Question about HEALTHRIDER R60 SoftStrider Treadmill
How do u turn machine on to use?
Push start moves about an inch then stops. thks ermalene
    Top Expert:
  • HEALTHRIDER Master
  • 12,223 Answers
This happening because the lack of maintenance LUBE schedule, you must do it , every week of use aprox. the machine shut down for to protect itself the electronic system. Use 100% de silicones or wax according with owener manual.
2) Lube the rollers bearing too.
3) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for MOTOR help.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Posted on Dec 03, 2012
Machine stops when needle is moved up or down
Five Common Sewing Machine Mistakes + How to Fix Them
www.tillyandthebuttons.com/.../five-common-sewing-machine-mistakes-...
Sep 23, 2014 - Sometimes the needle will push the edge of the fabric down into the ....also helps stop that problem, too .... makes for very frustrating sewing .... handwheel wont turn and so the needle doesn't move up and down, please help.
Trouble Shooting a Sewing Machine - YouTube
? 2:35
https://www.youtube.com/watch?v=A2QqmEh5qcw
May 25, 2009 - Uploaded by MonkeySee
my machine needle won't go up and down on a white sewing machine. ... won't go up and down it'll go but then it will stop moving after i push ...
Nov 30, 2015 | Sewing Machines
I have a kenmore he3 dryer that won't stay on. When I push the start button, the motor will turn the drum about a quarter of an inch then stop. I then need to push the pause/cancel button once and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 16, 2011 | Dryers
Loud clicking noise on startup
Had the same problem with machine gun noises. Solved same. Simply turn printer off. Open door. With a flashlite, look inside to the right side where you'll see a small tray that slides forward and backwards. This is the cartridge cleaner. Push the tray forward (away from you) until it stops then move it backwards until the little black tab on the right is 1/2 inch from the metal part of the carriage. Close the door. Turn printer on. All done. Print something.
Oct 28, 2010 | HP D1660 InkJet Printer
Singer 2259 - The machine has stopped moving, the foot pedal is making some noise and the hand wheel will turn OK but nothing moves when I push the foot pedal.
Check to see if you have your bobbin winder on. That's usually the problem. Just push it to the left and you should be ok.
Sep 09, 2010 | Singer 2259 Sewing Machine
Washer starts to fill then shuts off.
First, turn it off, and completely unplug it, then plug it back and turn it on if it continues to do the same thing replace the fill valve on it, just always make sure your safe when working on it or whatever your doing let me know im interested thks hope this helps
Feb 19, 2010 | Washing Machines
I just moved into a flat with the WMA641 w Beko Washing Machine. I loaded it and turned it on : settings : Delicates 30 degrees. Pushed the on button and nothing happens. after few seconds the on light...
turn the machine off at the wall , leave off for 30 secs , switch back on
and push the start button
give the door an extra shove as this may not be fully closed
the on/off button will be a push in type , the start button is usually much smaller
Oct 23, 2009 | Washing Machines
My needle keeps moving while I try to wind my bobbin
hi there,
the hand wheel and clutch should be disengage so that needle will not move also w/ the bobbins,doing this is hold the hand wheel then grip hold also at the center hand wheel.rotate center counter clockwise to release clutch.other type is push and pull hand wheel.any of them,try to run machine if needle is move again.cheers have a nice day don't forget to rate me.
Apr 07, 2009 | Singer 7436 - INGENUITY
HEALTHRIDER R60 SoftStrider Treadmill Logo
73 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
