Question about Tech Solution TS-900 Calculator
On/off button does not work
I have not used this machine in some time, 4 years. I did replace the battery, but the only way I can turn it on is by pressing the AC key. When I do the display only shows 0. The numbers that I press will not show up on the display. What is wrongg here?
  • 186 Answers
The ac key is you power on key. As far as not being able to input any numbers, make sure there is not a key that is stuck down or depressed. if so try to lift is up and you should be ok. Unless there was a liquid spill. In that case, cheaper to buy a new one.
Posted on Jun 16, 2007
I setup my Harman kardon AVR135 after 4 years not using it and it worked the first time. But then it doesn't respond to the remote nor does the buttons on the console work properly. Any solutions?
First thing I would do is change the batteries in the remote for fresh ones. If you haven't used it for 4 years the batteries must be a lot older. Not sure why the buttons wouldn't work. After the unit has been plugged in for say 24 hours, I would pull the wall plug and try again. There may be internal memory batteries that need to be recharged and reset.
Oct 27, 2015 | Harman Kardon Audio Players & Recorders
Delonghi ESAM3500: - Cannot turn machine on using power button. Turning off and on at socket goes into self-diagnosis. Two whirs of the motor then it shuts down again. Is this fixable or time to throw my...
What do you see on the display when it is plugged in? Does it show the time or any other information? Does it do anything at all when you press the power button?
Aug 22, 2013 | DeLonghi ESAM3500 Espresso Machine &...
I can't figure out how to set the time and date on the HEM7300REL blood pressure monitor. I have a manual and have followed the instructions without results. I don't see a reset hold on the machine. do...
If you remove and replace your batteries...you will not lose the memory. The unit will store up to 90 measurements in non-volatile memory...so it will stay there.
I have the same unit and use these directions....and never had issues with setting the date and time.
2.2
Setting the Date and Time
Your blood pressure monitor automatically stores up to 90
measurements values with the date and time. To make use of the
memory and average values functions:
• Set the unit to the correct date and time before taking a measurement
for the first time.
• If the batteries have been removed for more than 30 seconds, the
Date/Time setting will need to be set.
1. Press and hold the Date/time
setting button (
) to adjust the
date and time. The year digits
(2008) will flash on the display.
2. Press the Memory button ( ) to
advance the digits one at a time.
Notes:
• The range for the year setting is
2008 to 2030. If the year
reaches 2030, it will return to
2008.
• If you hold down the Memory
button ( ), the digits will
advance rapidly.
3.
Press the Date/time setting
button (
) to confirm the setting
when the desired number
appears on the display.
The year is set and the month
digits flash on the display.
4.
Repeat steps 2 and 3 to set the
month.
The month is set and the day
5.
day.
The day is set and the hour digits
6.
hour.
The hour is set and the minutes
7.
minutes.
The minutes settings is set.
button (
) to turn the monitor
off.
When adjusting the date and
time, press the Date/time setting
button (
on, follow the steps above, and press the START/STOP
button to turn the monitor off.
Good luck.
Semper Fi,
Z
Jan 31, 2018 | Omron HEM-780N2 Automatic Blood Pressure...
Hi. I have a Casio CE-3700 that is only used for a few weeks of the year. Once I month I try to turn on the machine and leave it powered up for around a day. I am now wanting to actually use the machine....
It sounds like the machine has lost some programming. What you were doing once per month is what I recommend if not used regularly, but the battery has probably now got to the stage where it is too old to even hold charge for a month. It is probably best to get the battery (internal vanadium type) replaced as it may have started leaking if it is too old. The dealer who replaces it can reset your decimal places at the same time. If you just want to get it running as is and take a chance, then do the flag clear (to get the FFFFFFFFFF on display then SUBTOTAL) on one of your WORKING machines, and tell me the big number that it prints out (this will not lose any data on your working machines, it just reads the settings)
Jul 26, 2010 | Casio Parts Cash Register PC Desktop
I charge the MP3 player and it still shows "low battery" message.
There is a trick to charging the battery in these small mp3 players. It won't charge if it is turned on, and it won't charges if it's turned off. Here's what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
That is if the battery is still chargeable after all this time. The battery may well require replacing.
Apr 19, 2010 | Creative Labs ZEN V Plus MP3 Player
Shuttle has been working fine for about 4 years. Then it would be slow coming on, maybe boot up 20 mins after pressing the on button. Eventually refused to come on at all. I replaced the power supply and...
Change your BIOS battery.
I have an old Shuttle XPC sn41g2. It's been running almost constantly since it was new. About a year ago it started to be difficult, it was difficult to start and sometimes I had to try several times before it started. At the end I had to disconnect and reconnect the mains supply everytime i had to reboot the PC. Then one day I discovered that the prosessor was running at the lowest standard frequency so I went to the BIOS to set it right, did so and rebooted, and the prosessor stil wouldn't run right. After some thought I changed the BIOS battery, went to the BIOS, resat all settings, then it rebooted normally and since it has been running like new.
Jan 02, 2010 | Shuttle XPC PC Desktop
How do you know when your batteries need replaced on Panasonic TG2344?
1. call length is diminished
2. battery takes a long time to - or never fully - charges
3. Handset will not turn on.
4. Handset gets hot during use.
5. Approximately 2 years of regular service.
Any of these indicate it is time to replace it.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 04, 2009 | Panasonic KXTG2344 Cordless Phone
This started last night, my battery indicator
The red or amber flashing lights indicate a bad battery. The Dell battery warranty is only for one year and the D600 has been out for a number of years. You should replace the battery. You can use the laptop as it is as long as it is connected to AC power.
There are several places to buy replacement batteries. One is www.bixcomputers.com. If you do a search on the web you should be able to find other sources.
Good luck and I hope this helps, even if it isn't good news.
Feb 28, 2009 | Dell Latitude D600 Notebook
Nikon coolpix 5600/4600 - won't turn on
I had the some problem... found a fix on another thread here on fixya...
hold the power button and at the same time press the play button.
Mine turned on after about 3-4 seconds of holding them down together!
Aug 06, 2008 | Nikon Coolpix 5600 Digital Camera
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Tech Solution TS-900 Calculator Logo
66 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
