Question about Dryers
GE Gas Dryer lights but won't stay lit.
Ignition lights for a few seconds, then goes off and restarts and goes off again.
  • 4 Answers
SOURCE: Maytag Gas Dryer won't stay lit
Mostly the Booster & Holding Coil, Their part number is 3-06106
Posted on Jan 10, 2008
TheMobilian
  • 8220 Answers
SOURCE: Won't stay lit
You ignitor is working and sensor is working because it will fire up. so those pesky coils are intermittant because they get hot and quit cool off and work some more . replace them
cc8e664.jpgHere is a little ditty I wrote some time ago about this subject
INTERMITTANT COILS
Posted on Mar 07, 2009
  • 10865 Answers
SOURCE: flame goes out in 15 seconds
check these: Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on May 17, 2009
  • 212 Answers
SOURCE: GE Gas dryer. Not hot enough to dry clothes this week.
replace burner assembly
Posted on Jun 20, 2009
  • 250 Answers
SOURCE: Malta dryer burner won't stay lit
usually a clogged vent or I've seem a coil go bad that allows it to light once but not the second time in the cycle
Posted on Feb 02, 2012
JGBP90 gas range - precise simmer burner won't stay lit
Check the "Orifice Spud" to be sure that it doesn't have a partial blockage.
Nov 30, 2012 | Kitchen Ranges
Feb 01, 2012 | Maytag Dryers
The igniter heats and the flame lights, but it shuts off after just a minute or two. It won't go back on until the dryer has cooled down completely. Could it be the high-limit thermostat? With the...
What your describing sounds pretty much like the sympthons of weak coils that open the gas valve. It is a fairly common thing that happens with gas dryers so i have written a tip that explains in detail what happens when gas valve coils are weak.
http://www1.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
I hope i have helped you to fix your dryer,
GENE
Oct 09, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have a Whirlpool super capacity 465 gas oven that won't stay lit. It often lights up the first time just fine but then it turns off which is normal but when it tries to relight itself the ignitor...
That sound to me like yall have some carbon buildup on the igniter. On this stove the igniter does 2 jobs. It lights the burner and verifies back to the control that Houston we has ignition. If junk is built up on that ignitor then she won't be sending verification of ignition back to the control. That white residue needs to be removed. NOTE: I don't have your model number I am going by what you describe that this stove is a Direct spark ignition model. If you have a normal ignitor it probably is weak and not drawing 3.5 amps to open the valve. Post a model number (bottom drawer frame)
More Here
Sep 08, 2011 | Ovens
Dryer turns on and lights , heats approx. 1 min. goes out when up to temp, stays off approx 1min. lights again, may do this for 5 times then just doesn't relight. Stays cold, keeps spinning drum. ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | GE DCVH515GF Gas Dryer
Flame won't stay lit more than 15 seconds
heatman101
Aug 07, 2011 | Dryers
My gas dryer is not heating anymore, but it still tumbles. A pilot or ignitor light does come on for a few seconds when I start it but then it goes out. Is it supposed to stay on or is that normal and...
It is not getting gas. Either there is no gas getting to the valve or the two solenoids ontop of the valve are faulty and need to be replaced. The fact that the ignitor glows means the thermo fuse is ok.
Sep 22, 2009 | GE DCVH515GF Gas Dryer
Oct 08, 2007 | Dryers
Dryers Logo
82 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
