Coleman-blower motor contiuesly on even when t-stat is not calling for heat? Suspect relay on control board stuck closed?
All-roll-out switches test good,limit test good,power good from secondary transformer! t-stat rests good.correct polarity!
    Genius:
  • 1,033 Answers
Hello, the relay on the intergrated control board is stuck. Unfortunatly the relay is part of the board, so the entire control board must be replaced.
Posted on Dec 03, 2012
  • milton morales Dec 03, 2012
    Gosh Robert! That was Fast thanks-ah-bunch I really appriciate your help! Respectfully Milton.....
  • 51 Answers
SOURCE: Goodman GMH950904CXAC
make sure the blower is not set on rather than auto or the blower will run all the time. You might want to disconnect the thermostat and test the low voltage circuit to make sure the wires are not shorted
Posted on Aug 12, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Posted on May 30, 2008
  • 89 Answers
SOURCE: GMPN 100-4 furnace. Blower motor runs when not calling for heat.
The board is bad. The unit thinks a flame is present, so it tells the blower to come on. Replace the board.
Posted on Oct 08, 2009
gear001
  • 59 Answers
SOURCE: I have a Goodman GMP075-3. Worked OK on A/C.
I come across this one a lot. You need to switch the wires at power cord.
  1. Pull power out
  2. follow the cord* back to the furnace
  3. Open the front door
  4. There should be a small metal box where the cord leads to inside the furnace
  5. Open that up
  6. Take the electrical tape off
  7. Pay attention to which wire goes where
  8. Switch the two wires around
If you still got problems ill walk you through it over the phone www.fastacservice.com
Posted on Oct 12, 2009
  • 118 Answers
SOURCE: bad control board?
bad board
Posted on Oct 22, 2009
Coleman Evcon furnace blower runs w/ no call for heat. Temp is 5+ degrees above thermostat setting. (Programmable tstat)
When you say door are you referring to the front door or the furnace door? If the unit kicks on AND off by itself I would say it's in the tstat or the tstat wire. If it were internal I would think the blower relay or heat contactor/relay were getting stuck AND THE FAN WOULD NOT TURN OFF until you flipped the breaker. Good luck
Mar 21, 2017 | Coleman Heating & Cooling
I have a Coleman eb15b I have replaced blower motors both relays not the capacitor. Cause it tested good but blower still. Won't. Come on wat do I do
The big question is does the blower come on when power is applied direct to the motor or the relays are closed manually?
If it doesn't the motor is suspect, if it does the control circuit is likely to be faulty.
May 08, 2016 | Coleman Heating & Cooling
Blower fan continually runs
It may be but the fan control may be set to turn off at to high a temp, or theres a short between ;r; and g at the stat or furnace or sequencer, IF it runs through it. A limit or rollout switch may have failed but this will keep the unit from firering. Check for a manual blower switch that may be on. At stat it should be at auto and alsso at the fan control. A stuck relay is always possible,
Mar 08, 2015 | Coleman Home Electric Furnace Eb15b/Eb15d
I have a dometic air/heat roof conditioner. When it is plugged in to power source, it automatically stays on and won't turn off
I agree with other answers here indicating that it could be a stuck relay contact. These units are controlled by a series of relays opening and closing contacts that apply the voltage to the compressor and fan motors. If both the compressor and fan motors are running then I would seriously suspect the main power relay is either being held ON by a stuck relay contact or the t-stat or relay control assy board has malfunctioned and is holding the main power relay in a state of constant activation. If you can disconnect your t-stat completely from the circuitry [it usually will have a connector behind the t-stat that can be disconnected] and the unit still continues to run; that would indicate to me that the t-stat is good and the problem is a stuck relay contact or the relay is being held ON. Now, after all of that, unless you have a complete schematic diagram of the t-stat, external relays and relay control board, AND have the knowledge to troubleshoot with the schematics, take it to a dealer who knows what they are doing [and all of them do not even though they may think they do]. Good luck--
Jul 14, 2012 | Dometic Rooftop RV Air Conditioner
Ac blower not coming on
Does the blower run fine for a long period when set to on? If I had to guess it sounds like a tstat issue. Did it work before??
Sep 27, 2017 | Heating & Cooling
Electric dryer spins no heat, replaced heater element and high limit thermostat, tested thermal fuse and it does have 0 ohms, thermistor reads ~50 ohms.
in addation to checking the high limit t-stat have you checked the thermal cut off (the small t-stat) on the heater housing where the element fits into, the high limit t-stat and the thermal cut off BOTH shoud have 0 ohms (the thermal fuse is in the blower housing) the cut off is on the heater box, if you have checked those to be good, check that the heat relay on the control board is closing and sending power to the element, if not replace the control, if all above are good then the motor switch is bad and not sending power to the element(thats a built in safety feature so the dry would never heat when the motor isnt running)the element of course heats only when 240 volts ac is to the element ,120vac from the relay on control through the high limit t-stat then through the thermal cut off finally to the element and 120vac from the motor switch for a comined 240 vac
Jul 20, 2011 | Kenmore Dryers
I have a Coleman Evcon gas (propane) furnace. When the t-stat is switched to heat the furnace heats up but the blower will never turn on. The unit then shuts down and tries to cycle again. I have replaced...
If the unit fires but the main blower fan doesn't come on the the unit is shutting off on a temp high limit switch and it sounds like the problem is the main blower fan motor or control
Jan 18, 2010 | Coleman Heating & Cooling
Problem with carrier heat pump
Check the relays on the main board of your blower/furnace. If one is stuck, then the unit will not change from ac to heat. You may need to replace the entire board.
Dec 11, 2008 | Carrier 38CKC042 Air Conditioner
Janitrol/Goodman GMP075-3 Draft Inducer Fan Won't come on
most forced draft fans are powered by 120 volts . close to the fan is usually a plug that unsnaps. create a call for heat after turning off to clear safetys and see if your getting 120 to fan on initial call for heat. if you are then fan draft motor is bad, usually sold as an entire assembly replace exact as it came out. sequence of operation is..... stat calls for heat via common and white wire to furnace , 24 volts. ......board sences call and sends 120 volts to forced draft ........ motor runs and creates pressure on proofing switch,....... switch closes 24 to board and tells it draft fan is on......... board then energizes ignitor,....... after ignitior glows gas valve is opened and burner lights ........ either ignitor or seperate sensor rod tells board the burner lit........ and a few minutes later the fan comes on and hot air is blown out. if a step is missed or doesn't proof the furnace either trys up to three times to light or locks out. turning off power usually resets safetys and it will resume attempts to lite normally.
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
175 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
