Assume rings are shot or ?
SOURCE: WILL NOT BUILD PRESSURE
Many craftsman compressor are built by champbell hausfeld using a dry type of cylinder and piston (no oil, no crankcase). If dry type, check for worn cylinder and piston ring. Pieces of the vinyl ring can jamb between the reed valves in the head causing air to escape from the intake. If your compressor has a crankcase and oil, check for broken reed valves in head. Spray soap solution on hoses, checkvalve, drainvalve, and fittings to check for leaks. Most likely problem is reed valves broken or open. Parts are available from sears or match parts to chpower.com. enjoy
SOURCE: coleman compressor no build up of pressure
your correct either the valves are worn or maybe just need cleaning as for the gaskets,idont know what part of the world your in but check out coleman on the internet or failing that ,i have maid these from gasket material suuplied from my local bearing supplier
Parts for coleman are available at www.mastertoolrepair.com your compressor is listed as L0502710. If however you like to tinker, you can make a pretty good reed valve out of aluminum can material or other (any ideas?). It is fairly easy to cut, does not last as long as factory stainless steel, but for short term, why not? Good Luck
SOURCE: air compressor not filling tank
Most compressors with the problem that you are having suffer from leaking valves. As in a gasoline engine, leaking valves will lower efficiency. Valves in a compressor are in the form of reeds that seal against valve plate. Leaking reed valves or gaskets will increase the discharge air temperture. Inspect these parts with a magnifying lense. Look for evidense of wear or leaks. Also look for signs of air leaking from one cylinder to the other thru gaskets. Replace valve plate as necessary. Simple test, as your compressor is filling, check the intake for strong suction; as it neers the 92 psi mark suction will probably deminish if you have leaking valves. If suction remains strong at 92psi then you have a leak at the discharge side. Check with soapy water on all parts. Good luck
SOURCE: air compressor fills, but slows down as the pressure builds
sounds like you need a new check valve which should be somewhere between the compressor outlet piping,tubing,etc and the tank which prevents the air in tank to back feed to the compressor which would cause hard starting and could damage the motor easy way to check is when you shut off the compressor with some air in the tank if the check valve is bad it would continue to bleed air out out the unloader valve .the unloader valve on your unit is most likely part of the pressure switch when the unit shuts of it should only bleed down the pressure in the pump so it would make it easy to start when needed hope i didn't confuse you
