Question about Gateway DX4200-09 PC Desktop
After shutting down numerous times un-announced my dx4200 shut down and will no longer power up
Would just shut down by itself all the time
  • Gateway Master
  • 2,072 Answers
Most probable causes
  • Bad power supply
  • Bad motherboard
Posted on Dec 03, 2012
  • 5 more comments
  • mike kohn Dec 03, 2012
    how do i know if it is the power supply?
  • Justin
    Justin Dec 03, 2012
    The "not powering on" is a good indicator. Replace the power supply and if it still doesn't come on then the motherboard is bad. Usually power issues are because the power supply is bad.
  • Justin
    Justin Dec 03, 2012
    If you really wanted to "test" the power supply unplug each connector and use a multi meter to test the voltage. If it isn't putting out the right voltage then you know it's bad.
    thanks man! I will try this
  • Justin
    Justin Dec 03, 2012
    Most techs won't even test a power supply because it is too much work. Molex and mini molex connectors have two different voltge pairs, 12v and 5v IDE has one 5v for the motor and one for logic.Sata has two pairs and the ATX motherboard 20 and 24 pin power connector has about 10 different pairs you would need to test. Plus most electronics retailers will allow you to return parts if they don't fix your problem. Power supplies are as cheap as $12 online.
    so does it have to be specific to my pc model? or will just about any one work?
  • Justin
    Justin Dec 03, 2012
    They are pretty universal.
4 Suggested Answers
nidostyle
  • 135 Answers
SOURCE: shut down when booting
if it enter in middle of loading Operating System then it is not Poser switch problem the is problem in your OS.
Try this
When bios appear press F8 key and choose "Known last good configuration " from the menu.
This may fix your problem.
Posted on Nov 27, 2008
support793
  • 81 Answers
SOURCE: Gateway profile all in one system shuts itself off
I just had a machine in the other day with the exact problem you describe. Don't know if this will help but they had a worm and when the anti-virus kicked in or they opened any type of online program like a broswer or email the computer would shut down.
Also hardware could be the issue. If its not the above issue could you tell us when the last time the heatsink was cleaned. What if anything your doing when it shuts down....
Posted on Mar 24, 2009
  • 6771 Answers
SOURCE: Gateway DX4200-09. Every couple
It will be one of two things, you may have a bad stick of ram, or hard drive issue. Before you power up the system remove one stick of ram, failing that! swap out the other, "remember to put the first one back" If the ram checks out, the next step is check the hard drive for a virus, "scan system" bad sectors on the hardware, "go into my computer, properties, select tools, and the check now button, this will check the volume for errors. If nothing shows up you will need a computer tech to take it further for deeper testing.
Posted on Mar 13, 2011
How to prevent my GT B5510 to shut down by itself ?
I had the same problem with my Samsung Galaxy after an upgrade. I tried numerous solutions. Nothing worked. Finally, I downloaded LOAD MONITOR [free] from the Play Store, fiddled with the settings a bit regarding the SOD [sleep of death=shutting down by itself], and it solved my problem. Hope it helps.
Apr 27, 2014 | Samsung GT B5510 Galaxy Pro Young Qwerty...
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
Ps3 just shut off by itself
The Fan could be faulty, I have had that problem with numerous devices, if the fan IS faulty, make sure you can get enough air for it to cool down
Nov 19, 2012 | Sony Playstation 3 (PS3) Console
IPad shuts down itself
It seems that you've already tried reset (holding the home and power buttons, right?) the iPad and it does not work.
So you may need to connect your iPad to your computer and do a factory restore using iTunes.
Check this: http://support.apple.com/kb/HT1414
Jul 18, 2012 | Apple iPad 32 GB WiFi Tablet PC
Hi FixYa folks, I have a Gateway DX4200-UB001A problem when ruuning in BOTH Vista Home Premium and now in Windows 7 Ultimate and giving me the same problem. When I put it in Sleep Mode, it won't come...
you are cold booting the pc always shut down normally when you shut down just useing button it will eventually corrupt the system I have several computers and never shut them off at all unless installing new hardware if you get a keyboard with the specific button just for the sleep mode this problem will clear up but if you shut down normal it will work rite
Jul 08, 2011 | Gateway DX4200-UB001A Desktop Computer
My gateway just won't start up
Try holding the power button for about 6 seconds until it shuts down. Typically, when the light is fading in and out it is in standby mode. If that doesn't work and even after unplugging it - you may have a bad power supply and need a new one (that's the unit that the power cord plugs into and has a fan that always spins).
Hope this helps! Rate my solution!
Jan 07, 2010 | Gateway DX4200-09 PC Desktop
Car stero doesn't come on
You have it wired wrong. With the fuse out it is like disconnecting the wire, thus removing the fault. Be glad it is shutting down. It is protecting itself from damage and electrical overstress. Trace the wire, my guess is it is a power wire that is grounding. Check all of your wiring again.
Feb 24, 2009 | Car Audio & Video
Gateway DX4200-09 PC Desktop Logo
80 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
