Question about Car Audio & Video
I have a lanzar sd32mu stereo its new when i took it out of box the wiring harness has a connector at the end where there should be just wiring usialy there is just wires this has a connector
  • 15,935 Answers
Looks as if you did not get a new unit.
The wires should look like this (top right side of picture) when new...
http://app.infopia.com/img/image/fp/VPID/1331418/img2/img.jpg
You have an aftermarket plug installed, which means it was in a vehicle already.
Need more help, just ask!
Posted on Jan 11, 2009
How to connect pioneer fh-x700bt to a 2004 ford explorer
You need to buy a wiring harness compatible with your vehicle. The wiring harness will connect to your vehicle OEM plug and the other end you need to splice it with the wire that came along with your car stereo.
Apr 16, 2014 | Pioneer FH-X700BT
Need to know how to connect the two wires socket in the back of my 2006 subaru impreza with manual transmission now i have a blinking check engine light
usually unplug wiring fromradio and plug one end of new harness into radio and the other into the original radio connector
Mar 27, 2014 | 2006 Subaru Impreza 2.5i
Dodge Neon'01 (Base model) streo upgrade enabling re-use oldWires
If you check at nearest auto parts stores, or car stereo stores, they will usually carry, the plug in adapters that you will need to simply plug in to your factory harness, and then wire to your new stereo. Makes for a nice easy, clean installation.
May 09, 2010 | Car Audio & Video
How to install An SD54MU Lanzar stereo
Hi if you go to a autoparts store such as auto zone they sell a universal plug for your vehicle you plug it in to the radio harness on dash and then match up the colors coming off the radio harness it comes with a diagram to help you.
Feb 01, 2010 | Car Audio & Video
Intaller Manual Lanzar SD32MU
output socket
hello, where can I get a output socket for my lanzar SD33MU, that is the socket that goes into the radio/dvd player, It is 18 pins.
With great regards Lody Alblas
Nov 30, 2009 | Lanzar SD32MU Car DVD Player
Lanzar SD32MU: how do you disable the video screen
ok here is the big secret. There should be a wire that goes to the parking break. In most after market radios, it is a brown wire. The way to get around this is to put that wire directly to ground. It will work at all times.
Nov 06, 2009 | Lanzar SD32MU Car DVD Player
I dont know how to wire it to my car stereo wires
Do yourself a favor and run to audio store or even autoparts store & get an adapter plug/harness, cost is a few bucks but well worth it. It plugs into factory harness & you wire your new stereo to it according to diagram with new system.
May 02, 2009 | 2001 Dodge Stratus
A new lanzar sd32mu car stereo
You need a factory wire harness for your car you can pick these up at bestbuy. The cord for the ebrake twist that to the ground wire its basically a safty thing so you can only work it while not driving. Hope this helps Good ratings help me out.. Have a good day.
Jan 11, 2009 | Car Audio & Video
I need to install a kenwood cd player into my 2001 ford explorer step by step
goto the auto parts store and purchase a pair of stereo keys, fascia adaptor and wiring harness (you may need to get fascia and harness from a car audio store or circuit city.)
Then use the stereo keys to remove the factory stereo. Push them into the small holes on the front of the stereo push them slightly outwards and pull to release the stereo. Unplug all the connectors from back keeping track of where they fall.
Insert wiring harness into the stock wiring
attach fascia in regards to its packaged instructions.
Place cage from new stereo into the hole in the dash using the tabs on cage to secure it,
Attach stereo to other end of new harness along with aerial (may need adaptor for this also depending on the new head unit.)
Insert stereo into new cage and voila nice new stereo.
Nov 27, 2008 | Kenwood Car Audio & Video
The wires for the stereo are cut
Yes this is not to bad to deal with.. make sure you use quality wire connectors so you don't have problems later with bad connections. you pretty much just have to match the colors from the harness in the car to the ones on your deck. If you don't want to cut off the harness connector on your deck just purchase one that you can connect to your deck and cut the wire ends on the other side of the adapter. The only wires you wont be able to match color for color is speaker wires... for these you will just have to hook them up temp. and test to see that they are connected to the proper speaker output. close.gif Read more >> Options >> answers-logo.gif
Aug 24, 2008 | 1991 Pontiac Sunbird
Car Audio & Video Logo
83 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
