Question about Nikon COOLPIX L2 Digital Camera
Nikon coolpix l25 wont turn on - Nikon COOLPIX L2 Digital Camera
4 Suggested Answers
  • 102366 Answers
SOURCE: Cannot turn OFF self timer mode on Nikon coolpix 8400.
Press the self-timer button (marked with a one-handed clock) once for ten-second delay, twice for three-second delay, three times to cancel timer.
Posted on Dec 12, 2010
BillB-SA
  • 2761 Answers
SOURCE: My Nikon COOLPIX S51 Will not turn on.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 08, 2009
yo5bdm
  • 81 Answers
SOURCE: my nikon coolpix makes ticking sounds when i turn
You could have dirt or a malfunction of the optical system. Get it to a local electronist to get it cleaned.
Posted on Apr 08, 2010
How to fix a cracken screen on a Huawei H866C
find a spares/repair for parts and swap the lcd..... you can't fix a cracked lcd.
you could also try looking for the part, by using the part numbers on the back of the lcd unit.
May 24, 2014 | Nikon Coolpix L25 Digital Camera White
Cause it wont
If your batteries are okay (try charging them overnight) it sounds like you'll have to send the camera in for service. Call Nikon Coolpix support at 1-800-645-6687
Here is a link to the Nikon support page which has lots of good info:
https://support.nikonusa.com/app/answers/detail/a_id/238/~/nikon-support-contact-information
May 18, 2014 | Nikon Coolpix L610 Digital Camera
Nikon l610 wont turn on
How to transfer pictures from nikon coolpix L25 to computer which is taken without using scandisk
Insert the memory card, press the MENU button, select the Playback menu (right-pointing triangle), then select the Copy command.
Mar 24, 2013 | Nikon COOLPIX Cameras
I have a red flashing clock face on my L25 but no mention of it in the manuel
Set the date and time as described in the "Time Zone and Date" section of the manual.
Oct 01, 2012 | Nikon Coolpix L26 Compact
My Nikon wont turn on or charge
You may need to purchase a new battery for this. Or there could be a problem with your battery charger or power cord. Replacing the battery and charger is the simplest solution.
Something like this:
http://www.amazon.com/Nikon-Coolpix-Digital-Camera-Accessory/dp/B0040996PM
Jul 26, 2011 | Nikon Coolpix S3000 Digital Camera
Nikon coolpix s570 wont turn on
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
May 26, 2011 | Nikon COOLPIX S570 Digital Camera
My nikon coolpix s230 wont flash, is there anyway to fix this?
Have you accidentally turned it off? Is there a picture of a lightning bolt with a line through it on the screen?
Dec 20, 2009 | Nikon COOLPIX S230 Digital Camera
Nikon coolpix s10 vr lens error on display and camera wont turn off
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 09, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon COOLPIX L2 Digital Camera Logo
229 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
