Question about Epson Stylus Pro 3880 InkJet Plotter Printer
I have the Epson Stylus Pro 3880. Up till a few weeks ago all was well, the today, it decided not to print out the black areas of my shots. I've check the inks, the heads all is well. HELP
I"ve tried all the different combination sof inks, types, etc, but the black is missing.
  • Epson Master
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Posted on Dec 03, 2012
  • 33 Answers
SOURCE: Epson Stylus Pro 4800 InkJet (Color printing problems)
If you do a nozzle check...do a cleaning...then do another nozzle check, you can "read" the patterns to see exactly what the problem may be. If the first nozzle check is missing half, then you do the cleaning, and the second is missing half also, check the pattern of the box to see if the missing nozzles are jumping around. If the pattern is exactly the same, you have clogs. If the pattern jumps around, you are having ink starvation issues, and may need dampers.
Posted on May 27, 2008
MerlinTech
  • 197 Answers
SOURCE: Black ink not printing...
same on a test page?
Posted on Jun 16, 2008
SOURCE: The black ink will not print on my Epson Stylus
I have an Epson sx600fw which has had a problem printing with black ink. I spent alot of money trying genuine and cheap inks as official advice is to replace with a genuine epson cartridge and clean up to 6 times before seeking further help. Tried this to no avail. By accident I found that if you set the paper type to glossy or photo then miraculously the black will work but in this setting it is slow. Epson replace the printer under warranty but I have just received a new one and it has exactly the same problem. I am slightly reluctant to buy another set of genuine inks to waste through 6 cleaning cycles as they are over £35 so am not sure what to do but I guess I will approach Epson again.
Posted on Nov 05, 2009
SOURCE: Epson Stylus CX7400 Black ink won't print
You are a ******* and I WILL NEVER BUY A PIECE OF **** EPSON AGAIN...THESE PRINTERS ****
Posted on Apr 12, 2010
  • 1218 Answers
SOURCE: my epson stylus color 400
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies. get more help and information for printer repair hope this helps you.
Thanks
Michel
Posted on Mar 03, 2011
How do i need to purge the ink lines on an epson 3880
Purging Procedure - If you have just installed a new archival or Quadtone cartridge you must purge the Epson print head of all of the old, non-archival, ink before you can begin to print with the full archival effect. The print heads in the Epson 200/400/440/500/600/640/740/800/850/860/900/1160/1520/Photo/Photo 700/Photo EX/Photo 750/Photo 1200 printers hold about 3 to 5 pages worth of ink. Always run a Nozzle check before printing. Even if you get a perfect nozzle check on your first try after putting in a new cartridge, run at least one or two head cleaning cycles. This will prevent any excess ink from over filling the print head. After the cleaning cycles, use the purging test patterns below to purge your system of the old ink. After printing about 5 (8.5x11) pages of this pattern, 98% of the old ink will be gone. The rest will come out slowly and may take as many as 20 or more pages, but at the 98% point you will see good results. If you have an Epson 3000, 5000 or 9000. See below
Sep 11, 2015 | Epson Stylus Pro 3880 InkJet Plotter...
Epson Stylus Pro 3880 Service call error 1224
4 possible problems and solutions, but you really need the service manual to do this:You might find it free somewhere, but most free sights will eventually lead to someplace where you will have to pay- just go here: http://www.2manuals.com/index.php?cPath=2_39
Sep 04, 2012 | Epson Stylus Pro 3800 InkJet Printer
I need a User's Guide for the Epson Stylus Pro 3880. I only have the quick start guide. How can I get one?
If you type your product description into the Product Finder box on this page, you will find that there are 4 versions of the Stylus Pro 3880:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes&expansion=1000000#prin (cut and paste it into your browser's search pane)
Therefore I will leave it up to you to determine which one that you have. At any rate, it will take you to a page giving you another link to the download file for the "manual", so you're most of the way home.
If the file that you choose doesn't display it's because they are .PDF files, which require that you have Adobe Reader installed on your computer, and use Adobe to open the file for display.
You can get the free download for Adobe Reader here:
http://get.adobe.com/reader/
Aug 04, 2011 | Office Equipment & Supplies
My epson stylus cx6000 has stopped printing black. I've cleaned the print head, changed the cartridge and it still won't print black. What else can I do?
Be sure you are using genuine epson ink. Epson printers are "smart" and will not allow generic ink to work properly. Even after you replace a generic with a genuine it may take several print outs and alignments to get it to print again.
May 05, 2011 | Epson Stylus CX6000 All-In-One InkJet...
Black ink will not print
You have submitted this problem in the Epson R220 area - it is unlikely to produce a response here. Try again putting it in the HP 990 area.
Jan 30, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Oct 10, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 3880 InkJet Plotter Printer Logo
308 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
