Question about Estate TS25AFXK Side by Side Refrigerator
Removing front panel by water estate TS25AF refrigerator
Is there screws holding the panel by the water and ice area?
    Top Expert:
  • Estate Master
  • 9,472 Answers
It just snaps in place.
Posted on Dec 03, 2012
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: Food and drinks freezing in my refrigerator. How do I adjust?
Inside your refrigerator is a control on left side of the panel. Try to adjust there and try to close the dampers near the lower drawer bins. If that don't work change the temp a little higher in the fresh food compartment. But closing the ducts should do the thing. Let me know, Thanks Sea Breeze
#27 below in pic try ajusting the air coming into fresh food compartment.
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Posted on Apr 21, 2009
Can't find the drain on the freezer side of a ts25af estate refrigerator
found this..
https://www.youtube.com/watch?v=H_DKNtgd5vI
If you have a Whirlpool, Maytag, KitchenAid, Roper, Estate or Kenmore defrostable refrigerator, that is leaking at its bottom and building up ice, you may have a plugged bottom drain line. This video will show you how to unclog this line.
hope it helps.
Jan 21, 2018 | Estate Refrigerators
How to reinsert ice maker into 1992 Model TS25AF
You unscrew the srews holding the ice maker into the refrigerator. There may be 2 or 3. Then you should unplug any electrical connection, and saw on another site you need to remove the arm and install it onto the new ice maker. Then replace the new ice maker into refrigerator. There should be a different piece that's actually connected to the water input and then sends the water into the Icemaker.
Aug 31, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an amana side by side model # JXD2252L. The ice maker is adding too much water at the beginning of the cycle and is dripping water into th ice bucket. It freezes and casues the ice dispenser to...
Adjusting Ice Maker Fill
Use a flat-head screwdriver to remove the screws on the ice maker's front access panel, and then remove the panel.
  • Locate the adjustment screw, located about mid-point on the side of the ice maker. Do not turn the crew more than one full turn in either direction.
  • Turn the screw clockwise ½ turn to decrease the water fill level.
  • Turn the screw counterclockwise ½ turn to increase the water fill level.
  • Close the access panel and restore the screws. Turn the refrigerator back on.
  • bobicehouse_20.jpg Look at mid point for adjusting screw
    Jul 10, 2011 | Amana ACD2232HR Side by Side Refrigerator
    Parts inside my ice maker in the door fell out cant figure out how to get the front panel off the ice and water maker
    Remove the top freezer door hinge cover and disconnect the plug there . This removes all power to the door so the refrig can still run while working on the dispensor . Use a butter knife slipped down between the lower portion of the dispensor cover and the main dispensor from the inside and press down . There are 2 plastic tabs holding the lower cover in place . After the lower portion is unclipped , lift upwards to remove the top portion . Disconnect the plug to the dispensor front . There are 3 or 4 screws holding the white " body " in place , so remove them and it should slide out a little ways to allow access to the inner workings .
    Jun 08, 2010 | Estate TS25AFXK Side by Side Refrigerator
    Is there a drain hole in the freezer area on whirlpool model # ET18LK?
    To get to it , remove the food from the freezer and remove the ice maker , if equipped , and remove the 2 screws holding the freezer bottom "panel" . Remove the 2 or 3 screws holding the rear freezer panel on , and remove the panel . About in the middle , under the coils , is the drain hole . If iced up , defrost the hole with a hair dryer until visible . Hot water will help defrost the hole . When water starts to flow , use a small piece of hose , inserted into the drain , and blow thru until clear . This will remove any debris built up in the unseen drain line .
    Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Ice maker OK but water will not work? Whirlpool Estate TS25AF
    hmmm, the only really way you will know if your water valve is working for the door is to jump it direct. unplug the machine get the valve out un do the line that goes to the door to the valve put a glass under the valve and jump it... if water then you have a door/control board issue.... no water than u need to replace water valve.
    Apr 26, 2009 | Refrigerators
    Apr 21, 2009 | Estate TS25AFXK Side by Side Refrigerator
    Water puddling in bottom of freezer which freezes
    Tool needed: Screw drive with the insert tips can be used to remove screws use the end of the screw driver with out a philips bit or flat tip inserted. Remove frozen food to camping coolers igloo ice chests or coleman ice chests or a freezer in your home . Remove all racks and baskets to expose movable panels at the inside back of the freezer compartment.
    Notice the 1/4" hex nuts remove the screws holding the panels at the back wall. Clear built up ice carefully. You now can take out the panels and expose the fan and cooling cool that creates the cold temperature on the freezer side.
    Near the bottom is an aluminum U shaped pan with a shallow funnel indentation at the bottom. Clear ice from the funnel pan and inside bottom carefully. Sharp objects break ice nicely and can pierce the interior surfaces . Look under the cooling coil and at the back wall is a screw holding this soft metal catch pan in place. Remove the screw and carefully tip and slid out the catch pan tray. You now have access to the drain hole that is frozen closed or clogged. Place a large towel in the bottom of the freezer area to catch water. Pour hot tap water a half cup at a time into the drain area. Do not use boiling water the plastic inside a refrigerator or freezer can not tolerate high temperature. I have melted a freezer compartment in a GE with a hair dryer. Remove the water with a clean reag and add more warm or hot water repeat until the drain allows water to flow. stop adding water or the evaporation pan under the refrigerator will over flow.
    Check the refrigerator about once a year for the freezeup problem or keep an eye on the bottom of the freezer looking for the build up of water frozen on the inside floor. The other solution get a new refrigerator.
    Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
    Estate TS25AFXK Side by Side Refrigerator Logo
    458 people viewed this question
    Top Estate Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    jasbo
    jasbo
    Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
