Question about LG 47LE5400 47 in. TV
First there was a bar of doll color in the middle of the screen now there is nothing just black.
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
Samsung 32inch d580 series 5. has two vertical color bars in middle of screen. have checked ribbon tape connections.
how about re seating the lvds cable in the t-con board doesn't work. if not, check for cold soldered component at the x board just re soldered it.
Sep 07, 2012 | Televison & Video
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
Black square in middle of screen on all channels. Not on other tv's
You might have a dead spot.A dead spot is where the pixels in the screen have "Died" and do not register color.They can show up as many colors but do not change in colors.If so there is nothing you can do but buy another television.Hope it helped
Oct 15, 2009 | Televison & Video
Sanyo Z3 Blue Color Problem
the LCD Module of your projector in blue panel is burn so that you can it larger and larger. replace your lcd blue panel. and also the mirror inside your optics.
Oct 08, 2009 | Sanyo PLV-Z3 Multimedia Projector
I hooked up this moniter turned on the power and nothimg black
My Dell monitor is showing odd splotches of colored bars.....turquoise bars and pink bars. What is causing this?
Apr 21, 2009 | Computers & Internet
Picture just has black bar down the middle of the screen.
That is probably a faulty segment display.
Replacing the screen will fix it.
Dec 07, 2017 | LG 50PC3D 50 in. Plasma Television
No color
CHECK THE SYSTEM IC
Sep 06, 2008 | Akai CTS2550 25" TV
LG 47LE5400 47 in. TV Logo
Computer Repairing
Computer Repairing
