Question about Foxconn A7GMX-K Am2 Amd 780G 5.2 Gt/S
Is it possible to replace the yellow bracket that holds the cooling unit in place?
One of the plastic clips has broken off. If it is possible to source a part and replace it then I won't have to replace the whole tower.
  • 5,660 Answers
  • 2 more comments
  • Nick Willis Dec 03, 2012
    Thanks, I will order one and see how it goes
  • joecoolvette
    joecoolvette Dec 04, 2012
    Isn't that hard to replace. Thank you for the rating!
  • Nick Willis Dec 30, 2012
    Working really well - thanks
  • joecoolvette
    joecoolvette Dec 31, 2012
    Hey any time!
Will not make ice
I have a Samsung RF265AABP model. I had the same problem on several occasions. One time the problem was a broken temperature sensor wire on the ice maker. The sensor assembly often gets snagged on the ice tray or scoop or something and falls down, making it more likely to snag, and prevents the ice maker from cycling when frozen. It is quite easy to remove the ice maker once you get the drawer removed from the slides. It is held in place by two plastic clips located near the back of the slides. Pop the clips out, and then lift the drawer out. Pull the front plastic cover off the ice maker, then remove the two screws holding it to the top of the freezer compartment. Slide the icemaker assembly forward about 1/2 inch and it will drop down. Unplug the wiring connector and the ice maker assembly will drop right out. The temperature sensor is located in a flexible rubber like unit that holds the sensor against the plastic water tray. This whole assembly often falls out, and may be found mixed in with the ice.
I fabricated an aluminum bracket from angle stock to hold the temperature sensor assembly in place, and used a small tie wrap to hold the wire to the bracket, up and out of the way after soldering the broken wire of course. The tie wrap is not shown in the photos below. I drilled and countersunk two holes for the 4-40 screws holding the aluminum bracket. The temperature sensor is not shown in the photo, but the wire comes out the right side and crosses over to the left in front of the aluminum bracket.
Aluminum bracket holding sensor in place.
Ice maker assembly showing screws holding it to freezer. It is upside down in this photo.
Sep 23, 2013 | Samsung RS2630SH Side by Side Refrigerator
Rf265abwp display shows 4 8's in display last on
The broken wires at the ice maker can cause that problem. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. After fixing this problem several times, I finally made a metal bracket from aluminum angle, drilled and tapped 4-40 holes in it, and drilled the plastic icemaker to mount it more permanently. I added a wire tie to hold the temperature sensor wire up and away from possible snag sources. The sensor wire and wire tie are not shown in the photo below, but if you have the tools to solder the wires and fabricate a bracket it helps a lot. It is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out.
Ice maker assembly upside down on bench.
Aluminum bracket and screws
Bracket installed. The sensor is not shown in this photo, but the wire comes out the right side and crosses in front of the metal bracket. The wire tie holds it to the bracket near the top center (hole not shown).
Sep 21, 2013 | Samsung Refrigerators
Ice maker stopped making ice
Broken wires at the ice maker or the temperature sensor falling out can cause that problem. Check your digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
Sep 15, 2013 | Samsung RF263AERS (258 cu ft) Bottom...
Icemaker stopped
Sep 13, 2013 | Samsung Refrigerators
88 88 fault on Samsung rf265abwp
Broken wires at the ice maker can cause that problem. It could be another temperature sensor as well of course. Check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
z
2q==
z
Sep 12, 2013 | Samsung RF265ABWP (25.8 cu. ft.) Bottom...
Samsung RSG257AABP stopped making ice. What to check before buying a new ice maker?
z
2q==
z
Sep 05, 2013 | Samsung Refrigerators
Ice maker not making Ice.
z
2q==
z
Aug 18, 2013 | Samsung RS2630WW Side by Side Refrigerator
Model RS267TDWP/XA. Not making ice
Broken wires at the ice maker or the temperature sensor falling out can cause that problem. On my model RF265AABP, I check the digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
z
2q==
z
Aug 11, 2013 | Samsung RF265AA Bottom Freezer French Door...
I can't get the ice maker to come on. What can I do?
Broken wires at the ice maker or the temperature sensor falling out can cause that problem. This solution applies to a different model, RF265AABP, but may be similar. Check your digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
z
2q==
z
May 03, 2013 | Samsung RB2155 Bottom Freezer Refrigerator
Epson 4180 scanner w/ possible drive belt problem
Check if you have a toggle lock at the back of your scanner, when you are facing the back of it, its on the right hand side near the tpu cable. toggle that 3x and make sure it on the UNLOCK position.
Mar 12, 2008 | Epson Perfection 4180 Photo Flatbed...
Foxconn A7GMX-K Am2 Amd 780G 5.2 Gt/S Logo
97 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
