Question about Air Tools & Compressors
Air Compressor starts then stops
I have a Sears air compressor model 921-153500. When it starts in only runs for a few seconds and stops. It does not trip a circuit breaker in my shop. I removed the cover to the pressure switch and pressed a black button that appears to be a reset button. It will then again start and stop after a few seconds. I just replaced the pressure regulator as it was leaking. Compressor ran fine for a few cycles after the regulator replacement before the problem described above began.
  • 138 Answers
SOURCE: sears craftsman 3 gal/1.5 hp air compressor won't run
are you using an extension cord? if so, plug the compressor into a wall socket, if it fires up fine then your extension cord is too long or not heavy enough - other problems could be a bad start capacitor, a loose connection in the pressure switch, or a bad switch
Posted on Aug 18, 2009
  • 19 Answers
SOURCE: Air leakage through pressure switch needle
1)Let your unit pump up.
2)Turn it off.
3)Find the supply line from the pump to the tank.
4)Remove the supply line from the pump head.
5a)If you hear air coming from the tank you have a bad check valve.
5b)If you do not hear air coming from the tank, you have a leaky
pressure switch.
Posted on Feb 02, 2009
  • 1388 Answers
SOURCE: Makita MAC2200 runs fine (with new Manifold Switch
I have worked on many makita compressors and have run-across this problem on a few of them. Your compressor has a check valve that is supposed to hold tank pressure after the switch reaches set pressure. There is an unloader valve built into the pressure switch that releases the pressure in the discharge hose after the unit shuts off. The unloader allows the compressor to restart with-out any pressure in the discharge line. If the brass check valve is leaking pressure back into the system, air will leak out of the unloader valve. Follow the discharge line to the tank and you will see the brass check valve. To test valve for fault, run the compressor till it builds around 80 psi and unplug the unit from the wall outlet. Remove the 1/4" hose connector from the check valve and check for air leaking out of the valve. If it is leaking you can order form www.toolpartsdirect.com. or call the makita 1-800 number. The price is about the same. Good Luck on your repair.
Posted on Mar 19, 2009
  • 67 Answers
SOURCE: Electric Air compressor just hums then trips breaker.
usally there is a releaf valve that takes the pressure off the compressor while it is resting. If that pressure is not off when the drive piston starts the motor will overload and blow the the breaker or reset. Check for a releaf valve for when the unit has reached full pressure
Posted on Jun 16, 2009
  • 98 Answers
SOURCE: breaker relay tripping out
If the unloading valve trips , which i think is the safety valve that tells me the compressor is pumping up past its maximum allowed pressure. that black switch should be the overload switch. check the amps of the wires going to the motor while its running and then look at the name plate of the motor to see the maximum amount of amps that the motor is allowed to draw.
Posted on Jul 21, 2009
Trips circuit breaker when I turn it on. Runs maybe a second or two and then trips breaker. Seems like compressor is stuck??
Either that or the start capacitor has failed. . The thermal overload should stop current to the compressor, so look at that device too.
Nov 17, 2016 | Heating & Cooling
What causes caravan aircon to trip circuit breaker on start up
My first guess would be that the compressor has seized. If not the compressor seizing, then I would look for a short to ground in the wiring. If you pull the cover of the AC you will most likely find that the compressor motor is plugged into a receptacle. If you can unplug or otherwise disconnect the compressor motor from its' power source and activate the thermostat to run and the circuit breaker does not trip, it is the compressor motor. If the circuit breaker trips, then it's in the wiring.
Aug 30, 2014 | Dometic Rooftop RV Air Conditioner
Why does air conditioner trip circuit breaker?
call the technician
indicates a compressor problem
could be a failed start/run capacitor or compress failure
Nov 19, 2017 | Heating & Cooling
Compressor trips breaker on startup or quickly after
The breaker may be too small. Check the amperage requirements against the breaker size.
May 31, 2012 | Craftsman 33 Gallon Vertical Portable Air...
Sears Craftsman Air Compressor power problem.
Check the compressor tank for any water, the symptoms are just what you would expect if there is excessive moisture in the tank.
Mar 06, 2012 | Air Tools & Compressors
The jenn-air fridge that i have jcd2289ae has stopped working it is tripping the gfi, i have tried plugging it in another plug in but it trips the breaker
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2289AEQ/1266/0165000/M0406284/00012?blt=06&prst=&shdMod= here is a simplified wiring diagram for your unit. It might help you track back the problem.
Before it started tripping the circuit breaker what was your refrigerator doing that was not normal? Usually, before something fails massively it will give you hints it is coming. Did your ice maker or lights stop working? Has the compressor been running an excessively long time?
What trips a breaker is the unit drawing more current that what the breaker is listed at. So something in the unit has shorted to cause this to happen. Although the first thing we check in a situation like this is the compressor circuit it isn't always the cause.
Jun 26, 2011 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Compressor causes 20 amp breaker to trip.
If I did the math correctly, 5.5 HP is right at the boarderline of 20 amps, particularly for an older machine that has some deteriorating electronics.
What to do? Can you reconfig the motor to run on 220 Volts??? It would then run on 1/2 the amps.
If you have a dedicated 120 line for this compressor now ... all you have to do to change that to 220 is change the breaker (I presume you have a vacant slot to do this). Find the "neutral" for that wire (white) ane make it the "red" for your compressor line ... (and mark it as such for your future behefit) change the outlet from 110 V 20 A to 220 V 20 A. Both lines will run on #12 with G wire.
If you dont have a slot, you could change one of your standard slots to a "piggy back" remodeling style breaker (has two breakers in one slot). This will free up one slot in your panel for the new 220 (double pole) breaker.
Let me know what you think
Thanks for using FixYa.com
Positive comments appreciated
a
Oct 29, 2009 | Air Tools & Compressors
Circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
May 01, 2009 | Dometic RM2852 Refrigerator
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Nov 20, 2007 | Ruud Central System Air Conditioner
Air Tools & Compressors Logo
2,023 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
