Question about Igloo Cooler IGLOO Freezer. 3.6 cu. ft. Upright Freezer in white FRF434
Igloo Cooler IGLOO Freezer. 3.6 cu. ft. Upright Freezer in white FRF434 will not freeze
2 Suggested Answers
  • 884 Answers
SOURCE: Igloo chest freezer 7.2 cubic ft seems running all the time?
It may be on "superfreeze", if there is a yellow light, or it may be set for too low a temperature (try setting the thermostat down to 1 or 2). Check the condenser is clean, and fan working if it has a fan, Check lid is closing properly and the ambient temperature isn't too high.. Lastly, if all else working correctly, suspect short of refrigerant.
Posted on Apr 30, 2014
Does this fridge have a drip pan
All fridges have a drip pan. Pull your fridge away from the wall, pull the lower cover off, and you will be able to locate it with a flashlight
Aug 04, 2016 | Igloo Cooler Igloo - 10.0 Cu. Ft....
Hey so we have a front open door freezer FRF 434 it is not freezing ... why could be?
door seal not sealing
compressor not working
could be a start/run capacitor , low gas or a seized compressor
cal a technician for a proper diagnosis and quote
Jul 12, 2016 | Igloo Cooler IGLOO Freezer. 3.6 cu. ft....
Why is my upright igloo freezer not staying close
The door sometimes warps and need to be lightly twisted back to where all four corners make contact and seal.
Your unit may need to be tilt back a bit so the door wants to close y itself, the front foot pegs are adjustable and can be turned to make the front higher or lower than the back side of the cooler, gravity closes the door when the unit is leaning back.
Aug 28, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
What does the on off switch for inside the frig "?"
Defrost heater.
It should stop the compressor and turn on a heating element to speed up defrosting.
Jul 15, 2014 | Igloo Cooler Igloo - 10.0 Cu. Ft....
Apr 30, 2014 | Igloo Cooler Igloo - 5.2 Cu. Ft. Chest...
Fridge noise cutting out
To be honest it sounds to me like your fridge may be ok?
To extract the heat from within the fridge interior a compressor (motorised pump) moves gas around a series of pipes around the cabinets insides. This movement of gas causes heat to be picked up and taken away externally to the outside world. When the fridge temperature reaches a predetermined level (around 5C) the compressor shuts down and all is quite. The sound of running water you hear is the coolant gas changing state from gas to liquid and running through the coolant pipes. If the fridge is doing it's job and keeping the content cool then I wouldn't worry. One of the reasons you are probably noticing this sound is because it is a table top fridge. Built in fridges make the same noises but you don't really hear them so much because of the cupboards screening the sound.
Dec 27, 2013 | Igloo Cooler IGLOO Freezer. 3.6 cu. ft....
Igloo Cooler IGLOO Freezer. 3.6 cu. ft. Upright Freezer in white FRF434 Logo
Top Igloo Cooler Freezers Experts
Michael Youngman
Michael Youngman
Renee Knafel-Bullock
Are you an Igloo Cooler Freezer Expert? Answer questions, earn points and help others
