Question about Refrigerators
LG GR P227STG icemaker has no water from dispenser?
I have a LG GR P227STG, icemaker fridge and was working fine until I went away camping for two days, on my return the water dispenser was not working???? Help please. I have taken the inlet pipe off and water is coming through from main supply, where to from here?
  • 92 Answers
SOURCE: ice maker not working
make sure its turned on check the wire connector is seated and check to make sure there is nothing jambed in the tray if all that is ok call for service
Posted on Feb 10, 2008
SOURCE: water dispenser in fridge door
I have same problem with GE monogram 42. ice maker works, water dispenser not. It does click but no water. Help.
Posted on Feb 23, 2008
  • 1073 Answers
SOURCE: just bought a fridge freezer.
call for factory service
Posted on May 06, 2008
jmgldsmth
  • 1869 Answers
SOURCE: Water Supply Line for Ice maker and Water dispenser is leaking.
Go to the hardware store and get a brass tube sleeve coupling; cut off the old tube end, slide the hex cap thread side out onto the tube, then; slide the tube sleeve onto the tube and, seat the tube into the supply valve then tighten the hex nut.
take the old parts to the hardware store to compare; the size is most likely 1/4" the part can be found in the "evaporative cooler parts" section of the hardware store
Posted on May 28, 2009
  • 35 Answers
SOURCE: Whirlpool ED22DQXEW01 Water Dispenser Problem
CHECK WATER FILTER/// IF GOOD BAD WATER VALVE
Posted on Jun 18, 2009
Hi I have an LG fridge freezer model number GR L206CPQA and there is a horrible smell coming from the water from the dispenser, the filter has been changed and the ice seems to be fine but the fans on the...
Sorry but your model number doesn't register with me in the USA.
My experience tells me that the plastic water line from the filter to the water tank to the dispenser outlet is your problem. Replace those parts and you should be ok.
Hope this helps.
Nov 14, 2011 | LG Refrigerators
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Hooking up water line to LG LRSC26920TT - water runs great through line, but once connected to fridge, no water runs through line in fridge - no water comes out when trying to fill a glass. No water...
dissconnect water line coupling behind lower kick plate under door. push water dispenser; and sell if water flows out line. keep a towel handy. it there is water; then, the problem is in the door itself. of course, make sure the water solenioids are working.
Apr 17, 2010 | LG LRSC26925 Side by Side Refrigerator
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
My icemaker is not dumping the ice when it's frozen.
Replacing the icemaker is neither expensive nor hard. Order a replacement on the Internet.
Sounds like a malfunction in the icemaker itself.
May 27, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jun 18, 2009 | Whirlpool ED2FHEXN Side by Side...
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
