mode then the problem is on the inputs-it could be loose and needs resoldering the terminals.But if it all happens on all functions then you need to replace the video board.In comes in between the input board processor and the video processor(the board that is terminated to the Plasma screen).
Dec 05, 2010 | Hitachi 55HDS69 55 in. Plasma Television
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
No picture on my Toshiba 42HP66 plasma tv.
I too have this problem with no help from hh Gregg, where I bought the tv, and no help from Toshiba. I resorted to calling the BBB and complaining about the defective workmanship. I took the tv, which is less than 2 years old, apart and found the y-sus board, behind the y-sus board is a foam rubber spacer to seperate the circut board from the backside of the screen. I think this pad is designed to prevent heat buildup in the y-sus board. The pad itself is held on by glue and that glue melted causing the y-sus board to short out. I noticed this after finding a tacky substance behind the board. The heat from the plasma screen melted this and also the pad itself. Toshiba claims no resposibility because the tv was out of warranty. Thanks Toshiba.
Jan 22, 2009 | Televison & Video
Hitachi 55 inch plasma tv
what type of connector are you using fo your xbox? I think
Dec 13, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi 55 inch plasma TV, sound but no picture What board is blown out?... 3000 dollar tv two years old.
Please update this with the model number. Each model has unique boards. Also, are there any other symptoms or just no picture?
Thanks,
Dan
Nov 26, 2008 | Televison & Video
Mar 01, 2008 | Toshiba 42WP27 42 in. Plasma Television
Toshiba 50HP66 50 in. Plasma Television Logo
320 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
