Question about Yamaha Full-Size Keyboard
I have a Clavinova CVP-301 whose right pedal just stopped working. Help anyone?
SOURCE: I have a clavinova CVP
If you go to Yamaha website,CVP 409 specs, it will tell you how to hook up each one of the interfaces (ie floppy, usb, external hd and mem stick) and this should apply to other models.
Posted on Dec 29, 2009
  • 10865 Answers
SOURCE: Yamaha Clavinova CVP 55 -
Hello. Most likely you will need to either clean the drive or replace it.
Posted on Sep 21, 2010
SOURCE: Can I replace the pedal unit to the Yamaha Clavinova CVP-75?
I can't solve the problem, but just wanted to sympathize because I have the same problem. My pedal is broken on my Yamaha Clavinova cvp85a. It worked wonderfully for years but finally it broke.
I'd be in the market for buying a new pedal or fixing the old one. But I've not found any suggestions in any of these forums for either solution.
Posted on Feb 27, 2011
  • 5603 Answers
SOURCE: I have hiss on my clavinova cvp 301 what can i do
The source of the noise could be many things. At real high volume levels with no notes being played, some hiss is common due to the statistical properties in electronics. At a normal listening level the hiss should be inaudible. If there is a failure there is little you would be able to do yourself to repair it. One MIGHT use circuit cooler to isolate a bad component, but it is unlikely you would have the tools to replace it as most everything is surface mounted. If you have a treble control, turn that down to reduce the level as the hiss is always up in the higher registers.
Posted on Apr 25, 2011
SOURCE: yamaha clavinova cvp-83s
Hi, did you manage to sort your problem as the same thing has happened to my clavinova (same model). Thanks.
Posted on Oct 10, 2011
Wiring diagram yamaha cvp 303 clavinova
i have a broken cvp-85a but the pedals are ok so?
Jan 14, 2013 | Music
Need manual for CVP-700 english version
how opening yamaha cvp-700
Jun 30, 2012 | Music
Hi, I hope can help me with this problem because I start to get desperate. I have a Clavinova CVP-85A. The sustain effect is always activated, whether the pedals are plugged in or not. I read that to...
It sounds like the inputs from the pedal switches are "floating", that is, not pulled up or down and they are drifting across the logic threshold. If I could find a schematic I could direct you right to the problem. For now, check the voltage across the switch contacts with a high impedance meter. Also check the resistance to ground of the common of the contacts. Without a schematic I am afraid to have you try things lest I direct you to do something that would cause damage.
Jun 07, 2011 | Yamaha Music
I have hiss on my clavinova cvp 301 what can i do to eliminate that?
Apr 25, 2011 | Yamaha Music
The disk drive on my Yamaha Clavinova CVP-105 acts like it has a disk in it when it doesn't and won't always play pre-formated disks like it used to. Is the drive dieing? Where can I go to get it fixed? ...
Often these drives are continuosly selected by the controller and rotate even without a disk.
These USUALLY use the old 720K disks which are almost impossible to find. The common 3.5 1.44Mb floppies often will not work in these units.
You can SOMETIMES use the 1.44Mb disks by covering the second corner hole AND degaussing the disk with a tape eraser and then reformating the disk in the Clavinova.
The pre-formatted 1.44Mb disks without degaussing SOMETIMES leaves artifacts between the tracks used by the 720K disks that causes problems.
Nov 27, 2010 | Yamaha Music
Yamaha clavinova cvp-83s
Oct 05, 2009 | Yamaha Full-Size Keyboard
I have a clavinova CVP 409. If I try to record using an external memory device (external Hard drive or memory stick, a message appears; DISC ERROR. Can you please help me solve the problem or direct me...
I SUSPECT that the CVP 409 will ONLY talk to the Yamaha USB floppy drive, not a hard drive or memory stick.
The internal drivers for these musical instruments do not have the "smarts" to talk to the wide variety of peripherals that PC's are able to.
Sep 10, 2009 | Yamaha Full-Size Keyboard
Jul 21, 2009 | Yamaha Music
Keys stick on Clavinova CLP 360
A contact rubber for CVP-35, part number VS549800 will work, that's how I fixed my sensor problems on my CLP-360.
Jan 19, 2009 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
116 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
