My Emerson 32in LC320EM3f the only light i have is red and turns off when set is on. Is this normal. Set works fine otherwise
Should light on front panel be red all the time or green.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
This varies from set to set---many sets the red light will be on when set off and go out when set turned on---silly in that most of us are used to the light coming on when set turned on
If set works fine other than this I would not worry about it--annoying but likely normal.
Red light is set in "standby" and off when set on.
Posted on Dec 03, 2012
SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Posted on Nov 24, 2007
  • 5 Answers
SOURCE: TV Won't come on...
Hello to all from Tom Arnold, WA6OVP
Subject: Repair of computer monitors or flat panel TV’s.
History:
Recently my wife's 27-inch AKAI (LCT21AS) 27-inch flat panel HDTV with DVD player quit working. Years ago, when I had an analog computer monitor quit operating; Joe Fadden WA6DDF had mentioned to me, that often computer monitor problems were caused by the monitor's power supply. Joe also said these power supply problems were often caused by failed electrolytic capacitors. Joe said he was able to fix many computer monitors by just changing all of the power supply electrolytic capacitors. Rather the fix that failed monitor, I just a bought a new one.
Symptoms:
The inoperative HDTV had been bought at COSTCO and had already been returned once to a COSTCO repair center for repairs. Cost to ship and insure the HDTV was 67 dollars. We received back a new HDTV set. Turn around time was over a month, with many long distance telephone calls being required. The new HDTV worked for about three months after it was received. When the returned HDTV failed, it trapped a DVD disc that had been left in the HDTV DVD player. The new HDTV failure symptoms were the same as the original HDTV failure. The red led indication would not change to green when the remotes power on button was pushed. There was no picture and no sound. The remote is required to operate the TV set.
Economics:
My wife's HDTV with internal DVD player was very expensive. Worse yet, the trapped DVD disc was the movie Flash Gorden Space Soldiers 1936. A local TV shop wanted 85 dollars to look at the failed HDTV; repairs were 75 dollars labor an hour plus parts. I quickly figured out that if I could fix the problem it would save a lot of time and money.
Internet Search:
I checked the Internet to determine if other AKAI owners had similar problems with their HDTV sets. There were lots of AKAI 27 inch and 32 inch HDTV set owners listing problems. Without exception all of the complaints concerned the HDTV power supply PC board and failed electrolytic capacitors.
General Internet Consensus:
Most of the AKAI HDTV sets worked just great and that many had been sold worldwide. There were some AKAI HDTV sets that did have power supply problems. Most of the AKAI HDTV set owners were not very pleased with either AKAI or the COSTCO response to the inoperative HDTV power supply problem.
Trouble Shooting:
All electrical power was removed from the HDTV set. The HDTV was placed face down on a workbench with a piece of cardboard to protect the display screen. The HDTV back panel cover was removed. There were many screws of several different sizes. The power supply PC board was separate from the rest of the set's components and was easily identified. The power supply PC board contained several different individual different voltage power supplies. Three electrolytic capacitors located on the PC board had obviously failed. The tops of these three capacitors were puffed out. Often when electrolytic capacitors fail they get over heated and the top of the capacitor is puffed out displaying an over pressurized appearance. The power supplies on the PC board were of the switching type. Switching type power supplies are also used in computer monitors to save money and weight.
Power Supply PC Board Removal:
The power supply PC board was mounted to the HDTV back panel with several screws. These screws were removed. There also several multi-pin connectors attached to the PC board. These connectors were numbered with a black felt marker to ensure correct reinstallation. The connectors were Hot-glued in place. A sharp knife was used to remove the hot glue. The connectors were removed.
Repair:
The three suspect failed capacitors were easily removed. The three capacitors were each 1000 ufd and rated at 16 working volts. The other power supply PC board electrolytic capacitors were visibly checked. Three new capacitors were installed, they were rated at 1000 ufd at 25 working volts. On the PC board the three electrolytic capacitors were in just one of the power supply circuits and were identified as EC18, EC19, and EC20.
The New Electrolytic capacitors:
These were low impedance / high reliability radial lead polarized aluminum capacitors, they have a plus and minus connection pins. Correct installation of any polarized capacitor is required. The three new electrolytic capacitors were specifically designed and rated for service in switching type power supply circuits. Switching type power supply electrolytic capacitors need to be both very robust and designed for use in high frequency circuits. General-purpose aluminum electrolytic capacitors should not be used in switching type power supplies, if capacitors designed for switching power supplies can be obtained.
