Question about Sewing Machines
Thread to loose under the material
As I sew the thread under the material is to loose and bunchs up
  • Sewing Machines Master
  • 7,365 Answers
Try changing the needle
adjust the top tenison one number or letter higher, using a scrap
piece of cloth to check the stitches till they look normal
clean under the needle plate and in the bobbin area for lint
Posted on Dec 03, 2012
SOURCE: Thread bunches from the bottom while sewing.
Hello, sewing is a part of my income and I've encountered this problem before and managed to fix it on my own, by trying out these different things. I re-threaded the machine and checked to make sure that the tension is not too loose. Check the bobin and the sack the bobin fits into, sometimes it comes loose too, click it back into place and re-do the bobin. adjust the tightness of the stiitches, I usually put it on 2 .5 - 3. Hope this helps. Good luck to all. Nefishakh@hotmail.com
Posted on Dec 11, 2008
  • 46 Answers
SOURCE: Thread is bunching up unside of the material does not catch bobbin thread
This sounds like the tension is not set properly for what you are sewing.
Posted on Oct 24, 2008
bargainbox
  • 1388 Answers
SOURCE: on underside of material thread is loose and not catching
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Posted on Sep 02, 2009
  • 1116 Answers
SOURCE: Thread bunching under work
Clean away all the thread.
If you look through the Singers at Relics.com you may find your machine and order a manual so you can be sure the bobbin has been threaded and is inserted correctly into the machine.
It is possible the timing has to be adjusted - you can find this at sewusa.com
Posted on Feb 22, 2010
  • 40 Answers
SOURCE: top thread bunching under fabric when sewing
tension could be too loose. start with bobbin tension- should allow thread to pass with SLIGHT resistance. then adjust top tension at about 2-3 to start.
Posted on Jun 01, 2010
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Bobbin thread bunches up under material
make sure that the bobbin carrier is fixed in properly
make the needle thread tension a lot tighter
Jun 23, 2016 | Sewing Machines
Cotton is loose/looping under material?
Sounds like bird nesting.
The #1 thing is to install a brand new needle (old, worn, nicked, or bent needles can create a lot of havoc).
Remove all the thread from the machine. RAISE the presser foot and rethread from the beginning verifying that it is threaded correctly. Make sure the bobbin is loaded and threaded in the bobbin case properly.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Why Do Get Bunched Up Thread Under My Fabric
8 Tips to Fix Birdnesting in Embroidery
Jan 28, 2016 | Sewing Machines
Why is my thread birdnesting? i am getting some thread that bunches up under my fabric. I have played with the tension changed needles, and rethreaded both top and bottom
bunching up under the material is loose tension of the needle thread
pull the thread out before you thread the needle and if it doesn't require a small amount of effort to pull then the thread is not between the tension plates or the tension plates are not being allowed to move closer together to add the tension
check that the thread is actually between the plates and not to one side of them
full tension adjustment should make it fairly difficult to the thread by hand
Nov 20, 2015 | Sewing Machines
My machine bunches tread on the bottom of the fabric when sewing. What am I doing wrong. This machine is new to me.
thread bunching under material is an indication that the needle thread is not at the correct tension
tighten up the tension setting until the result is where the both treads meet at the center of the materials being sewn
practice on pieces of scrap until you get it right
Oct 01, 2015 | Sewing Machines
Can't get Juki tension right
which tension is wrong
if thread is bunching up under material increase the tension of the needle thread if the bottom thread is loose then increase the bobbin thread tension
each thread result for above or below material will indicate which thread to alter the tension on
Jul 02, 2014 | Juki Sewing Machines
The top thread just hangs and knots on bottom of material
try changing the needle-flat side goes to the back of the machine
check to see if the thread has come off the thread take up lever
try rethreading the machine top thread & bobbin
clean under the needle plate area & also in the bobbin area for lint or loose threads
Feb 20, 2012 | Sewing Machines
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
80 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
