Question about RCA Audio Players & Recorders
I need a transcription software compatible with vr5320r
I need to transcribe audio voice from my rca vr5320r. I need software to do this. I have a sony voice editor2 foot pedal and transcription software.
javer821
  • 207 Answers
SOURCE: transcription does not work .. foot pedal will not
Hello on the right side of unit is a switch for transcribe make sure is on the on position you are going to see on Deck A only lines on display, put your tape on Deck B is the only side that transcribes if the pedal does not respond you probably have a broken pedal here is one in a great price
http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
Or if you feel better to send unit to service try this.
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Posted on Dec 18, 2009
javer821
  • 207 Answers
SOURCE: Sony BM-147 transcription unit rewind/fast forward problems
Hello just get a really cheap foot pedal replacement at http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
Posted on Jan 07, 2010
  • 145 Answers
SOURCE: My transcriber keeps going after
Does your transcriber have a digital display? If so, turn off indexing by holding down both stop and reset together for about 5 seconds. Also turn off the Auto Stop if on.
Posted on Dec 17, 2010
  • 8 Answers
SOURCE: I got only the foot
THe RS 25 pedal works with the Ds 4000 as a hands free device allowing you to operate the play / rewind / record functions with your foot
Posted on Jan 25, 2011
  • 89 Answers
SOURCE: I have a RCA VR5320R
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player.
These units are notorious for their failing USB feature.
Posted on Mar 15, 2011
Installed Olympus AS2400 transcription software on my PC running Windows 10 - worked fine for the first couple of days then would not open at all,
check that the program is compatible with win 10 os
if not then you have a problem that you will have to microsoft or the software publishers as to how to get it to work properly
take it all to an IT geek shop and have them install the soft ware or find out why it will not work
Nov 08, 2015 | Olympus Software Olympus AS 2400...
Olympus DSS Player Pro Woes!
Could it be that the files are just being regularly accessed by one of the server admin tools and the DSS Player application interprets an open file as 'being transcribed'
What happens when a copy of a .DSS file is made to an operators machine and then loaded locally for transcription?
Oct 21, 2007 | Olympus DS-40 Digital Voice Recorder
HOW TO INSTALL OLYMPUS DRIVER FOR FOOTSWITCH RS24
Hello your foot pedal don't need drivers but you need for sure a transcription software, the pedal will required a program to work together to control your audio files for example you can get a Olympus transcription software that will be compatible with your pedal, at http://www.tvps.com/Products/Olympus-AS-5002-DSS-Player-Pro-Version-5-Transcription-Software---New__OL-AS-5002.aspx or you also can used http://www.tvps.com/Products/Olympus-AS-7002-Pro-ODMS-R6-Transcription-Software---New__OL-AS-7002.aspx
May 01, 2014 | Olympus AS-2300 PC Transcription Kit
Rca vr532or lost manual need to set it up again
The manual for the VR5320R is available at the RCA audio/video site: http://www.rcaaudiovideo.com/audio/voicerecorders/?sku=VR5320R . Click on the Support/Manuals tab. The direct link to the English version of the manual is: http://audiovox2.info/docs/common/VR5320R/VR5320R_OM.pdf .
I hope this helps.
Jun 05, 2011 | RCA VR5220 Digital Voice Recorder
I have a RCA VR5320R digital voice recorder. My voice recordings are stored on the recorder, under folder "A," but when I attach the recorder to my computer, eventhough the device shows up under...
Mar 09, 2011 | RCA VR5220 Digital Voice Recorder
How to download software for the rca vr5320r
Go to www.rca.com ..downloads are in the Audio/Video link.
Jan 24, 2011 | RCA VR5230 Voice Recorder
No voice recognition
You must have already set up and trained a user with the Dragon NaturallySpeaking software prior to transcription. Make sure that the Digital Voice Editor (DVE) software is not opened prior to starting these steps.
Open the Dragon NaturallySpeaking software.
The Dragon Bar window opens. From the Dragon Bar menu, click the Sound button.
From the Sound button, select the Transcribe Recording menu item.
The Transcribe a Recording dialog box opens.
Click the large square button to the left to start the DVE software.
The Digital Voice Editor window opens.
NOTE: If the file you want to transcribe is still on the Integrated Chip (IC) recorder (which will be reflected on the left side in the IC Recorder window), you will need to connect the IC recorder to the computer using the supplied USB cable, or transfer the file to the computer.
Select the item you want to transcribe from the PC window on the right side.
Click on File from the tool bar.
Select the Voice Recognition menu item.
The Converting.. Dialog box opens.
The Transcription Options dialog box opens.
Click the Transcribe button to continue.
The Transcribing window and Dragon Pad window opens.
The text is displayed while the transcription is in process.
NOTE: Once the transcription is complete, it may be necessary to make grammar, word, punctuation, and formatting adjustments.
To save the text file, click on File from the tool bar.
Select the Save As. Menu item.
The Save As dialog box opens.
Browse to the folder location to which you want to save the text file and double-click on that folder.
The folder you chose should now be showing in the Save in drop-down box near the top.
Type in the desired File name in the File name drop-down box towards the bottom and then select the document type.
Click the Save button.
Click the X (close) button in the upper-right corner to close the Dragon Pad window.
Click the X (close) button in the upper-right corner to close the Digital Voice Editor software.
Feb 10, 2010 | Sony ICDSX68 Digital Voice Recorder
42 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
