Question about Horizon GS950T Upper Control Board
Safety key off
How to reset the control bard?
    Top Expert:
  • Horizon Master
  • 12,223 Answers
You need to reset the machine. see your instr. manual where located the reset b.
see the block diagram attached. the control board can NOT be reset.Test the key magnet for repulsion attraction or repulsion againt with your magenet refrigerator and replace if necessary.
God bless you
Posted on Dec 04, 2012
My Z100 Tredmill screen will not reset or respond when any button is pushed on the console. The fuse on the board is good. The outlet is properly grounded. Need Help
Safety key is installed? No response from key presses usually indicates a "halt"state for the upper control "brains" like when the safety key is pulled. You can also try jatinah electronics for further help.
Feb 01, 2015 | Spirit Fitness Z100 Treadmill
RM-VZ320 won't even turn on my player, help?
depending on age you might have to take apart not hard and clean the key pad where they make contack with bard with pencial erraasor or rubbing alcohol and a cotton swab to clean contacts good luck
May 03, 2014 | Sony RM-VZ320 Remote Control
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
follow this steps and fix it. God bless you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
Screen turned yellow
Hello
Just do a factory reset to your set and see whether it helps you. If it doesn't help you to correct its color, T'Con board [Timing Control bard] of your set needs replacement. But before replacing this card, a thorough check should be done by any experienced service technician. If the board needs repalcement, it will be best it to be done at the Authorised Service center for Sharp at your town.
Anyway, just reset the set to its factory settings first. To make it to its factory set values for all parameters, Get into it Menu, surf though, select "Reset" and press Enter. OK.
Nov 02, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Error 7 on my york inspiration treadmill tried reset button but still not working any ideas.
hi,
By error 7 it means that the safety is not positioned correctly. or the saftey switch inside the unit is faulty. Its a magnetic switch. When you place the safety key (its made of magnet) this switch will activate. Then only teradmill start. Check the safety key is positined correctly or not. If it is in position then you have to replace the safety switch inside the control console.
OK
Sep 01, 2011 | York Barbell Home Use Fold-Up Treadmill
Which key is the options key on my keyboard
The option you mean the right click feature on your mouse that you can use on your keyboard if so the option key is on the bottom right hand side of your keyboard
Example bottom middle is space bard then to the right of it should be Alt Gr the next one over is your windows key and the one next to that is an option key if you are controlling your computer without a mouse this button is useful for emulating the right click on your mouse by pressing this button down it acts like a right click and you have the options you would normally have. if this is what you needed please rate me if not will further help Kronoguy
Aug 03, 2011 | E-Machines eMachines Desktop PC
Forgoten my password for norton tried to phone 0906 635 5414 but no is bard can you help
This is from Symantec
How to reset the Norton Internet Security 2004 or Norton Personal Firewall 2004 password
Situation:
You forgot the password that you assigned to Norton Internet Security or Norton Personal Firewall.
Solution:
To reset your password
1. Click Start > Settings > Control Panel > Add or Remove Programs.
2. Select Norton Internet Security or Norton Personal Firewall.
3. Click Change.
4. Click Reset.
5. In the "Password key" field, type the password key displayed.
6. Type your new password into the "New password" and "Confirm new password" text fields.
7. Click OK.
Hope this helps.
Oct 05, 2009 | Computers & Internet
Pasward compaq harddrive pls guide it open and chang bard hard
To reset the BIOS password you must take out the BIOS battery on the motherboard of the computer.
On most desktops this is not a hard thing. Simply take off the side of the case, then take out the quarter sized battery on the motherboard, wait 60 seconds then reinstall.
On a laptop the same thing must be done but I must recommend you take it to a local technition as this is not an easy thing to do if you have never opened up your laptop.
Mar 11, 2008 | Compaq Armada M700 Notebook
@ sign on my laptop key bard
I have an acer computer too. I had to press the (ctrl) (bottom left) and then the (Alt) botton (beside the space bar) and the number 2 at the same time to get back the @ sign then it should work normal from hear on in .
Dec 06, 2007 | Acer NSK8458AN Keyboard
Horizon GS950T Upper Control Board Logo
244 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
