Question about Dewalt G17 Brush Setdewalt Dw420 Dw421 Dw422 Dw423 Sanders
My dewalt dw423 looses torque under pressure - Dewalt G17 Brush Setdewalt Dw420 Dw421 Dw422 Dw423 Sanders
My Dewalt DC925 works well but the torque settings don't seem to be working.when i am drilling screws the drill will just drill until i release the trigger.is this a clutch problem?. Many thanks.
Try to put it on the lowest torque and if it slips when wanted, then add a little more torque and check to make sure it slips. Continue at each torque setting and usually works again at full torque. Usually happens when left on the same torque all the time. This kind of resets it.
May 07, 2015 | Dewalt Drills
18 volt cordless Dewalt drill does not have any torque I can stop it with my hand quite easily any suggestions
If it's fully charged and still has no torque, either replace the battery or, if you're a DIY type, disassemble the battery and check each cell under load to replace just the weak cells.
Sep 08, 2014 | Drills
Dewalt 331k jig saw blade falls out
Dewalt Jig Saw
DeWalt Jig Saw MANUAL ManualsOnline com
Blade catch wears out too fast
I loved this tool when it was working but after not that much use the teeth that hold the blade under pressure no longer hold hard enough to prevent the blade from coming out. The mechanism that holds the blade has no catch hole, it uses a few serated teeth to pressure hold the blade in place. Unfortunately, once the pressure starts to lessen you can't tighten it down...
Aug 24, 2014 | Dewalt 331K 6.5 Amp Top Handle Jig-Saw
Dewalt xrp stuck in hammer mode cant move selector to drill or number selections
I am assuming you are talking about not being able to move the "Mode Control Collar" and unless you can get it out of hammer mode, you will not be able to change the torque collar either.
If you feel comfortable taking it apart AND its no longer under warranty, my best guess without seeing the tool will be part# N026313 Gear Case Assembly. It costs about $80.00 US
Hopefully its under warranty, if so you can go to
http://servicenet.dewalt.com/ServiceCenter/Search
to locate nearest service center.
Good luck
Sorry I wasn
Apr 29, 2011 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
Dewalt drill won't work in 1st gear then it kicks in and works
You could have lost one teeth on the gear wheel . Once it is rotating the system will not miss the lost teeth, until you loose some more teeth then you will loose power and the drilling will become jerky and might even stop on applying pressure
Mar 08, 2011 | Dewalt DrillRecip Kit 18V
Operating instructions
The Instruction Manual for the Dewalt DeWalt DPD3300 3300 PSI 28 GPM Commercial Pressure Washer can be downloaded from the following site:
http://servicenet.deltaportercable.com/Products/Detail?productNumber=DPD3000IC
Scroll down in the Downloads box to the desired item; select the icon under PRINT DOCS to open.
Mar 06, 2011 | Dewalt DPD3300 Commercial Pressure Washer
Using a garden auger with the torque set to the highest setting the clutch broke and started to slip. Is this too much for the Dewalt 720 cordless drill? Dewalt is repairing it under warranty.
Yes, luckily Dewalt is taking care of you. You might want to look into a 1/2' drive electric model (sorry with a cord) Alot depends on how hard the ground is but in the long run the big electric will handle about anything you throw at it. Check Sears or Home Depot both good sources for good tools
Jan 04, 2011 | Dewalt 18 Volt Compact Drill Kit
If the pump is broken, should the engine start? if i choose to rebulid pump where do i find the torque values/guidlines for the pump. i have to get the model #, but i do have the dewalt 3800 psi model. ...
If the engine turns rather freely and not hindered by malfunction of pump, then it should start. Since you are going to rebuild pump, you should just remove the pump from the engine now and set it on the work bench to prevent any further damage. It is a good idea to test engine before you spend any money on the pump. Dewalt service center has all the parts lists for your machine, however you should look up the model number of the pump itself (stamped / tagged on body of pump) and look for more information from mfg. web site. Good luci
Nov 11, 2010 | Dewalt 3800 PSI Pressure Washer
How do I select torque setting?
the black ring behind the chuck, has numbers on it, turn to desired torque
May 24, 2010 | Dewalt DC750KA Heavy Duty 3/8'' 9.6V...
Dewalt G17 Brush Setdewalt Dw420 Dw421 Dw422 Dw423 Sanders Logo
52 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
