Question about Kenmore 24 in. 17032 Built-in Dishwasher
Dishwasher doesnt pump, wash dishes. - Kenmore 24 in. 17032 Built-in Dishwasher
Why does our Hobart lx 30C Pump out at start of wash cycle?
Could Could the anti syphon blocked? I'm guessing the drain pump doesnt operate while this happens
Jan 16, 2018 | Hobart Dishwashers
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
Dishwasher fills with water but doesnt spray water around
suspect the pump has failed .or the control board for it
Mar 03, 2018 | Frigidaire Dishwashers
My kenmore washing machine fills with water but will not wash..it sounds like its doing something then it stops after a while i hear it drain and then stops again..water doesnt spray..I let the dishwasher...
Often these work by reversing the motor which has two pump impellers. One direction will pump the water out and the other will pump it through the spray bar. IF the one pump impeller has broken then that would explain your symptoms.
If this is the type you have, verify that the motor is running reversed from when it is draining. If it is not running during wash time, then the timer is probably at fault. If it is running, check for broken pump impeller for the was direction.
Sep 29, 2009 | Kenmore 24 in. 16193 Stainless Steel...
Bottom rotating arm doesnt spray water but top arm does
i have a similar problem. water is not reaching the bottom spray arm. there. i have an underwater case for my digital camera, so i'm going to put a torch or 2 in some waterproof bags and remove the bottom spray arm and run the dishwasher to see if there's water coming out of the bottom pipe, if not, i need to try and see if there's a blockage in the system, or a dodgy valve, could be that the soldering's or the control panel's buggered.
Nov 24, 2008 | Siemens 24 in. SE25T250 Free-Standing...
GE Dishwasher
It could be a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle,it pushes the water out of the dishwasher. The motor and pump are located beneath the dishwasher. Look if the pump's impeller (a round plastic fan blade-type of device) spins around freely. In case it doesn't spin freely, look if it doesn't blocked or stuck from any other reason. Good luck!
Sep 10, 2007 | GE 24 in. Profile PDW7800 Built-in...
Kenmore 24 in. 17032 Built-in Dishwasher Logo
70 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
