Question about Craftsman Air Tools & Compressors
265-410 craftsman air compressor rod bolt torque specs
emissionwiz
  • 79865 Answers
SOURCE: 2005 Tucson
camshaft sprocket bolt 58-72 ft. lbs. crankshaft pulley bolts 108-132 ft. lbs. crankshaft pulley center bolt 80-94 ft. lbs. cylinder head bolts cold engine 65-72 ft. lbs. warm engine 73-80 ft. lbs. cylinder head rear cover bolts 69-86 in. lbs. flywheel/Driveplate bolts 94-101 ft. lbs. intake/Exhaust manifold nuts/Bolts 11-14 ft. lbs. jet valves 13-16 ft. lbs. main bearing cap bolts 36-39 ft. lbs. oil pan bolts 51-69 in. lbs. oil pan nuts 43-60 in. lbs. oil pan drain plug 33 ft. lbs. oil pump cover bolts 72-84 in. lbs. oil pump relief valve plug 29-36 ft. lbs. oil pump sprocket nut 25-28 ft. lbs. Rear oil seal retainer bolts 84-108 in. lbs. rocker arm shaft bolts 14-15 ft. lbs. rod bearing cap nuts 23-25 ft. lbs. silent shaft sprocket nut 22-28 ft. lbs. spark plugs 15-21 ft. lbs. thermostat housing-to-Engine bolts 86-114 in. lbs. timing belt tensioner bolt 32-40 ft. lbs. valve cover bolts 43-61 in. lbs. water pump-to-Engine bolts alternator brace bolt 14-20 ft. lbs. all others 9-11 ft. lbs. water pump pulley bolts 72-84 in. lbs.
Posted on Sep 08, 2008
  • 6 Answers
SOURCE: air compressor won't run
Don't run it with the head off! the cylinder will just up and down with the piston and ruin the seals again. I have three Craftsman compressors in my shop and I've torn them all down at least twice. Rather than pay for the kit, I went to NAPA and got a roll of cork gasket material and made my own seals. They don't last as long but they work great.
I'd be willing to bet your seal it just too tight. I made this mistake the first time around too. it's not a very good design as the piston tilts through the stroke. I would try putting a light coat of heavy weight oil on the cylinder wall and move the piston by hand to lube the seal.
Posted on Dec 17, 2008
  • 19 Answers
SOURCE: head bolt torque spec for this compressor
220-300 in lbs work from center out
Posted on Feb 01, 2009
  • 22 Answers
SOURCE: NEED TORQUE SPEC FOR CONNECTING ROD BOLTS ON GX390
the torque setting is 16nm,hope this helps
Posted on Mar 30, 2009
  • 68 Answers
SOURCE: Craftsman 3.5 hp portable air compressor keeps blowin head gasket
I would say the head or block is warped. Use Majic Marker to cover the mating surfaces , the head can be rubbed on a flat surface like a cast iron table saw to find the high spots, or the head can be rubbed on the block.
Careful work with a good flat file will remove the high spots.
The torque value sounds low even for an aluminum block, you could check with a small engine shop to get their opinion.
Posted on Apr 25, 2009
Head bolt torque for ir. ss5 air compressor?
It's not that critical, use a torque wrench and make sure they are all evenly tightened like you would do with the head of a car engine. Use basic torque specs for the size bolt. That can be googled. Start with a lower setting on the torque wrench. Tighten the bolts in a pattern, then increase the torque setting and torque the bolts again.
May 20, 2016 | Ingersoll Rand Air Tools & Compressors
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
What are are the tork spec on the clyinder head bolts
Torque setting for that cylinder head would be around 20 ft/lb and about 30% less if the bolt threads are lubricated before insertion.
Jun 22, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
What is the torque specs for a cylinder head for a craftsman air compressor 150 psi 7hp 60 gallon
The spec is 25-30 ft lbs.
Here are the specs.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D22629/d22629.pdf
Oct 10, 2010 | Craftsman Air Tools & Compressors
Torque specs for the head bolts on a GMC compressor
There are surely specs, but you should be able to feel the right tightness for these bolts. It's when the threads just begin to bend-- if you don't know this feeling, and can't find the torque specs, use 15- 20 ft. lbs.
Nov 23, 2009 | Ingersoll Rand SS3F2 Gm Ir Portable...
Need to know torque specs for rod and head bolts on a quincy model 350-11 air compresser
25-35 ft. lbs. Never saw any air compressor head bolts any other torque range If that number is a little squishy for you, call Quincy up tomorrow at
212-222-7700
Aug 21, 2009 | Air Tools & Compressors
Head bolt torque spec
220-300 inch lbs work from center out
Jan 15, 2009 | Coleman 6.5hp - 80 Gallon Vertical ASME...
Air Tools & Compressors Logo
67 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
