Question about LG WM-2277HW Front Load Washer
Wm2277hw DE code
How to a access the drain pump motor in order to change it out?
    Top Expert:
  • LG Master
  • 9,472 Answers
Take a look at this page.
Posted on Dec 03, 2012
4 Suggested Answers
SOURCE: lg tromm wm2277hw code de
Error Code "de" is for "door switch assembly faulty".
You can down load the service manual from this site:
http://136.166.4.200/contents/Laundry/WM2277.htm
Have fun!
Posted on Mar 06, 2008
  • 3 Answers
SOURCE: I have an LG WM2277HW that shows a ''DE'' problem code
I bought a suitch door (7,5€)...nothing... I bought a drain pump (€18)...and dont´work. I have spoken with some experts and they say" the problem could be from the "PWC" board ". I live in Portugal and it´s price is €75. I´m not shore if is the right advice because I bought a new LG Machine with Direct Drive tecnology... but I have stored my old LG Machine. I hope this information could be useful
Posted on Jan 06, 2010
TheMobilian
  • 8220 Answers
SOURCE: My LG washing machine is giving me a dE error
Drain error. It took longer than normal for the machine to drain. This is caused by the wrong detergent, too much detergent, drain hose way too high, slow drain, and my fave: frozen drain. I have your wm2277 deluxe polyunsaturated, 99 and 44/100th% real deal repair manual. Right ova HERE
Posted on Feb 16, 2010
What are the intructions on how to change the "motor pump assembly"? I have the part and want to try abd save $ by changing it myself ... thanks
Here's a link to complete instructions to repair your washer. You may require a special tool to remove the installed pump. Click on the small pictures at the end of the page to view the detailed instructions. Here's the link;
http://www.managemylife.com/mmh/questions/228916-lg-washer-model-wm2277hw-code-oe-wont-drain
May 18, 2011 | LG WM-2277HW Front Load Washer
Tip
Filter clear, but won't pump out. DE error code. OE error code.
If you have the "OE" error code, which is really a "DE" (drain error) code, and you have checked the filter and it is clear, then most likely the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall. You can reach through the large hole in the bottom of the washer base to access the pump. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 5.5 or a 6.
on Apr 21, 2009 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
either drain pump itself is broken or something jammed in between the pump housing and pump impellor. the drain hose itself or pump cleanout cup (behind lower left access panel) may be clogged too.
Mar 26, 2010 | LG WM-2277HW Front Load Washer
DE code comes up repeatedly; nothing wrong with door.
DE is drain error (dE would be door error)
Check the filter behind the access panel on the lower left on front of the machine. If it is clear, you may need to replace the pump motor.
Mar 17, 2010 | LG Washing Machines
Feb 15, 2010 | LG WM-2277HW Front Load Washer
Not fully drained within 10 minutes. check the pump for strings or small items . Check drain DE=drain error.
For a manual go HERE
Nov 06, 2009 | LG Washing Machines
I have the LG Tromm, WM2277HW. I followed the
I took the entire washing machine apart. I checked the drain pump as the repair service said I needed a new one, as well as a rear and front drum, shocks rear bearing assembly. Would you believe the only thing wrong with the unit was that the drain pump was clogged at both ends. Machine is running fine and not throwing the LE Code. The repair service (LG recommended dealer) should be shot for telling me to throw out the unit.
Aug 01, 2009 | LG WM-2277HW Front Load Washer
Fault DE ( motor overload?)
DE error code stands for "Drain Error" resulting from no or too long a drain time. Open access door at lower left on front of machine. If small hose is not plugged, you can drain the remaining water out of it, then remove the large screw thing there. (it's the filter.) Clean it and replace. Test. If filter was clear, you may need to replace pump motor.
Mar 30, 2009 | LG Washing Machines
Error code oe
That's not OE, that's DE = Drain Error. Open the access door at the lower left on front of the machine. Use the small hose to drain the remaining water out of the machine, then open the large knob which is attached to the filter. If there is nothing in the filter, you may have an object which made it past the filter and is blocking the pump impeller, or the impeller may have come off the pump motor shaft, which would require pump motor replacement.
Oct 15, 2008 | LG WM-1485FHD Front Load Washer
Lg wm2277hw
You do not have an "OE" error, you have a "DE" error. DE error is "drain error" which displays if the washer has not pumped out after 10 minutes. If there is water in the machine and no obstruction in the filter I would suspect that the pump impeller is bad, and you would need a new pump motor. (part # 4681EA2001D) Pump motor is located directly to the left of the filter, and can be accessed by tilting the washer back and reaching it from underneath. The pump housing is held onto the machine by three phillips head screws.
If you have "DE" error and there is no water in the machine that's a whole different problem I'll address if you say that's the case.
If you need good service, try calling a small dealer who sells and services the procuct line you are having a problem with. You can find LG servicers at us.lgservice.com but avoid the utility companies, A & E, Sears, and all the big guys who try to service every brand but often times are not very familiar with your brand.
That should help. Carl S., factory authorized LG technician for over 10 years.
Aug 25, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
