Question about Baby Lock Esante
ES2 needs calibrated and/or reset to English language
Cannot select English for the language--it seems I need to touch the screen higher than I am able to...for some reason the screen seems to be out of sync with the various selection buttons/indicators...please advise.
  • Baby Lock Master
  • 1,564 Answers
Take it in have it recalibrated.
Posted on Dec 04, 2012
I have a husqvarna Viking designer 1, that I am trying to learn how to use and on the bottom of the screen it is in French, how do I change it back to English?
Are the tabs at the top of the screen in English or French? According to the manual, you should be able to change the language from the Set tab. If these are in French, that will be the second tab from the right. Touch the More (Plus) button, on the left above the Fabric information, to scroll through the Set menu screens. You need the line for Language (Langue, which is on the second screen, just above the More and OK buttons. Press the Next button to the right of this line to scroll through the available languages. Press the OK button (on the right next to the More button) to save the selection.
The manual is available here: http://www.husqvarnaviking.com/SiteFiles/ClientSite/9b/9bcc04bf-d0a8-42ba-b7a0-5734832311ff.pdf . See page 30 for what the menus and tabs look like in English. All of the items will stay in the same place even when they are displayed in French. I hope this helps.
(I'm not completely certain of the French that will be on each line. The Language line might read as la langue. Set could be parametres or reglage.)
Nov 18, 2016 | Husqvarna Sewing Machines
My Janome mc8000 touch screen is responding all wrong,touch one pattern and it does another but the re calibration won't work
sounds like there could be something wrong with the computer probably needs to be serviced
Apr 01, 2016 | Janome Sewing Machines
Letter characters won't change
You need to re-calibrate the touch screen. It is in the settings menu to reset touch screen. Done.
Cheers,
Embroidery Services
San Diego, CA
Sep 24, 2014 | Baby Lock Esante
Janome 11000
I'm guessing here but you might need to calibrate the touch screen or possibly a circuit board has moved inside the machine. I don't know if you can reboot the machine or return it to factory settings which might reset everything. Failing all of that I'd be asking a computer/phone repair place to look at it.
Apr 23, 2013 | Sewing Machines
Screen calibration screwed up.. need to know how to reset it?
You can get back into the touch-screen calibration routine if you start up the machine with both of the needle offset buttons pressed at the same time ... once you've calibrated the touch-screen you'll be OK again.
Dec 30, 2012 | Bernina Artista 180
I have a Husqavarna Designer II sewing Machine and the language every time I turn off the machine and then power it up again stays on another language. I have read the book many times on how to change the...
Hello Michella Linton
On the touch screen touch "English" until your language choice is indicated. The language setting remains until it is changed. Refer to manual page 21 which can be downloaded free from this link: http://manuals.husqvarnaviking.com/
Happy Stitching
Sewingirl/
Apr 18, 2017 | Sewing Machines
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
My touch screen on my Designer 1 is off-kilter. You touch to the right to get the left box to work. For example, if I use the first stitch I touch the second stitch. The touch also does not work well...
You need to access the SET menu. Try pushing to the right of this in various spots and hopefully you will be able to get in to this menu. Then you need to keep hitting More until you get to "Colour touch screen adjust" . Select this (by trial and error - keep touching to the right of the square until it is selected). Now get your stylus and carefully press it directly in the centre of the crosshatches - first the one marked "1" - it should turn green - then the one marked "2" - it too will turn green. Your screen is now re-calibrated and you should be able to push the buttons and get the correct selection. If not, I think the machine should be seen by a technician. There may be problems either with the screen or the motherboard.
Oct 13, 2010 | Husqvarna Designer I
Janome MC 9000 off touch screen calibration
Thanks guys
I remembered the fix!!
On the Janome MC 9000
To calibrate the touch screen
1. Turn off
2. on Sewing arm above needle there are a series of buttons
3. Hold down bottom 3 buttons
4. While holding turn on machine
5. Using scribe
6. Touch the centre of each + as it appears
7. It will go Centre bottom rh centre top lh as you select each + position it moves of it's own accord.
8. Turn off machine
9 Turn on and test.
Important sometimes this does not entirely fix prob!!
Simply do it again "Yahoo""
Some mechanics will try to tell U the screen is on it's way out
Bollocks just calibrate.
Thanks
CYA
Nov 16, 2009 | Janome Memory Craft 9000 Computerized...
Changing the language
Turn on your machine. The SET tab is the fifth from the left (or second from the right). Touch that.
You now need to touch the More button, which is on the bottom row and is the button on the left hand side (there are two buttons at the bottom - More and OK).
On the next page that comes up, the LANGUAGE select button is the single orange button at the bottom of the list. The two buttons at the very bottom are once again More and OK, so go above them to the single orange button. Each time you press this, the language changes. There are quite a lot to scroll through, but keep pushing it until English comes up again.
That should fix your machine for you. No suggestions on how to fix your husband, though!
Pamsquilt
Oct 16, 2008 | Husqvarna Designer I
Sewing Machines Logo
77 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
