Question about Mitsubishi Televison & Video
Tv turns on and back off
Push the power button, hear a click and then the light goes off
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Most of these sets have a self check----if Green power light comes on for a few seconds and goes off on the front of the set press and hold both the menu and input (source) buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it for a total of 5 times.
Let me know if you get a error code and what it is.
Unplugging power from the set clears the error code so if that has been done you will have to try to turn set on, let it fail and then do the self check again.
Posted on Dec 03, 2012
SOURCE: TV Won'T Turn On
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Posted on Dec 18, 2007
SOURCE: Mitsubishi Medallion does this
may be there will be some loose connections inside you need to find and should solter it ............if warranty is there go for it...................because repairing by own will void warranty
Posted on May 26, 2008
SOURCE: power on, few seconds off
Took it to the landfill today. Thanks for the reply!!!
Posted on Jan 26, 2009
ginko
  • 19396 Answers
SOURCE: Clicking sound!
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 15, 2009
SOURCE: mitsubishi WS-55909 dm board repair
I have the same exact problem with the mitsubishi ws-55809 I get 2 blinks pause 2 blinks when I do the menu and input buttons but I have no idea what it means.
Posted on May 31, 2009
I push the power button the power light come on i hear a click the the light goes back off what is wrong with my tv
Do the self check this model has:
Turn set on and when green power light goes out: press and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code: most common one is 2 blinks, pause and 2 blinks---it will repeat the error code at least 5 times.
Let me know what you find--2,2 is the most common and may be a do it yourself repair.
I am here to help you--if this information is helpful rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 11, 2010 | Mitsubishi WS-55513 55" Rear Projection...
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Sylvania 6842THG won't turn on. the tv red light displays when you push the power button you hear a click and then 5 - 10 seconds it goes back off
I have been having the same issue. I unplug the TV for 10 minutes and it usually works fine. I moves all of my A/V plugs to a single power strip and that helped a lot. Since then, the TV went into protection mode only once in 2 weeks. Next, I will use a power strip that includes the cable protection.
Dec 12, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
TV will not turn on
Hey guys this one is a no brainer when you push power button AND STANDBY LIGHT COMES ON NEXT PUSH THE BUTTON ON THE LEFT NEXT TO POWER BUTTON AND WALLA IT TURNS ON
Nov 11, 2008 | Televison & Video
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
ESA 42" plasma will not turn on
Find a power supply that was the problem with my. Exept my tv now dont have picture Cause ysus board is dead..
Nov 10, 2007 | Televison & Video
RCA 27F520T no picture problem
 Examine PCB closely,probable cracked board.Depending on
how severe,it may be fixable.Ask repairman what the bench labor
charge will be to repair,if repairable at all.
Oct 11, 2007 | RCA TruFlat 27F520T 27" TV
42pf9956/37 philps plasma
I don't know why but this got my TV on.
I took off the back cover and found the source of the clicking.
Two blue plastic rectangular relays in the exact middle.
When I pushed the power button, I felt the top relay click, and I saw a flash from the bottom one. (they are right next to each other)
I took a hair dryer and placed it over the two relays for about 1 minute and tried the power.
It clicked only 4 times and then came on!!!!!!!!!
For some reason heat helps the relay.
If anyone is a tech and can explain this, please do.
Good luck!!!!
My tv is on and it didn't cost me anything.
I just can't turn it off now!!!
Sep 25, 2007 | Philips Magnavox 42MF521D/37 Television
TV Won'T Turn On
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Open Questions:
Televison & Video Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
