Question about Kodak EasyShare Photo Printer 500
Ink cartridge is stuck in kodak easyshare photo printer 500
  • 96 Answers
SOURCE: Printer Kodak Easyshare 5300 Will not print black ink
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Posted on Aug 19, 2008
SOURCE: Kodak Easyshare G600 printer dock problem!
I HAD THE SAME PROBLEM. tALKED WITH THE KODAK TECH LINE AND THEY TOLD ME TO...TURN OFF PRINTER, HOLD TRANSFER BUTTON AND LEFT ARROW DOWN AT THE SAME TIME AND TURN THE PRINTER ON. DO THIS THREE TIMES. iT WORKED FOR ME. GIVE IT A TRY.
Posted on Nov 27, 2008
  • 2692 Answers
SOURCE: EasyShare G610 Ink only wanted.
Start here:
http://www.kodak.com/global/en/service/products/ekn033119.jhtml?pq-path=10734
Can I purchase the ink cartridge and the paper separately for my printer dock?...No, you cannot purchase the ink cartridge and the paper separately....FAQ
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10734/7269&pq-locale=en_US
Posted on Jan 17, 2009
  • 3 Answers
SOURCE: Kodak printer dock cartridge is stuck inside printer dock
turn off your printer. Press and hold down the left arrow and the transfer button, turn on printer while holding them down, you should hear your printer make some noises, This will be the head lining up. Open the side door to gain access to the cartridge, push on it to see that it i s"locked" in. Lift up on the Green release button on the inside and your cartridge should come free on its own. Be careful not to try and pry it out for this can void your warranty! http://www.wonderhowto.com/how-to/video/how-to-remove-a-stuck-cartridge-on-a-kodak-g600-printer-dock-249276/view/
Posted on May 18, 2009
mdgoose
SOURCE: can not remove ink cartridge in Kodak EasyShare Printer Dock
Turn the power off. Hold down the transfer button, on the left side, and at the same time hold down the left arrow button, on the right side. Holding both buttons, turn power on. You should hear it recycle. After it stops, push in the cartridge in until it locks. Then you should be able to release the catch and remove the cartridge. I had the same problem, found this on the web and it worked for me. Hope it does for you, too.
Posted on Aug 27, 2009
How do you get the ink cartridge out of the printer
  1. Unplug your Kodak Photo Dock's power cord. Pull the black tab on the right side of the printer down to open the ink cartridge door.
  2. 2 Push up on the green cartridge release tab in the upper center of the ink cartridge to release the old cartridge. Pull the old ink cartridge carefully from the Photo Dock.
  3. 3 Rotate the new ink cartridge's ribbon wheel on the side of the cartridge clockwise with your finger to remove any slack in the film. Do not rotate the wheel too much---this will damage the cartridge.
  4. 4 Insert the new ink cartridge into the Photo Dock with ribbon film facing down until you hear the cartridge click in place. The ink cartridge will only go in one way.
    Do not touch the ribbon with your fingers. Handle the cartridge by its edges.
  5. 5 Close the ink cartridge door and plug in your Kodak Photo Dock's power cord.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 26, 2010 | Kodak EasyShare Printer Dock Series 3
Not printing in color and black/white copy not clear, light in some places
Dear sir
good day
to fix up such problem
Clean the printhead, then print and
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo + Copy simultaneously to print a demo sheet
and you have to Replace ink cartridges.
IMPORTANT: Make sure you are using KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to KODAK Ink Cartridges & Photo Value Packs.
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Insert new KODAK ink cartridges into the printhead, then press down firmly until you hear the cartridges click into position.
  3. Close the printer access door, then make the same print.
and you can point to the website below for further information
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=5224/6198
thanks
Dec 18, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Bought a new ink cartridge for 5300 printer - all photos were purple. Replaced ink cartridge with another new cartridge and now photos are green/yellow.
problem with printhead. go to www.kodak.com/go/printheadsupport and then try to remove printhead from printer. put it back again into carriage,install cartridges and then clean printhead from home center software. u r issue will be resolved
Jul 28, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I want easyshare photo printer COLOR CARTRIDGES.where do i get em
No. Simply use the paper when you get new color cartrides.
Jun 21, 2009 | Kodak EASYSHARE 300 Photo Printer
Won't accept new cartridge. 5300 Easyshare
I had a problem with my Kodak printer. I called Kodak explained the problem, they told we what would fix it and they sent me the part, extra ink cartridges, and some photo paper, all free of charge. So I would suggest calling Kodak and let them know what it is doing I'm sure they can help...
Jan 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Photos are too red printing on Kodak Easyshare 5300
After contacting Kodak and running through their trouble shooting site, they advised that the printer needs a new printhead which they supply free of charge.
Jan 09, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Can print paper but photos have green tint
If you refilled the ink cartridges, this can happen. Kodak uses pigment based inks, the others use dye based inks. Also, make sure your printer is set for normal photo printing, rather than special effects.
Jan 01, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EasyShare Photo Printer 500 Logo
41 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