Final Repair Steps:
The PC board was reinstalled without the electrical connectors to the PC board being hot glued. The HDTV back panel cover was refastened. Watched episodes one through five of Space Soldiers. It was well worth the time and three electrolytic capacitors to fix the problem. The repairs saved a lot of time and money. The repair was very simple and not the least challenging. It took longer to remove and then reinstall the HDTV back cover panel than it took to replace the three failed capacitors.
Safety:
These types of repairs should not be attempted without a complete understanding of the dangers involved with working on electrical equipment, especially working around power supplies and charged capacitors. Proper desoldiering and soldiering techniques need to be used.
Conclusions:
Flat screen computer monitors and TV sets do fail. Repairs of electronic equipment can be very expensive. When your computer monitor or flat screen TV does fail, you might consider a visible inspection of the equipments power supply. A simple repair might save you a lot of time and money.
Posted on Aug 21, 2008
  • 191 Answers
SOURCE: LG 32LC2D Power light Blinks but set will not power on.
change your adc(analog to digital converter) board will help out
Posted on Oct 11, 2008
  • 2336 Answers
SOURCE: My LG Plasma 42PC3D turns on and off repeatedly. I
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
Posted on Sep 24, 2010
SOURCE: my flatscreen emerson tv will not turn back on.
I found a way around this problem. When this happens, don't use the remote.
Walk up to the TV, then HOLD DOWN the power button and while the lights are flashing, start pushing the menu button on the TV at the SAME TIME.
Then your screen will turn on. No idea why this works. Just stumbled on it while getting ********** that this TV, I had less than a month, suddely would not come on anymore. I was about to unplug the whole thing to take back to WalMart and just started pushing button combinations and found this worked.
Posted on Dec 26, 2010
I have an Emerson tv 32in model no. Lf320em4a it’s about 3yrs old it won’t turn on the screen starts and shows the Emerson name then shuts off.is there a fuse or etc or is it just shot
Check your voltages when you power it on compared to when it shuts down...see what rail is dropping off for starters, then I can give you more of an idea where the issues are at..I have a feeling you have inverter issues because this was a common failure on this set check and see what voltages drop off after the startup screen
Apr 03, 2018 | Emerson Televison & Video
How to program a VT1320 Emerson remote when it does not have a tv button, only power button and does not show up on screen to do the programming?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Jan 07, 2016 | Emerson Televison & Video
EmersOn TV has no picture when you turn it on, I noticed that the red light blinks 4 times after pressing on, I'm curious if that means something? Please help!
the 4 blinks are a error code means something wrong inside the tv
type your number and error code in google maybe point you in right direction
Jun 23, 2015 | Emerson Televison & Video
I have a Emerson model LC320EM3F-A TV style ME2A1236181115. The model number for the Magnavox DVD Player is MDV2100/F7. How do I get it to work?
usually plug the proper wires from the DVD player into the proper input jacks on TV then select the proper input to the TV thru the menu
May 04, 2015 | Emerson Televison & Video
Reset dynex tv
You can reset the unit by unplugging, wait 30seconds to 1 minute.then try again.
If still doesn't come on, the lightning may have done some internal damage, such as to the power supply or Main PCB.
Jul 23, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
Dish network code for emerson LC320EM3F
For LC320EM3F I used 694. I read somewhere that Emerson makes Funai TVs. This was listed as one of their codes. Worked like a champ.
Dec 01, 2012 | Emerson LC320EM8 32 in. LCD TV
Flashing red,blue, green screen
last week i had an emerson 21 inch with built in dvd.,it was flashing colours.none of the front buttons would work.i unplugged the front buttons and plugged them back in again.set is working fine.ican not remember if i did it with the power on or off.try both.some how the front buttons were locking up the micro.
Nov 24, 2011 | Emerson LC320EM9 32 in. LCD HDTV
My name is shakena brown, i have a sanyo 32in flatscreen TV that I brought from Wal-Mart. The TV is not an year old yet and it will not show anything. When I plugin the cord in and turn the TV on the...
Your set is still under a manufacturer warranty. Take your set back to Wal-Mart and they will send it out to be repaired, or give you a new one.
May 19, 2011 | Sanyo Televison & Video
Emerson 32in flat panel has a resolution mismatch with my ps3
I had the same prob,first thing u need to do is to hold on ps3 power button for 4-6 sec until the ps3 resets and turns off.Next unplug and replug yr hdmi/red white and yellow wires in.Then turn ps3 back on it should adjust in 8seconds.
Sep 07, 2010 | Emerson LC320EM8 32 in. LCD TV
I have a black box going across my screen with blue numbers it will not go away. I have an emerson 32in hdtv flat screen
Make sure closed captioning is turned off on the TV as well as your cable box or satellite receiver (if you are using them and they have that feature). Captioning is probably on and set for text mode.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Televison & Video Logo
231 people viewed this question
Top Televison & Video Experts
