Question about Thule Boating
Chevy colorado wheel vibration above 40
I have a 2007 chevy colorado that exhibited vibration similar to a slipped belt in the tires. I changed rims and tires and the same thing still occurs. It will stop if I loosen and retighten the rear wheels and resume after a couple days. If I don't do this the vibration continues. I suspect a brake drum issue possibly but I am a little stumped regarding what could cause this and don't want to blindly replace parts until I find the problem. Also when this occurs I have pulsing in my brakes like a warped rotor that again will stop when the pulsing stops. The two are directly related.
    Top Expert:
  • Thule Master
  • 48,330 Answers
If it is brake or drum related best take it to an accredited brake specialist shop for drum machining or disc skimming
it will take a proper diagnosis to determine what has to be done so get a quote
Posted on Apr 16, 2017
Shakes at 65mph had tires balanced also I cant feel it in the steering wheel it feels like it's coming from the back passanger side or middle
put tires from rear up front and front to rear and see if tires cause a shake also make sure no debris on hub so rim sits flush if no change and still vibration check drive shaft and u joints
Jul 27, 2016 | 2003 Chevrolet Tahoe
I have a 1999 Chevy Silverado 1500 exc 4wd at speeds over 50 and it starts to shake and vibrat and really loud what could it be?
Wheel balance problems usually occur at speeds above 40mph. Also check driveline u joints for problems, but these usually show up when taking off and vibration at lower speeds. Check wheel rims for being bent and tires that are free of bumps or out of round.
Apr 03, 2015 | 1999 Chevrolet Silverado 1500
2001 chevy silverado steering wheel vibration problem
bent alloy, bent steel rim, broken belting inside of tire(caused from hitting a good size hole). lug nuts not torqued to correct ft lbs, outer or inner tie rods, toe/ cmber out of adjustment. Are the tires wearing? If not, forget the camber/toe
Dec 14, 2009 | 2006 Chevrolet Trailblazer
My montero vibrates everytime i brake but i already change the rotors and pad and still doing the samething.
you could have bad wheel bearings worn tie rod ends.worn lower ball joints.all 3 of those problems. cause wheel to shake or vibrate.
Jul 20, 2009 | 2005 Mitsubishi Montero
Maxima - terrible vibrations in low speed
A bad tire, a loose wheel, a loose tie rod end, a bent rim, (tire balance at higher speeds), a piece of rust or whatever caught between the rim and brake rotor, or between the brake rotor and hub. Have you done anything to it prior to this starting?
I had this issue and it was one of my winter tires about to blow out, showing signs of weakness.. hopefully this helps!
May 26, 2009 | 2001 Nissan Maxima
1996 dodge grand caravan vibration 45 mph to 55 mph replaced right front axel still same problem vibration no felt in steering
Vibrations while driving like you are describing can come from tires that have defects (internally broken belts) (wheel weights that have fallen off) or a bent rim (perhaps from another driver [not you :-) ] hitting a curb) Are the tires worn? Have they been balanced and rotated regularly? You report no vibration in the steering wheel.
Vibrations during braking can be warped rotors or discs (but this doesn't sound like your problem since these kind are usually felt in the steering wheel during braking).
If and only if you feel like you can do this safely,
you can try getting the car up to 55, placing the car in neutral, then switching the "engine off" but leave the "key on" (be warned the power steering will go out but the vehicle can still be steered though the steering wheel will be much stiffer) if you try this (do it perhaps in a vacant parking lot or on an empty road) and the vibration goes away with the engine off but while the vehicle is still moving, then the vibration is engine or transmission related. If this is the case you might hope for maybe a bad engine mount. Bad engine mounts can be diagnosed with the vehicle stopped as well. However, if the vibration remains with the van moving forward but with the engine off, the vibration is likely a problem with the tires or suspension. Try to provide some more info.
If you don't feel comfortable trying the above suggestion, please take the vehicle in to an ASE certified suspension and steering professional for further diagnosis.
Finally, I had a similar situation happen to me today. I was riding with a friend in their van and the vehicle started vibrating more and more around 55 mph. We stopped and carefully checked the front tires (including the lug nuts for tightness) but
found a tire defect. (it had several broken steel belts that caused a bulge in the tire and thus the vibration) We changed the tire and the vibration was gone. Good luck to you.
May 08, 2009 | 1996 Dodge Grand Caravan
98 chevy astro front end vibrates and shakes at 65 mph
You may have to get your wheels re ballanced if you lost one of the weight's on the rim. The other thing to is a bent rim if you hit a large pot hole or crub and last to see if the tire it self has funny wear patterns on the treads.
Other things to look for if your wheels are ok. Check the ball joints Check the tie rod ends Check and pay attention to the Idler and Pitman arm. Your looking for any excessive movments
A good way is to grease all that is mentioned above and see if the vibration is gone.
Lost thing would be the brake rotors but you'ld now that by having vibrations throught out any speed when you apply the brakes to slow down.
Good luck and hope this helps, you should be able to do this on your own other then checking the wheel ballance.
Apr 14, 2009 | 1997 Chevrolet Astro
Boating Logo
78 people viewed this question
Top Thule Boating Experts
Tom Chichester
Richard Warren
Richard Warren
john cordey
john cordey
Are you a Thule Boating Expert? Answer questions, earn points and help others
