Question about ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard
How to set the CPU frequency (MHz) on bios set up?
  • Brian Perry
    Brian Perry May 11, 2010
    Once you boot up into bios, you should be able to change the frequency under the chipset feature. It varies for whatever bios you have. If you can't find it, look me up and I'll try to walk you though.
    Sergeant:
  • 270 Answers
Enter in bios setup.change frequency in prescribed column
Posted on Jan 12, 2009
Athlon processor upgrade assistance:
Go to this link:
http://us.msi.com/?func=searchresult&keywords=ms-7025
Select the model motherboard you have and click on the CPU support link, it will show you a list of CPU's that are supported. You have a socket 939 board and AMD CPU's are now AM2, AM2+ and AM3 socket, which are 940 pin. It may be difficult to find a new CPU for your motherboard that is new since they have not been made in awhile.
Feb 09, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
I have a Gigabyte GA-7N400-L motherboard CPU problem
dit you try a bios update?Some motherboard needs a bios update for a newer cpu.
Jan 17, 2010 | Gigabyte GA-7N400-L Motherboard
Motherboard and CPU Frequency
When you power up the computere press F2 or "del" or F5 key towenter in bios then load optimal defaults settings.then save then check.
If still problem arise then pull out cmos cell for 15 minutes from motherbord then it auto reset to factory defaults.
Jul 24, 2009 | ASUS P4PE-X Motherboard
Overclocking a CPU Type Intel Pentium IIIE, 581 MHz
If you have an adjustment for the VCORE voltage in your bios, bring it up by one value, then try overclocking the CPU.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
How to overclock a pentume 4 processor
Increasing of FSB (processor clock) from 10% up to 15%.
from 1700Mhz you can get 1850 Mhz.
from 2400 Mhz you can get 2640 Mhz
from 3000 Mhz you can get 3300 Mhz
but not all mater board allow this do.
Mar 07, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Motherboard Jetway V880DAS, PCU Athlon xp 2800, Memory PC 3200 2Gb. Bios Update 880DASA7.BIN .Operating system Windows XP Pro with Service Pack 2 I Set the CPU FSB Jumper to 166 Mhz.The computer keep...
is this the first time you encounter this problem with the athlon Xp? i have encounter this already with my PC. you should update again the bios of your computer, and load the setting of your bios to the default settings.. try to restart your computer.. and try to contact me as soon if this works for you. thanks!
Apr 15, 2008 | Computers & Internet
RAM not running at full speed
Go to page 33 in your manual, see DRAM Clock/Drive Control & press enter. You can tweak your memory to run faster however your manual suggest not too. Hate to see you burn it up. As you will see everything is set to Auto:
Max Memclock (Mhz) [Auto]
1T/2T Memory Timing [Auto]
CAS# latency (Tcl) [Auto]
When DDR Timing Setting by is set to Manual, use this item to set the DRAM frequency. Would be nice to have a side panel fan blowing on your memory.
Link to your board.: http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=455&DetailName=Specification&MenuID=1&LanID=9
Jan 04, 2008 | EliteGroup K8M800-M2 Motherboard
OVERCLOCKING
The 800 MHz seems to be your system bus speed and not the CPU speed. They a related but no quite the same. Overclocking is usually defined as forcing something to operate at a higher speed than it was designed to. If you changed the 800 MHz to 1.6 GHz in your BIOS then yes it could be considered overclocking.
One thing I would like to mention is that when changing clock speeds in your BIOS, do it in small steps, if done in large steps it can cause system instability.
Oct 28, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Motherboard Jumper free code
Set Jumper Free Mode (manual) and new FSB in BIOS Setup - menu "CPU External Frequency (Mhz)".
Oct 24, 2007 | ASUS P4SP-MX Motherboard
ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
